Steam Deck Left Button Board Replacement
  1. Steam Deck Left Button Board Replacement, Prepare your Steam Deck for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Prepare your Steam Deck for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Prepare your Steam Deck for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Left Button Board Replacement, Remove the back cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    there should be a picture of the SD card slot at the start of every Steam Deck teardown. i know the note is there but i generally use the pictures to guide me and forgetting to remove the SD card is a very critical step
    Nathan Barrow - crwdns2934203:0crwdne2934203:0
    I agree, I just broke mine...
    Camille B -
    What is the the #1 philips used for? Only the #0 is mentioned in the instructions.
    Christopher Martin - crwdns2934203:0crwdne2934203:0
    I wish they would specify which size to use for which screws.
    Mark D -
    I found it easiest to use a PH1 for the red screws, and PH0 for the rest (including the internals.)
    Chris Clawson -
    Be careful you can strip the screws take your time
    I use PH00 bit
    jaybush74 - crwdns2934203:0crwdne2934203:0
    My last one did. I'm so mad honestly
    kyuuchat -
    I used the PH1 bit for this. You can use smaller bits but ideally there should be no play of the bit in the screw head.
    Charles Semple - crwdns2934203:0crwdne2934203:0
    are there playstation replacements (circle,square,cross,triangle)
    Deór - crwdns2934203:0crwdne2934203:0
    I used the ifixit tools and used the 00 size for the screws on the back.
    Luis B - crwdns2934203:0crwdne2934203:0
    I've completed the guide and found it very helpful!
    I think somewhere in this part it would be helpful to name the size of the correct Phillips driver to use:
    Four 9.5 mm screws
    Four 5.8 mm screws
    Maynard - crwdns2934203:0crwdne2934203:0
    I used the PH1 for the 9.5mm screws and PH00 for the 5.8mm screws. The PH0 wanted to strip one of the small ones.
    Pol Llovet - crwdns2934203:0crwdne2934203:0
    FYI - 512gb version has blue threadlocker on the Orange screws.
    Kyle - crwdns2934203:0crwdne2934203:0
    Just a point for knowledge sake, the Four 5.8mm screws on this step are factory installed with a version of locktite. Not sure why but there will be slight resistance when removing the first time.
    Derek Schmidlin - crwdns2934203:0crwdne2934203:0
    Stripped two of the 5.8mm screws, feel pretty dumb, now I'm stuck at step 2 of 43 :|
    Yareyous - crwdns2934203:0crwdne2934203:0
    The screw bit that came with my fix kit just stripped the screws of my steam deck. I guess I should've just sent it in...
    Randy Jackson - crwdns2934203:0crwdne2934203:0
    Model 1030 SteamDeck uses Torque #6 (CR-V T6) 5.0mm for all 8 screws making it far less likely to damage the screw heads.
    seaniepie - crwdns2934203:0crwdne2934203:0
    Model 1030 is the OLED version, which we have separate guides for! See here: Steam Deck OLED
    Carsten Frauenheim -
    the steamdeck that I purchased in April 2025 no longer uses phillips for the rear panel screws, but instead uses a Torx T6H driver
    Kevin James - crwdns2934203:0crwdne2934203:0
    Do you have an LCD or OLED model?
  3. Steam Deck Left Button Board Replacement, Unclip the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Unclip the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    I found it easiest to start this process at the top of the device near the fan exit.
    Peter Lindberg - crwdns2934203:0crwdne2934203:0
    second that and inserting the pick in the bottom middle and sliding the pick to each side
    Sub -
    I also found the top near the fan exit to be easier
    Travis Patton -
    Thank you for this tip, it definitely was easy starting at the top instead of by the bumper/triggers. After I opened the top I did the bottom and then it was way easier to gently open the sides. be very careful and go slowly to make sure that none of the clips are damaged
    Luis B -
    this as suggested above:
    1. open the top
    2. open the bottom
    3.gently open the sides
    austrasier -
    same; i pried from the top of the screen area. I was unable to find an opening on the side
    Dennis Wu - crwdns2934203:0crwdne2934203:0
    I also started from the middle of the deck and worked my way out since I couldn't get a grip with the pick on the deck's side grips. Since this is a common step for pretty much all guides for opening the deck I think it's also worth noting that you should be careful not to bend the trims/seams where the front and back covers meet with the pick. When I first opened my deck you can definitely see where I nudged the pick in between the covers since I was probably using too much force on the pick itself.
