Sony MDR-1000X Opening Procedure
  1. Sony MDR-1000X Opening Procedure, Pry up the ear cup cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MDR-1000X Opening Procedure, Pry up the ear cup cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ear cup cushions of the Sony MDR-1000X are held in place by small plastic clips.
    • Insert a spudger into the gap between the right ear cup cushion and the headphone frame.
    • Lever the spudger downwards to pry up the ear cup cushion.
    • You should hear a little clack noise when the plastic clips pop open.
    • During reassembly make sure all six plastic clips snap back into place.
  2. Sony MDR-1000X Opening Procedure, Remove the ear cup cushion: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony MDR-1000X Opening Procedure, Remove the ear cup cushion: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ear cup cushion.
  3. Sony MDR-1000X Opening Procedure, Remove the protective cloth: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MDR-1000X Opening Procedure, Remove the protective cloth: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MDR-1000X Opening Procedure, Remove the protective cloth: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The protective cloth in the inside of the ear cups is glued to small foam spacers. These foam spacers are glued to the headphone frame with small pieces of adhesive tape. During the following step make sure to remove the protective cloth including the foam spacers and not to rip the cloth off them.
    • Carefully remove the protective cloth in the inside of the ear cup including the foam spacers.
    You may not need to remove this foam, I was able to gently pull it back to access the screws. This way you dont need to worry about tearing the foam or compromising the double sided tape attachment.
    Cameron Fong - crwdns2934203:0crwdne2934203:0
  4. Sony MDR-1000X Opening Procedure, Unfasten the ear cup screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 8.3 mm-long Phillips #00 screws securing the ear cup cover.
  5. Sony MDR-1000X Opening Procedure, Pry up the ear cup cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony MDR-1000X Opening Procedure, Pry up the ear cup cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony MDR-1000X Opening Procedure, Pry up the ear cup cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ear cup cover is held in place by small plastic clips just like the ear cup cushions.
    • Insert a spudger into the gap between the ear cup cover and the headphone frame.
    • Lever down the spudger to pry up the ear cup cover and pop open the plastic clips.
    • Do not try to remove the ear cup cover all the way. It is still connected to the motherboard by a flex cable.
    • Carefully open the ear cup cover.
If it’s necessary apply new adhesive to the ear cup foam before reinstalling it.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
233,678 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,184crwdne2935297:0
My WH-1000xm2 battery started dying quickly (it would only last a few minutes after a charge) some time ago, so I decided to replace the battery. At the end I found that the new battery lasted longer (because it came fully charged) but after the first run out, it would not charge anymore. So the problem is likely on the charging board (even the phone red light does not turn on when connected to micro USB). When I looked close at the charging board, the ribbon cable was a bit melted, so I believe the problem is in it. What is the exact ribbon I have to purchase if I want to replace the one from the charging board?
geo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 3,230
