Shark ION Robot R75 Side Brush Motor Replacement
  1. Shark ION Robot R75 Side Brush Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
    Here, you have misused the reminder bullet. The note bullet would be better in this case; I would also say how to turn it off, rather than just to do it. Avoid locate steps, and instead, move straight to the information about what to do. Use markup on the images to indicate where the component is. Be careful about using “remove” without other information about how to remove it, especially if there are multiple ways to remove something.
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  2. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
    Make sure to review how to appropriately use special bullets. Make sure to check throughout to remove “locate” steps, and instead, just go straight to the action.
  3. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
    Here, you’re using tweezers, but you don’t indicate that in the guide steps. Instead of including the information in the special bullet, I would just integrate the tool into the actual procedure. Do you have pictures of you pushing the tab? Can they yank the wire, or do they need to pull gently? I would add a flipbook style action shot to make the procedure clearer in the pictures.
  4. Shark ION Robot R75 Side Brush Motor Replacement, Main Brush: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
    I would add markup and action shots here. Which cover? Make sure to specifically identify device components.
  5. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the main brush slightly to the right to remove it from the compartment.
    When will you know that you’ve pulled far enough to the right? When you say remove, do you need to lift the brush up? Do you have more action shots demonstrating this procedure?
    Right. Mine does not budge, and I don’t want to break the mounts.
    EiEiOh - crwdns2934203:0crwdne2934203:0
  6. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
    Be sure to check special bullets. Indicate how to remove the end cap.
  7. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
    The first step doesn’t seem necessary here. You can just include markup on the full shot to show the component you’re asking them to work on. Also, you don’t need to include cleaning/maintenance directions here, although you can include them in the introductions and/or the troubleshooting page.
  8. Shark ION Robot R75 Side Brush Motor Replacement, Drive Wheel Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
    Here, the device was already oriented this way, so the directions on the side sensor with using this prerequisite make the procedure confusing. Make sure to read through all guides to make sure you don’t have these kinds of continuity errors. Also, include the battery replacement as a prerequisite for all guides, and use the system to include the prerequisites, rather than putting this information in the note.
  9. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
    Be sure to include a markup shot showing the location of the five screws. Remove locate steps in all guides. Indicate how to remove the wheel assembly in the guide text. Use caution bullets for caution notes.
    What to do when the cable rips when taking wheel out?
    Samantha Mcilwain (Sam) - crwdns2934203:0crwdne2934203:0
  10. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
    Add markup. Remove all reassembly guide text. Indicate how to disconnect the cable, not just to do it.
  11. Shark ION Robot R75 Side Brush Motor Replacement, Shark ION Robot R75 Caster Wheel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device with the bottom facing up.
    This photo is not helpful. Is removing the whole assembly correct procedure, or could it break the device?
  12. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
    Note that you’re using a plastic opening tool, not a screwdriver. Be sure to appropriately identify tools. Proofread all guide text for clarity and end punctuation. For all remaining “remove” steps, if something can be done in multiple ways, then you need to indicate how. Remove is good for screws because there’s only one way to do that. For everything else, use more detail or a stronger verb.
  13. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
    Hi I have the same model but the screws are not on the outside and there is what appears to be like a ring like part that held the caster assembly in the slot I cant pop the assembly back in and nor does that white part come out can you please help me with that
    Hanisha Rush - crwdns2934203:0crwdne2934203:0
  14. Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push down on the black tab and remove the dust bin
    In the first image, the device looks significantly different for Step 13 to Step 14, then the device is flipped in the second and third images. Be careful about these kinds of continuity errors.
  15. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
    Use markup on images to show where components are. Past Step 15, here, I’m no longer marking this issue. Additionally, proofread all steps for end punctuation.
  16. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the robot is facing rearward
    • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
    • Pull the bottom part of the bump guard away from the body of the device.
    What does it mean to face the device rearward?
    Do you have pictures of you removing the bump guard?
  17. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
    • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
    • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
    What is the difference between the two black bullets? Also, the information bullet is not necessary here.
  18. Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
    • Slide the sensor out from the base of the robot
    Do you have pictures of the third bullet?
  19. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
  20. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white connector from the sensor.
    Where is this component coming from?
  21. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the screw on the sensor.
    • Remove the sensor from its mount.
    Do you have a picture of you separating the components? Also, make sure to write directions as commands.
    where can I buy the sensor
    Karina - crwdns2934203:0crwdne2934203:0
    And thats why i bought this robot because i don't have a man, funny i paid $300 after one year i have to work on it?? I have different Shark products and this is the first im not happy with Shark.
    Masoume A - crwdns2934203:0crwdne2934203:0
    Yes, I agree. We have only had it less than a year and we are having problems with it already. What a joke.
    Kelly - crwdns2934203:0crwdne2934203:0
    Less than year and I’m
    Having this issue as well very disappointing. It doesn’t say where to get the sensor .
    Sandi - crwdns2934203:0crwdne2934203:0
  22. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that both the left and right side sensors have been removed from their compartments.
    • Using a Phillips #0 screwdriver, remove the two screws on either side of the motherboard.
  23. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingers in the groove right above the bump sensor.
    • Carefully lift the motherboard and plastic assembly up to expose the motors and charging contacts.
  24. Shark ION Robot R75 Side Brush Motor Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the malfunctioning motor from its slot in the device.
    • Desolder the two connections on the faulty motor.
    • If you're unfamiliar with soldering techniques and best practices, check out our How to Solder and Desolder Connections guide!
Andrew Lowy
crwdns2935283:001/25/20crwdne2935283:0
599 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G6, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G6, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S3G6
crwdns2947412:05crwdne2947412:0
What is the motor part that is being replaced?
Cheryl Bobo - crwdns2934203:0crwdne2934203:0
I have a different question.
My ion 75 will clean for three minutes, and then it returns to dock. I have cleaned everything underneath but have not unscrewed anything. Popped the wheels and brushes and used Qtip on the side sensors. I charged directly from the wall (bypassing the charger) and had the same result….. three minutes cleaning and returns to dock.
Am I being premature to suspect a battery replacement is needed? This detailed article of yours has me wondering.
flea
Gail Burgess - crwdns2934203:0crwdne2934203:0
My ion RV870 series just stopped working flashes blue max. I have checked all components and cleaned. It has a good charge. I see no dysfunction what so ever. How do I get it working again?? I'm out of ideas because everything seems to be functional and clean.
Gina Madore - crwdns2934203:0crwdne2934203:0
These were awesome instructions for me. Mine had hair wrapped around the brush motor spindle. Before fix it would come off the dock and stop after like 1 foot. After tear down and full clean, it went over an hour. Thank you!
Naz Lazar - crwdns2934203:0crwdne2934203:0
I have the Shark IQ, this was very similar and absolutely awesome. Thanks so much
Lance Plummer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 8,825