    Kaleb McKone - crwdns2934203:0crwdne2934203:0
    It would be useful to note here that if you want to insert the little blue triangular iFixit opening picks into the right side along the edge, there isn't actually a gap as the directions say, at least not on newer Decks. You'll be making the initial gap using the pick. Brace it on something because you will need to use enough downward force that you're flexing the pick a bit and it'll probably be digging into the skin of a bare hand. With enough force suddenly it will make a click and go in just a bit, and then you're in business.
    CaptFrost - crwdns2934203:0crwdne2934203:0
    plastic picks didnt work for me but finger males did the job on prying this open
    jacobbagsic - crwdns2934203:0crwdne2934203:0
    I found it easiest to open starting with R1 or L1 buttons and proceeding to the center of the top edge
    Karol Gro - crwdns2934203:0crwdne2934203:0
    This step was the hardest by far. First I didn't find an opening at the sides, and it did take a really long time until I finally got it open... Then, when I had the one side opening open it didn't just pop out, I needed to slide all the way to the other side with the pick and open everything. I guess they made it even more drop resistant.
    Dollique - crwdns2934203:0crwdne2934203:0
  4. Steam Deck Left Button Board Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    If you have an SD card, you will want to take it out. I followed the guide and didn't think about the SD card I had inside. When I went to snap the case back on it clapped shut on the exposed SD card, shearing it in half and leaving the bottom half stuck in the SD card slot. I am still endeavoring to get it out.
    Novice - crwdns2934203:0crwdne2934203:0
    you can use the case that comes with the steam deck to support it once the lid is removed
    Luis Barbosa (Armored Saint) - crwdns2934203:0crwdne2934203:0
    You can get the pry pick inserted easier if you start in the gap for the shoulder buttons. A lego brick separator works well here
    Andrew Borsje - crwdns2934203:0crwdne2934203:0
  5. Steam Deck Left Button Board Replacement, Uncover the hidden shield screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Uncover the hidden shield screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    Use some heat here from a hairdryer to make this part easier.
    If you screw up here you can replace the little aluminium square with some aluminium tape from Amazon. No less than 50 microns thick, slightly thicker is fine. and the square is 13mm both ways.
    Matt S - crwdns2934203:0crwdne2934203:0
    Thanks for that Matt, i destroyed the original tape and i had no solution since i read your comment.
    Cihan Kocaman -
    there are other new version of board shield from 2023.
    Gorf Woo - crwdns2934203:0crwdne2934203:0
    Is it alright to use the deck without the tape?
    Jake - crwdns2934203:0crwdne2934203:0
    You should not. This is EM shielding to protect your processor and ram from radio waves in the air
    Andrew Borsje -
    I found out my 3 Weeks new Steam Deck is a old Version... gg. Valve...
    Miller Schiffer - crwdns2934203:0crwdne2934203:0
    wenn ich aluminium foile benutze, womit soll ich sie dann verkleben?
    Christian Dud - crwdns2934203:0crwdne2934203:0
    If we have the new version with the black shield, how do we access the SSD?
    James Bennett - crwdns2934203:0crwdne2934203:0
    I need this part, does anyone know where to get it?
    rolando norica - crwdns2934203:0crwdne2934203:0
    PSA: The only purpose of steps 5–8 is to enable you to disconnect the battery, which is not essential. I skipped steps 5–8 and did not have any trouble with the repair.
    David H - crwdns2934203:0crwdne2934203:0
  6. Steam Deck Left Button Board Replacement, Remove the shield screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the shield screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    The procedure ended here for me, used an ifixit PH 00 bit on the screw behind the aluminium tape, bit wouldnt bite too great, one wrong twist and the screw was stripped. Not sure who or what initially screwed in that particular screw as the rest of the screws on the shield were fine, but boy is it in there tight. So now i have a stripped screw and a botched ssd replacement, don't think valve will let me RMA for this, but i'll give it a try and update accordingly.
    Y. van S - crwdns2934203:0crwdne2934203:0
    Any updates? Did they let you RMA?
