Sony SRS-XG300 Tweeter Replacement
  1. Sony SRS-XG300 Tweeter Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before beginning, make sure to unplug and power off your speaker.
    • With the Sony label on the left, roll the speaker horizontally to the bottom of the speaker with the rubber stands.
    • Remove four 12 mm screws with a Phillips #1 screwdriver.
    • Remove the loose rubber feet.
  2. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the metal spudger tool at 90-degree angle into the right part of seam.
    • Pry off the top part of the fabric cover using the metal spudger.
    • Follow the seam to completely detach the top part of the fabric cover.
    • Repeat to remove the bottom part of the fabric cover.
  3. Sony SRS-XG300 Tweeter Replacement, Tweeter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip all six trapezoid-shaped notches around the rim of the speaker using the metal spudger.
    • Begin at the end of the speaker volume button board for an easier process.
    • You may have to work clips off, pushing away from the speaker simultaneously.
    • Remove the speaker mounting ring.
    • Repeat the same steps on the other end of the speaker with the power button board.
  4. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 12 mm screws on the corners of each tweeter using the Phillips #1 screwdriver.
    • The tweeters are smaller compared to the two woofers in the center of the speaker.
  5. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the right tweeter up to expose the connected cables at the top and bottom of the right tweeter.
    • Pinch down on the metal tab and pull outward to disconnect each cable.
    • Pieces are malleable, so you may have to maneuver to disconnect.
    • Lift the right tweeter up and out of the case.
  6. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 12 mm screws on the rim of the radiator using the Phillips #1 screwdriver.
    • Uncap the left bass radiator. Detach the blue ribbon cable from the bass radiator.
    • Using the angled tweezers will make this process easier.
    • Remove the left bass radiator.
  7. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the microphone by pulling on the white end of the microphone cable.
  8. Sony SRS-XG300 Tweeter Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Tweeter Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the left tweeter up to expose the connected cables at the top and bottom of the left tweeter.
    • Lift the left tweeter up and out of the case.
Melody
crwdns2935283:002/19/25crwdne2935283:0
448 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 7-3, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 7-3, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S7G3
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 124
