Samsung Galaxy Watch Motherboard Replacement
  1. Samsung Galaxy Watch Motherboard Replacement, Opening Procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
  10. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
If possible, turn on your device and test your repair before resealing.
crwdns2935229:09crwdne2935229:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125.967 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01.137crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Anyone know where to purchase a Galaxy Watch mother board?
lorne serpa - crwdns2934203:0crwdne2934203:0
What is the part number, or where can you get the motherboard?
Nick Henthorn - crwdns2934203:0crwdne2934203:0
Where can the motherboard be purchased from for Galaxy Watch ?
Mohammed Aamir - crwdns2934203:0crwdne2934203:0
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
Agris Jurjans - crwdns2934203:0crwdne2934203:0
Hello,
Do you know if switching a motherboard from a GW46 Bluetooth only (R800) to a GW46 LTE (R805) is a straight swap or additional parts are needed?
As my R800 sensors are dead and i need to replace the motherboard and the back cover anyway.
Thanks
BRazvy - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 165
crwdns2942667:0crwdne2942667:0 14,267