    Emanuel Gjoni -
    I found one screw to be ridiculously tight too, managed to undo it without stripping thanks to reading your comment beforehand and going extra careful. Not going to lie, it was a tense moment :D
    Andy HL -
    I'm stuck in the same place. I haven't fully stripped it, but I can tell you that if I try and make it budge it will strip. The thing is massively overtightened. The driver fit fine, the metal just gives way before the screw will budge.
    Robert Boswell Johnson -
    I think the tendency is to go too small on the screwdriver bits because you're working on small electronics.
    I used the PH1 bit on the screw under the foil and the PH0 bit for the two remaining screws without any problems.
    What does this shield actually do? Some kind of magnetic protection?
    Corey Cleric - crwdns2934203:0crwdne2934203:0
    if I had to replace the key (R2) and that's it, can I directly remove it or do I have to act here on the motherboard too?
    pujattidanny - crwdns2934203:0crwdne2934203:0
    have you gotten an answer yet? trying to change mines as well but dont wanna do too much to the deck
    briaNN -
    I used the ifixit tools and used the 00 PH for these screws with no issue
    If only swapping the SSD, it is not necessary to remove the top left 3.7mm screw. The heat shield is flexible enough that you can move it out of the way to access the SSD screw. For me this was necessary as the 3.7mm screw was completely unmovable and quickly stripped.
    Scott A - crwdns2934203:0crwdne2934203:0
    FYI there is a little pin on the cover that slots into the board. It is located near the top screw. I needed that to be inserted for the cover to go back down properly.
    Seth Robinson - crwdns2934203:0crwdne2934203:0
    For anyone who may have stripped a 3.7mm screw, Steam Support states it's M1.6 diameter with a 0.35 thread pitch and a 3mm length. Hopefully that'll help anyone trying to locate a replacement screw. Hoping iFixIt can make an internal screws kit as they're kinda hard to find the right one online.
    Michael Dyer - crwdns2934203:0crwdne2934203:0
    Did valve change the shield recently as my new 64gb deck has a black shield with no hidden screw.
    David Alexander Hubbard - crwdns2934203:0crwdne2934203:0
    Yes there's a new hardware revision out there that some people are getting. Consider stopping at this point and putting your deck back together if you have one of these new hardware revisions (the fan is quite different as well to the pictures) until iFixit has an updated repair guide.
    Simon M. -
    There are only 2 screws now, but be careful taking the shield off, because there are still thermal pads under it sticking it to a heat pipe.
    Rudolfs Skurulis -
    Are they m2 3.7mm screws? I am looking to replace mine because they instantly stripped and I had to remove them with needle nose pliers because they were over tightened.
    Nick - crwdns2934203:0crwdne2934203:0
    I need this piece, can someone help me where can I find it please?
    Hi, is it possible to buy these shields somewhere? I am extremely interested in buying a replacement.
    Yannick B. - crwdns2934203:0crwdne2934203:0
    The refreshed model 1030 has 2 T6 torx screws instead of Philips
  7. Steam Deck Left Button Board Replacement, Remove the shield: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the shield: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the shield: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    When putting back on, run a pick along the edge of the shield between the wires to make sure nothing is pinching and the wires are clear of the shield before screwing down.
    Are you saying that the fan cable should be positioned above the board shield instead of being pressed down by it? Just like the image shows, where it 'lays on the side of the board shield'?
    Necesito esta pieza la mía no la traía se ve que se la quitaro
  8. Steam Deck Left Button Board Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    After fully reassembling my device I found that my battery was not showing any stats anymore. I couldn't start the device without being plugged in, however if I restarted it would stay on even if my power cable was detached. Battery showed 0%. It turns out I had not fully reinserted the battery cable at this stage during reassembly. MAKE SURE YOU PUSH IT ALL THE WAY BACK IN!
    Michael Hoffmann - crwdns2934203:0crwdne2934203:0
    Awesome thanks for this tip!
    petergeranio -
    It is helpful to lift up gently with a the tapered end of a spudger underneath the tucked-in portion of the battery cable, creating a bit of flex in the cable before pulling on the pull tab. I found that without doing so, the fabric pull-tab simply tore off of the cable under light-to-moderate force (the fabric itself ripped cleanly across, like a paper towel). Careful, gentle pressure with a spudger can be used to remove the plug by prying gently on the rear ridge of the plastic plug (not the wire!) if this happens.
