Sony SRS-XG300 Button Board Replacement
  1. Sony SRS-XG300 Button Board Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Button Board Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Button Board Replacement, Fabric Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before beginning, make sure to unplug and power off your speaker.
    • With the Sony label on the left, roll the speaker horizontally to the bottom of the speaker with the rubber stands.
    • Remove four 12 mm screws with a Phillips #1 screwdriver.
    • Remove the loose rubber feet.
  2. Sony SRS-XG300 Button Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Button Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the metal spudger tool at 90-degree angle into the right part of seam.
    • Pry off the top part of the fabric cover using the metal spudger.
    • Follow the seam to completely detach the top part of the fabric cover.
    • Repeat to remove the bottom part of the fabric cover.
  3. Sony SRS-XG300 Button Board Replacement, Button Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Button Board Replacement, Button Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 12 mm screws on the corners of the right tweeter using the Phillips #1 screwdriver.
  4. Sony SRS-XG300 Button Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Button Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XG300 Button Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the metal spudger to peel off the adhesive button (volume, play/pause button) to access the control panel underneath.
  5. Sony SRS-XG300 Button Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Button Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 7.5 mm screw in the middle of the control panel using the Phillips #1 screwdriver.
  6. Sony SRS-XG300 Button Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XG300 Button Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to carefully lift up the control panel.
    • Make sure to do this slowly and not lift it all the way up, as it can tear the cables.
    • Detach the blue ribbon cable from the button board.
    • If not visible, lift the right tweeter to see a better view of the cable internally.
    • Remove the button board from the speaker.
Emilie Wheeler
crwdns2935283:002/20/25crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 7-3, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 7-3, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S7G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 117
