Sonos Roam Inner Circuit Board Replacement
  1. Sonos Roam Inner Circuit Board Replacement, End Caps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, End Caps: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, End Caps: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
    What about IP67 rating? Am I going to lose the water resistance rating if I do not reapply some glue or additional adhesive when reassembling things back?
    Askar - crwdns2934203:0crwdne2934203:0
  2. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Inner Circuit Board Replacement, Speaker Grille: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, Speaker Grille: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
    my sonos roam sl used t7 screws here
    Arndt Kurek - crwdns2934203:0crwdne2934203:0
  4. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device.
  5. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Inner Circuit Board Replacement, Speaker Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, Speaker Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
    A diagram of how the latch works would be helpful as well as the photo
    Neil Makaroff - crwdns2934203:0crwdne2934203:0
    When re-assembling, I used tweezers to put the ribbons in place. The ribbons have keys that stick out, and the ribbon must be far enough toward the latch for the ribbons' keys to be past the notches on the white-ish mount point. With the ribbon mostly flat, I closed the latch. Everything is working.
    Matt Burke - crwdns2934203:0crwdne2934203:0
  10. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
    is it necessary to desolder the board to replace the battery? it appears subsequent steps just push it to the side...
    Daniel Rodriguez - crwdns2934203:0crwdne2934203:0
    Same here, not sure if that is a necessary step to replace the battery
    I made the repair without soldering. Works without any problem
    Ze si - crwdns2934203:0crwdne2934203:0
    Same here. No need to desolder
  12. Sonos Roam Inner Circuit Board Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, Battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  13. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to firmly squeeze the middle of the plug.
    • Pull the plug out to remove it from its socket.
    • Remove the battery from the device.
  14. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to pry the battery out of its casing.
    • Use the iOpener, blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
    I used the iOpener plastic cards to shove between the battery and the case on both sides to break the adhesive.
  15. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from its casing.
    Step 11 is optional. There is no need to unsolder the circuit board to get the battery out, you can pry the cable off and move the board out of the way while it is still attached to the case.
    Kristoffer Rydquist - crwdns2934203:0crwdne2934203:0
    Agree with prior comment, did not unsolder wire and still completed successful battery change.
    FYI, my Sonos battery most probably failed as the charger was not sufficient power. This was not in any literature but Sonos help line stated minimum power needed.
    Paul Ukrainetz - crwdns2934203:0crwdne2934203:0
    I also agree that step 11 is unnecessary. No need to unsolder anything, just carefully flip the board out of the way. This lead is going to one of the antennas, so I would not want to deal with resoldering this micro-coax. Hardest part is dealing with all the adhesive.
    Matt Schirmacher - crwdns2934203:0crwdne2934203:0
    Bravo pour les explications très claires, précise et bien illustrées !! Il est vrai que dessouder le fil n'est pas nécessaire .. de si quelqu'un peut dire à SONOS qu'un petit interrupteur à pression serait bien utile pour un hard reset des enceintes plutot que de devoir démonter les batteries :-)
    Teran - crwdns2934203:0crwdne2934203:0
  16. Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR9 Torx screwdriver to remove the two 5 mm screws.
  17. Sonos Roam Inner Circuit Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sonos Roam Inner Circuit Board Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to firmly squeeze the center of the plug.
    • Grab the metal box to remove the inner circuit board.
Lauren Young
crwdns2935283:009/20/23crwdne2935283:0
719 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-2, McMurrin Fall 2023 crwdns2935289:0Utah Tech University, Team 1-2, McMurrin Fall 2023crwdne2935289:0
UTAHTECH-MCMURRIN-F23S1G2
crwdns2935297:013crwdne2935297:0
Danke für die Anleitung.
Ich müsste die Leiterplatte auch tauschen. Weiß jemand, wo es noch passenden Ersatz gibt?
Danyel Bürgel - crwdns2934203:0crwdne2934203:0
Vielleicht hier?
VauWeh -
Danke aber das hatte ich schon versucht. Bietet man nicht an. Ich kann den Fehler eingrenzen aber den Chip bekomme ich leider auch nirgends.
crwdns2942667:0crwdne2942667:0 505