    Gene Eckser - crwdns2934203:0crwdne2934203:0
    This is exactly what happened to me. Maybe it was a pull tab previously, mine was a ribbon cable that tore - captured the image here: https://www.ianwootten.co.uk/2022/11/22/...
    Ian Wootten -
    This was the best approach (and I feel safest for the wiring) for me. Mostly push pressure on the plastic ridge with some minor pull tension on the fabric.
    Victor -
    I found it less scary and easier to remove the battery connection by using a fingernail on the ridge and pushing it off the connector. I felt like pulling on the battery cable was too harsh.
    montgomery mchargue - crwdns2934203:0crwdne2934203:0
    Yeah, pulling cables like these is usually ill advice. They might be fine if it's a new device, but for old devices that have been sitting there for years, there's a good chance the connector has grown brittle and the cable might just come off separately (something I learnt the hard way).
    skzm -
    I second this approach. For me, the cable felt way to flimsy and the connector wouldn't budge even under moderate force. Except I used the flat end of a spudger to "scrape" it out.
    Misza -
    Upon plugging the battery back in, I found it easy to use two spudgers- one on each side- to pull/push the connector back into it's port. Be careful to not put any pressure on the battery wires themselves.
    When reconnecting the battery cable, you'll know when it's inserted and power is restored, because the white LED will illuminate at the top of the Deck near the power button. You should be able to see it while you're reconnecting the battery cable
    Michael Davis - crwdns2934203:0crwdne2934203:0
    This is only true if you haven't put the deck into battery storage mode as directed.
    Ean Manley -
    Why not just let the battery discharge completely and then not have to disconnect it?
    Jeffrey Martin - crwdns2934203:0crwdne2934203:0
    Completely discharging a battery reduces its lifespan. It's completely unnecessary.
    Stefan Camporese (CENTER) -
    Because no lipo battery is ever completely discharged -- you would not be able to recharge it if it was. There will always be enough power left in it to cause damage if shorted even if it isn't charged enough to power up the device it's connected to.
    David Cameron -
    I would personally not recommend pulling the tab. It doesn’t apply force at the correct angle. You should revise these instructions to advise using a combination of pulling on the tab, and careful pressure on the connector towards the right of the mainboard to carefully work it out.
    Using the pull tab alone could cause problems if not done extremely carefully.
    William Winborne - crwdns2934203:0crwdne2934203:0
    This part was wayyyyy easier than I anticipated and I worried for nothing because I used the ifixit spudger to push it out a bit and then I literally used my finger nail and was able to slide it right off. Dont be afraid, its not that difficult and its not that delicate to break if you do it patiently
    I inserted the cable very firmly with a spunger, being careful not to press down too hard on the cables, and even tried redoing it, but I don't see any LED illumination. I am now unable to boot the deck into the boot manager. Any additional tips?
    junefish - crwdns2934203:0crwdne2934203:0
    What is the risk of not unplugging the battery? Just curious!
    Nick Hight - crwdns2934203:0crwdne2934203:0
    Once I was changing termal paste on my Windows based expensive tablet PC... And I was so scared to disconnect any cables (there was many of them), so I did it all with battery connected (I didn't even knew where is battery cable). When I tried to put board shield back... it didn't go right into needed place... and short circuit some small component. It flashed. That was the end of my repair. Dudies from repair service later told me that multiple components fried including CPU, so repairing is too hard. That's what can happen if you don't disconnect battery.
    bugwarlabs -
    To pull the battery out I used my spunger, but the batter had actually not space to be pulled out completely. I needed to lift the cable up with the spunger to get the cable fully out. When plugging it in again I had to press the battery down kinda hard so it would fit again. This was really scary and I recommand using two spunger as someone said above.
    Does it have to be a clean fingernail?
    Steven Murphy - crwdns2934203:0crwdne2934203:0
    I disagree with the order here: I think the battery should be disconnected right after step 4. You can do that before touching anything else by gently pulling the pull tab to the right.
    If all you want to do is to disconnect and reconnect your battery (because your Steam Deck is not booting up... again...) then with a bit of finesse, luck and a flat plastic tool you can even push it back in without removing the shield. Make sure it went all the way back in.
