Sony WF-1000XM3 Case Battery Replacement
  1. Sony WF-1000XM3 Case Battery Replacement, Case Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement, Case Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement, Case Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use plastic opening picks to release the locking mechanism that secures the plastic shell of the charging case to its internal components.
    • Use a spudger to release the final lock and slide out the internal components of the charging case.
  2. Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of each connector to "walk" it out of its socket.
    • Do not pull on the cables as they may come loose.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
  3. Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to carefully remove the battery from the double-sided tape securing it in place, then remove it from the battery compartment.
  4. Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two metal 3 mm screws from the motherboard using a Phillips #000 screwdriver.
    • Remove the motherboard and battery assembly from the battery case
  5. Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony WF-1000XM3 Case Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the red and black wires that connect the battery to the motherboard.
    • Solder the wires from the replacement battery into the circuit board following the same configuration.
    • Position the battery so that the raised section faces inward, allowing the case to fully seal.
    • Do not let ends of the wires of either battery touch, as they may spark and cause a fire.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
WyattC
crwdns2935283:010/24/24crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 3-6, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S3G6
what kind of battery is in the case?
Bóas Kár Ketilsson - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 82
crwdns2936753:030crwdne2936753:0 507
crwdns2942667:0crwdne2942667:0 1,605
