Samsung Watch Active Sensor Array Replacement
crwdns2869540:0crwdne2869540:0: 5.1K
4
18
91
5,131
crwdns2955950:0crwdne2955950:0: 5
crwdns2960004:05crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 10 - 25 crwdns2931279:0crwdne2931279:0
Use this guide to replace a malfunctioning or defective sensor array on your Samsung Galaxy Watch Active.
    1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
    5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back cover.
    1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
      • Carefully twist the opening pick to separate the sensor array from the back cover.
    2. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the sensor array from the back cover.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
136,104 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:02,268crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 91
crwdns2959996:0crwdne2959996:0 5,131