    Fozi - crwdns2934203:0crwdne2934203:0
    Be very careful with this tab, it rips easily!
    Tom Sid - crwdns2934203:0crwdne2934203:0
  9. Steam Deck Left Button Board Replacement, Unclip the left trigger: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Unclip the left trigger: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The left trigger will be on your right-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    This step is taking me a while to get the trigger out.
    I solved this by pushing the trigger to the left while inserting the spudger.
    Twist the spudger, it will take some force.
    The trigger and spring will fly out.
    Tom Sid -
    Yeah, the trigger takes a bit and is a little tricky to get out. Eventually got it though
    Kane -
  10. Steam Deck Left Button Board Replacement, Remove the left trigger: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the left trigger: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    In case the spring gets lost, it's 19 mm long with about 14 coils.
    Claudiu Avram - crwdns2934203:0crwdne2934203:0
    Omg thank you
    Jill Flanagan -
  11. Steam Deck Left Button Board Replacement, Remove the trigger bracket screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
  12. Steam Deck Left Button Board Replacement, Remove the trigger bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    If I only need to get to this part to check if I have to change the button or the daughterboard, do I HAVE to disconnect the battery ? The less I fiddle with things the more likely it is that I won’t break anything else…
    Monsieur_Croco - crwdns2934203:0crwdne2934203:0
  13. Steam Deck Left Button Board Replacement, Disconnect the left thumbstick: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the left thumbstick: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the left thumbstick: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    My tweezers keep slipping off, this pull tab has poor grip.
    I ended up just using my fingernails and it worked.
    Tom Sid -
  14. Steam Deck Left Button Board Replacement, Remove the thumbstick screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the thumbstick screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  15. Steam Deck Left Button Board Replacement, Remove the left thumbstick: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the left thumbstick: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left thumbstick.
  16. Steam Deck Left Button Board Replacement, Disconnect the interconnect cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the interconnect cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the interconnect cable: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    Interconnect cable is along bottom of left board (on your right hand side). Ought to put a picture of where it is for easier reference.
    David Boers - crwdns2934203:0crwdne2934203:0
  17. Steam Deck Left Button Board Replacement, Disconnect the remaining button board cables: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the remaining button board cables: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the remaining button board cables: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the D-pad cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
  18. Steam Deck Left Button Board Replacement, Disconnect the left haptics: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the left haptics: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Steam Deck Left Button Board Replacement, Disconnect the left haptics: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    Any advice on resoldering a disconnected haptics connector housing?
    Will Rarich - crwdns2934203:0crwdne2934203:0
    If you dont accidently launch the housing some where you cant find it
    Jimbo -
    Der Stecker steckte fester im Gehäuse als das Gehäuse auf der Platine... Eine Idee, wie das in Ordnung gebracht werden kann?
    Mariano Mertinat - crwdns2934203:0crwdne2934203:0
    Broke the housing in half, still usable though. This was while only prying the connector, which stretched the housing too much. I highly recommend the flipping over the edge alternative :)
    Radu Bonea - crwdns2934203:0crwdne2934203:0
  19. Steam Deck Left Button Board Replacement, Remove the button board screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to disconnect the four screws securing the left button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    during reassembly you will need to remember to line up board with 2 plastic mounts. pcb has good flex and can push down top to get top screw to line up flush
    B P - crwdns2934203:0crwdne2934203:0
    also the 2nd cable from the top (the one below shoulder button cable) should be pulled free before tightening your screws lol
  20. Steam Deck Left Button Board Replacement, Remove the button board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Steam Deck Left Button Board Replacement, Remove the button board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left button board.
    • Keep track of the Steam button and its membrane, as once the left button board is removed, they're no longer secured in place.
    This is useful, but how do I get a Left Button Board? Mine is damaged in the left bumper button micro switch and I need a replacement.
    KaizerJV - crwdns2934203:0crwdne2934203:0
    i thought i needed to replace L1 but i need to replace daughter board too. Valve has said they will supply left daughter boards they are just sold out rn
    B P -
    Same, i replaced the assembly for nothing, its the board that needs to be replaced, since i cant solder at all and its the blue button that is faulty
    rubenalexandredinisaraujo -
    I need this board to fix my deck
    Avery Jones - crwdns2934203:0crwdne2934203:0
    que precio tiene esta pieza, se daño la de mi steam deck
    jose cortes - crwdns2934203:0crwdne2934203:0
    when will the button board be for sale?
