Sony Pulse Elite Edition Battery Replacement
crwdns2942287:0crwdne2942287:0When working with electrical components, be sure to avoid loose wires.
crwdns2944105:0crwdne2944105:0
Locate the left side designation on the headband-earpiece junction.
The battery is in the right earpiece.
The motherboard is in the left earpiece.
Gently pull around the perimeter of the left ear cushion until it comes off.
Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
Gently pull the outer ear rim off of the headset assembly.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently pry the red and black speaker wires from the attached socket.
Lift up battery and disconnect wires using tweezers.
Use a new battery for reconstruction.
crwdns2935229:08crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Where can I buy the replacement battery for this?
Pretty hard to find...
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
you didn’t show how to remove the inner ring that holds the battery in, looks very fragile and I don’t want to break it
brimest0ne, the inner ring is fastened down by the same three screws originally removed in step three! When you remove the inner ring, the bass volume adjustment side will give you a little resistance, just be gentle and it comes right off. That’s it, now replace the battery and start using the headset again! What I really want to know, has anyone done an upgrade will battery replacement and how much more time are you getting from the upgrade?
