If your vacuum will not turn on and the power cable/connector is faulty, use this guide to replace the power cable/connector. You will need wire strippers, wire end caps, and the T10 and T20 Torx Screwdrivers. Reassembly requires rewiring.
Press the Hose Release button and pull back to detach the hose.
Press the Wand Release button and pull up on the metal tube to remove the entire hose.
Press the Lift Away button and pull up on the handle to separate the top of the vacuum from the bottom.
Pull up on the extra brush pieces to remove them from the vacuum.
Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
Pull up on the filter tab to remove the large foam filter.
Pull up on the small tab to remove the filter pad.
Use the T20 screwdriver to remove the two 12 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 17 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 14 mm screws by turning counterclockwise.
Hi , the T 20 worked on all screws apart from the 17mm ones. I also tried T15 and T10. They would not work. Do you know what else I could try?
Use the T20 screwdriver to remove the three 15 mm screws by turning counterclockwise.
Use the T10 screwdriver to remove the one 17 mm screw by turning counterclockwise.
Use the T20 screwdriver to remove the four 14 mm screws from the bottom of the vacuum by turning counterclockwise.
Use the metal spudger to pry off the back panel.
There are 2 TT20 under the top silver cups
There are extra screws that need to be removed under the switches on the top which can be levered off. And then a couple extra screws under the top cover.
On the white cap holding the wire, use the T20 screwdriver to remove the two 12 mm screws by turning counter-clockwise .
Remove the white cap by pulling it off the device.
Use wire cutters to detach the power cord by cutting the black and white wires.
To reassemble your device, you must rewire a new power cord, then follow these instructions in reverse order.
crwdns2935229:08crwdne2935229:0
Very well done. You need a few stars,/.
Where to buy replacement power cord? Looks like it needs 120V, 60 Hz, 1150W, 9.5 A, but when I search for those parameters nothing comes up. Best way to search for replacement?