    Brett Archey - crwdns2934203:0crwdne2934203:0
    L4 button not worked. When will the button board be for sale?
    Racoon Family - crwdns2934203:0crwdne2934203:0
    Will a button board be available for purchase soon?
    Sean Gillum - crwdns2934203:0crwdne2934203:0
    Please provide daughter board, l1 button stopped working. Pads lifted off the board.
    Alistair Pullen - crwdns2934203:0crwdne2934203:0
    Please sell a button board. L1 button stopped working. Seems to be a common issue.
    Jimmy - crwdns2934203:0crwdne2934203:0
    Ernesto Bauer Maza - crwdns2934203:0crwdne2934203:0
    Guys, I have the same problem as everyone else. The STEAM button stopped working almost immediately after purchase, Steam actually refused the warranty - they offered me to bring the console myself to the other side of the world, although they could have simply sent a replacement part or a new one. You can’t buy spare parts anywhere - they simply weren’t made “in reserve.” As a result, I have a dead, useless console for a lot of money. No trust in Valve now. I'm thinking of filing a class action lawsuit against the company. Maybe we can get together? I'm @paaladin on social networks and Steam.
    Pavel Semenov - crwdns2934203:0crwdne2934203:0
    Where can I buy this board? If this board isn't available, what else could I do to fix the L1 button switch?
    Amanda Huggett - crwdns2934203:0crwdne2934203:0
    Same issue happened to me soon after purchasing Street Fighter 6. Once you continue pressing these triggers excessively, they eventually bend down where as the trigger can't activate the Micro Switch any more. Luckily I purchased my Deck New, directly from Valve and not used. So in my case they had no shipping me a New unit immediately after receiving my faulty Deck. So what I did to remedy this issue was purchase a Victrix Pro FS Arcade stick just to play my favorite fighting game Street Fighter 6 on the deck and PC. These triggers definitely don't hold up to constant presses + pressure. I do feel bad for those that find themselves in this situation but purchase there deck used with no form of warranty.
    David - crwdns2934203:0crwdne2934203:0
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Carsten Frauenheim
145,323 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,467crwdne2935297:0
crwdns2947412:052crwdne2947412:0
Is the button board available for purchase, or planned to be available for purchase? My steam deck took a tumble and busted the left bumper button that the bumper presses.
boop pert - crwdns2934203:0crwdne2934203:0
I know it's been a while, hope you've already fix it. I fixed the micro switch myself recently, see my comment: Steam Deck Left Button Board Replacement
Shane Qi -
I also have the same problem as boop pert.
I'd like to know if the board with be available as the Left Bumper is non functional now and needs to be replaced entirely.
Aaron Latta - crwdns2934203:0crwdne2934203:0
I know it's been a while, hope you've already fix it. I fixed the micro switch myself recently, see my comment, hope it helps: Steam Deck Left Button Board Replacement
Shane Qi -
Got the same problem, my steam deck fall and broke the L1 internal button , and as i see is attached to the left button board. Is there any ETA to have this part available ? Thanks !
Gio - crwdns2934203:0crwdne2934203:0
Is there anything i can do if my problem comes from Left Button Motherboard ? Is there any replacement for Left Button Motherboard ? Any news about that ?
Gio -
Shane Qi -
I have my L1 button not responding anymore. After checking, I could see that it comes from the board itself. I have the same question that above me.
Will this board be available for purchase soon? If not, do you think that valve will still replace it if I send to the after sales service? Thanks
Tarek Elmeskine - crwdns2934203:0crwdne2934203:0
FYI I fixed the micro switch myself recently, see my comment: Steam Deck Left Button Board Replacement
Shane Qi -
I ordered a replacement Left Bumper button because I thought that was the issue, but it turns out it was the left button board, sadly. I have figured out a temporary fix, but I rather replace the board myself than do another 1 month RMA. I would like to echo the question about having this available to order.
Rex Downham - crwdns2934203:0crwdne2934203:0
If you are willing to do some soldering, see my comment, I fixed the micro switch myself recently:
Shane Qi -
咕哒子 - crwdns2934203:0crwdne2934203:0
Also would like to get a replaced board as my L1 is broken without the device falling down. It was like this out of the case.
