Use this guide to replace the motherboard in your Steam Deck LCD.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
These steps only describe how to physically remove and replace your console’s motherboard. You may need additional software tools and calibration procedures to get the replacement motherboard to function as intended.
Power down your Steam Deck and unplug any cables.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Remove the board shield.
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
Use a pair of tweezers to remove the sticker from the top edge of the fan.
For original Steam Decks: Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
One captive 3.5 mm screw
One 3.4 mm screw
For refreshed Steam Decks: Use a Phillips driver to remove the three screws securing the heatsink to the motherboard:
Two 2.9 mm screws
One 3.7 mm screw
Lift and remove the heatsink.
Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
Use a pair of tweezers to grip the antenna connector close to its base.
Pull straight up to disconnect the cable.
Repeat for the second antenna cable.
Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
Carefully peel the audio cable off of the battery.
Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
crwdns2935229:010crwdne2935229:0
crwdns2947412:014crwdne2947412:0
When will I be able to buy the motherboard?
What is the actual size of the screws (M1.6, M2 , M2.2) as this information would be helpful if someone was to lose a screw while carrying out a repair or re paste.
Why Can't I buy this accessory?
Could we change dram or apu on the motherboard or upgrade thé motherboard ? Cause it s just zen2 and rdn2 .we need better performance and power !!!!
Neither the ram or the APU are replacable. This is about the most powerful of an APU you can get in this formfactor, while not getting abysmal battery life
