Shark ION RV754 Brush Roll Motor Replacement
  1. Shark ION RV754 Brush Roll Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the unit on its back with the wheels facing up.
    • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
    • Use your finger to lift off the battery door using the small indent next to it.
  2. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery out just above the compartment to access the battery connector.
    • Squeeze the tab against the connector and pull it straight up to disconnect it.
    • Remove the battery completely.
  3. Shark ION RV754 Brush Roll Motor Replacement, Wheels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement, Wheels: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement, Wheels: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TR15 Torx security screwdriver to remove five 13.85 mm screws from the left and right wheel assemblies.
  4. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the wheel assembly out to access the cable connectors that are attached to the wheels.
    • Squeeze the tab against the connector and pull it straight out to disconnect it from the wheel.
    • Remove the wheel assembly.
    • Repeat the steps to remove the other wheel.
  5. Shark ION RV754 Brush Roll Motor Replacement, Suction Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the dust bin latch and slide the bin out to remove it.
  6. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5 9.30 mm screws securing the bumper trim using a Torx TR8 screwdriver.
    • Use an opening tool or spudger to release the clips securing the bumper trip.
    • Carefully pull the bumper trim off the vacuum.
    • Lift the front bumper off of the vacuum.
  7. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TR8 Torx Security screwdriver to remove the five 13.9 mm screws from the bottom of the vacuum.
    • These 13.9 mm screws are in deep recesses and the TR8 screwdriver will need an extension or a narrow shaft to reach them.
    • Remove the two 9.3 mm screws from the bottom of the vacuum near the dust bin cavity using a TR15 Torx Security screwdriver.
    • To separate the vacuum body, place one hand on the bottom and pull with the other from the brush roll recess.
  8. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6 circuit board wire connectors on the left side of the board as shown.
    • Remove the 6 circuit board wire connectors on the right side of the board using the same method.
    • For helpful tips on removing the cables from the board, take a look at the Recognizing and Disconnecting Cable Connectors guide.
    • Be careful when disconnecting the wire connectors from the circuit board to avoid damage to the wires, sockets, or circuit board.
    • It is a good idea to keep a reference picture for reattaching the wires later, since many of them are very similar in color and size.
  9. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 9.80 mm screws from the circuit board.
    • Gently remove the circuit board by pulling up on it as shown and set it aside.
  10. Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 11.6 mm screws securing the suction motor using a Phillips #1 screwdriver.
    • Disconnect the remaining wires connected to the suction motor and move the wires aside to avoid pulling on them when removing the suction motor.
    • Pull up on the suction motor to remove it.
  11. Shark ION RV754 Brush Roll Motor Replacement, Brush Roll Motor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement, Brush Roll Motor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION RV754 Brush Roll Motor Replacement, Brush Roll Motor: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws holding the brush roll motor.
    • Remove the wires attached to the clip by pulling them away gently.
    • Pull the brush roll motor up to remove it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Trinity Cogan
crwdns2935283:002/03/25crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Tennessee Tech University, Team 1-1, Pickering Spring 2025 crwdns2935289:0Tennessee Tech University, Team 1-1, Pickering Spring 2025crwdne2935289:0
TNTECH-PICKERING-S25S1G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 72