I’ll open up the deck today and check what really happened.
Too bad that this happens too often.
I will do that my self.
Jason McLaine - crwdns2934203:0crwdne2934203:0
My L1 button is not working because of the Left Button Board and I can't find any online. I figured I could use L4 instead of L1 in games as a temporarily solution, but I would really like to be able to buy a Left Button Board for replacement instead of waiting for RMA.
If you are up to fixing it yourself, see my comment, I fixed the micro switch myself recently:
Shane Qi -
Please make this part available to buy
Isaac Ah-Loe - crwdns2934203:0crwdne2934203:0
Still waiting to be able to buy this board as I am not experienced in repairing the connection with the switch to the board
Dominic Santangelo - crwdns2934203:0crwdne2934203:0
dropped my steam deck, and the dpad is seemingly damaged, every input but up on the dpad works,
and while steam support is willing to repair it, i would rather fix it myself so i wouldnt need to wait for it to get back to me.
valve, if your reading this, PLEASE LET US PURCHASE REPLACEMENT BOARDS!!!
-Lily Burks
Lily Burks (LilyTheFox) - crwdns2934203:0crwdne2934203:0
The board for the dpad is actually located on on the left bumper's assembly which ifixit does have for sale (which is funny considering that the button for the bumper is on the button board). Though before you buy anything double check if the select button works as that is on the same board as the dpad. If that also doesn't work then you may just need to reinsert the ribbon cable.
Michael O'Connor -
This guide is nonsense since you can't buy button boards. Steam Deck's rubbish.
Giulia - crwdns2934203:0crwdne2934203:0
ive been waiting months for the button board to be available for purchase, they said a repair would cost 130€ and i dont have that much money, i'd rather replace it myself anyways. please let us buy button boards
Ollum - crwdns2934203:0crwdne2934203:0
Installing these boards in the Steam Deck requires special calibration that isn't currently publicly available. As of right now we don't know if/when these could be available for purchase.
Carsten Frauenheim - crwdns2934203:0crwdne2934203:0
Hi Robert! Do you have an update for us? Did these internal switch for the Nintendo worked on the button board of the Steam Deck?
Art Oca -
I ordered them and I will solder one in and report back
Robert Manners - crwdns2934203:0crwdne2934203:0
Curious if you ended up going through with this. Mine isn't broken, just very spongy. I think the button solder point is bent.
This is such a tremendously fragile part. It's one of the most likely areas to actually take an impact if the Deck falls, and that force is absorbed by a solder joint on a tiny button.
They are going to have to make these daughter boards available by some means, because they are going to break.
Josh -
I've asked Steam support if it's possible to get the parts for this guide. I really don't want to have to send my device back. I just got it set up with my Non-Steam games, and it would be way quicker to perform this guide.
Neil Sutcliffe - crwdns2934203:0crwdne2934203:0
i've actually had this convo with them last night... was told they arnt for sale and offered to RMA it to a repair center. im 50\50 on doing it. for the time being i have the left bumper button mapped to one of the rear paddles and works just fine. i really dont want to wait the 2 weeks for something simple we can do ourselves
Albert Henderdon -
will the left sister board be available soon? sure would like a working left bumper button again..
Albert Henderdon - crwdns2934203:0crwdne2934203:0
Just so others are aware, I haven't seen the Left button board or the Right button board available for purchase from Ifixit just yet. I just took apart my deck having ordered a left bumper replacement set thinking this would fix my issue, it will not. The issue is the switch itself that is attached to the Left Button Board
Antonio Cruz - crwdns2934203:0crwdne2934203:0
i ordered these from amazon. they work for the deck but requires precise soldering as the solder joints are small. its doable. i was going to fix it but the original button tore off the center contact pad on the board.. RIP.
i may play the waiting game untill its available for purchase
Albert Henderdon -
Oh well, I suppose I could do the same but I don't have soldering tool. I'm already going to bite the bullet on getting Valve's Support involved for a RMA process to get started, I already replied to them via the ticket I created for this issue a few minutes ago.
It's not great that still these parts aren't available to the public, I don't understand why that is. Perhaps Valve is using those resources to make more Steam Decks. I really hope the new unit they send, or the fixed one I currently have, doesn't have this issue so soon again
Antonio Cruz -
Installing these boards in the Steam Deck requires special calibration that isn't currently publicly available. As of right now we don't know if/when these boards could be available for purchase.
