Sony Pulse Elite Edition Battery Replacement
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Battery Replacement, Remove Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
crwdns2935229:08crwdne2935229:0
Chris Echter
crwdns2935283:001/29/15crwdne2935283:0
865 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - crwdns2934203:0crwdne2934203:0
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - crwdns2934203:0crwdne2934203:0
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - crwdns2934203:0crwdne2934203:0
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - crwdns2934203:0crwdne2934203:0
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - crwdns2934203:0crwdne2934203:0
you didn’t show how to remove the inner ring that holds the battery in, looks very fragile and I don’t want to break it
brimest0ne - crwdns2934203:0crwdne2934203:0
brimest0ne, the inner ring is fastened down by the same three screws originally removed in step three! When you remove the inner ring, the bass volume adjustment side will give you a little resistance, just be gentle and it comes right off. That’s it, now replace the battery and start using the headset again! What I really want to know, has anyone done an upgrade will battery replacement and how much more time are you getting from the upgrade?
helliant1 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 11,902
