Wire Stripping
crwdns2869540:0crwdne2869540:0: 14.210
15
108
448
14.210
crwdns2959984:0crwdne2959984:0: 24
crwdns2959974:024crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 8
crwdns2959982:08crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 1 - 3 crwdns2931279:0crwdne2931279:0
Wire Stripping
Wire needs to be exposed from its insulation in order before it can be soldered to another wire. Wire stripping exposes the wire so you are able to make good connections.
    1. Wire Stripping, Wire Stripping: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Match your gauge of wire to the gauge on a wire stripper.
      • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
    2. Wire Stripping: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
      • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
    3. Wire Stripping: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
crwdns2935229:024crwdne2935229:0
nat coll
crwdns2935283:009/27/12crwdne2935283:0
868 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-53, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 7-53, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S7G53
crwdns2935297:0180crwdne2935297:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 108
crwdns2936753:030crwdne2936753:0 448
crwdns2959996:0crwdne2959996:0 14,210