If you are here because the L1/R1 micro switch is broken, you can replace just the micro switch. I've done it recently:
1. the micro switch I used was the sync/pair button of the Xbox controller, and it works just fine (iFixit sells the Xbox controller motherboard for $15 each)
2. later, I found the micro switch's model number: "TL3340AF160QG" (<$1 each)
3. I used a soldering iron to install it. It's not easy, but DIY-able. I have very little soldering experience, and I fixed it myself.
4. If you use hot air, don't blow directly on the plastic part of the micro switch because it could easily melt.
Here is the thread where I documented this project: https://mastodon.social/@shaneqi/1100088...
Shane Qi - crwdns2934203:0crwdne2934203:0
Giving this a try. Micro switch is $0.54 each on DigiKey, so I got a few extra to practice with. Never soldered something so small.
Chris Beidelman -
Please, make these parts available for us to buy. I had the same issue as many have said here before. It will be quicker to just replace the full board. I live in Mexico and will be more difficult to me to send it to USA to send it to their repair shops.
cesarm4d - crwdns2934203:0crwdne2934203:0
I wish the right board was available to the public. I live in Greece and sending it to Valve would take a lot of time. I can't find any clickers that ship to Greece from a reliable website either... Such an easy fix but no parts.
dimitris - crwdns2934203:0crwdne2934203:0
vende el tablero de botones izquierdo, o donde se podria adquirir
mi correo es nilo@hotmail.com por si pueden enviarme una respuesta
nilo2198 - crwdns2934203:0crwdne2934203:0
Still unavailable, my Deck fell 2 feet while in its case this morning and now the button is broken. Very frustrating that a replacement part for something so susceptible isn't being sold, we shouldn't have to ship the Deck away when I can replace the part myself if I could just buy it.
Being told by Steam support that they don't allow user repairs (I asked if they'd be willing to ship the part to me) because it's dangerous rings hollow when I safely took it apart to even find out what was wrong.
Norah Morris - crwdns2934203:0crwdne2934203:0
hi. I would like buy the. Steam Deck Left Button Board Replacement R side
julio. cuello - crwdns2934203:0crwdne2934203:0
Valve should provide the board and the software already for us to repair the most fragile button on the deck.
Andrés Sánchez Hevia - crwdns2934203:0crwdne2934203:0
this is rediculous that its not available by now.
Nolmirk - crwdns2934203:0crwdne2934203:0
can we get a yes/no on if this particular piece of hardware will ever be available?
MR BDB - crwdns2934203:0crwdne2934203:0
MR BDB,
Unfortunately, the Steam Deck button boards require Valve's special calibration software that still isn't publicly available. We still don't know if/when the boards could be available for purchase.
When is the buttons board going to be available for the Oled version?
felipe alarcon - crwdns2934203:0crwdne2934203:0
felipe,
The Steam Deck OLED button boards still require Valve's special calibration software that still isn't publicly available. We still don't know if/when the boards could be available for purchase.
Evan Gattuso -
Hi,
The transistor on the left daughterboard is missing. I would like to buy a new transistor and solder it myself. Could you please provide me with the specifications of the transistor or give me a link to purchase one? The L2 button is not working because of it.
See the blue arrows in the attachment: https://imgur.com/a/lfLIQbR
Kristiyan Petrov - crwdns2934203:0crwdne2934203:0
This is a joke seeing as you don't even sell the button board replacements (and haven't for 2 years).
Florido - crwdns2934203:0crwdne2934203:0
Salve vedo la guida ma non l'acquisto non c'è sul sito?
Salvatore Nullo - crwdns2934203:0crwdne2934203:0
Still not board to actually even buy. Wtf Valve?
Mikey D - crwdns2934203:0crwdne2934203:0
Do you sell left daughterboards for SD OLED yet? I had a little water get into my "STEAM" button that causes the system to think it is constantly being held down. Makes the whole system inoperable off one issue.
Sam G - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 35
crwdns2936753:07crwdne2936753:0 192
crwdns2936753:030crwdne2936753:0 814
crwdns2942667:0crwdne2942667:0 30,424
