Samsung Refrigerator Icemaker Auger Assembly Replacement
  1. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  4. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  5. Samsung Refrigerator Icemaker Auger Assembly Replacement, Check the ice bucket condition: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
  6. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wire harness screw securing the cable cover panel.
  7. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  8. Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  9. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the air tunnel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ice maker screw securing the air tunnel flap.
    My unit does NOT have a screw in the front as shown in STEP 9 ???
    TOM PETERS - crwdns2934203:0crwdne2934203:0
  10. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  11. Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  12. Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  13. Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  14. Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  15. Samsung Refrigerator Icemaker Auger Assembly Replacement, Removing the Ice Maker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Removing the Ice Maker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  16. Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the auger wiring connector:
    • Rock the connector side to side to loosen and disconnect it
    • Guide the wiring harness out of the retaining tabs.
    • During reassembly, make sure to re-route the wiring harness back into the retaining tabs. Otherwise, you won't be able to click the cable cover in place.
  17. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A stiff plastic clip holds the auger assembly in place.
    • While lifting the clip with a flathead screwdriver, pull the metal head of the auger assembly to separate it from the chassis.
    • This will prevent the clip from locking back in place.
  18. Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the auger assembly out of the refrigerator and remove it.
    I have done everything including step 17 with flathead screwdriver to lift tab. Auger motor will not budge. Even clamped vice grips to auger metal head to get a better grip. Still will not budge?
    Donald T. Ford - crwdns2934203:0crwdne2934203:0
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15.927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
Team Vulcan crwdns2935289:0Team Vulcancrwdne2935289:0
Staff
crwdns2931471:06crwdne2931471:0
crwdns2935297:0197crwdne2935297:0
GOOD MORNING NICO! My Samsung Refrigerator is a unit built in about 2012. In STEP 9, you show a screw that needs removal to slide out the air tunnel. It appears that my model is a one - piece design. It does NOT have the screw. Any ideas how to proceed?
TOM
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 1,896
