Use this guide to replace the motherboard in a Samsung Galaxy Watch.
Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
Use an opening tool to get between the back cover and the metal housing of the watch.
Carefully pry the plastic back cover open.
Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
Use a spudger to disconnect the sensor flex cable from the motherboard.
Use a spudger to disconnect the display flex cable from the motherboard.
Lift the core unit out of the housing.
Use a spudger to disconnect the hall sensor flex cable.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to gently peel both button cables from the plastic frame.
Remove the single Phillips #00 screw (3.4 mm length).
Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
Lift the motherboard by twisting the spudger.
Slide the motherboard out from under the plastic tab.
If possible, turn on your device and test your repair before resealing.
crwdns2935229:09crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Anyone know where to purchase a Galaxy Watch mother board?
What is the part number, or where can you get the motherboard?
Where can the motherboard be purchased from for Galaxy Watch ?
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
Hello,
Do you know if switching a motherboard from a GW46 Bluetooth only (R800) to a GW46 LTE (R805) is a straight swap or additional parts are needed?
As my R800 sensors are dead and i need to replace the motherboard and the back cover anyway.
Thanks
