Samsung Galaxy Watch3 Motherboard Replacement
  1. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the back cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    I heeded your advice - and now need another screw because it fell out!!!
    Paul - crwdns2934203:0crwdne2934203:0
    I must have stripped the screws out or either the dirt and sweat is so packed into the screw i can't get a good bite to unscrew the screws. What can I do about this? This watch battery DOES NOT hold a charge for more than 5min, should I trash the watch?
    ShaneWizdum - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    Could not get the back housing off
    Joseph Ortiz, Jr - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    Where would one get a new rubber water gasket if the old one is damaged by this process?
    Jack Popham - crwdns2934203:0crwdne2934203:0
    I need also the Rubber Sealing. Anyone got a replacement part?
    Steffen Politzky -
    Me too, I'm tired of searching for one, they don't exist.
    Karl Roberts - crwdns2934203:0crwdne2934203:0
    If anyone has the red ringed gasket in the photo please share a link to buy or part code to search for etc. I am constantly drawing a blank no matter what key words I search. It's utterly crushing not to have this part easily available.
  5. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
  6. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the motherboard screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips #00 screw.
  7. Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard is held in place by two small plastic clips.
    • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
    • Remove the motherboard.
    Question, I had a demo Watch3. I tried to swap out the software and ended up putting it into Odem Mode. It’s bricked right now, any idea or help to fix it?
    Lucas Economy - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before resealing.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
124,795 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,132crwdne2935297:0
What is the cost of R845 mother board of Samsung watch 3- 45 mm
Jayanta Roy - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,676
