Samsung Galaxy Watch Active2 Back Cover Replacement
  1. Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the rear screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Bekomme ich nicht auf … Schrauben zu fest
    Tino Wehner - crwdns2934203:0crwdne2934203:0
    The screws are attached to the cover. So you just need to loose them, not remove them.
    Yonic Surny - crwdns2934203:0crwdne2934203:0
    Any tips for a too tight screw ?
    Daisy Doune - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    There is a glue-ish gasket keeping it closed. I used an exacto knife to start it opening.
    BRIAN MIRANDA - crwdns2934203:0crwdne2934203:0
    This was super helpful thank you! Perfect timing
    this is trash -
    Waarmee kan ik de achterste oplaadplaat weer vast lijmen op de achterste behuizing
    Ilona Smit - crwdns2934203:0crwdne2934203:0
  4. Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Ou je peu me procurer le tourne vis tri point 000
    grenierlulu - crwdns2934203:0crwdne2934203:0
  5. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    Where would you recommend buying a new back panel/charger?
    Nathan Williams - crwdns2934203:0crwdne2934203:0
    Una pregunta. y para poner el reemplazo sería necesario algún tipo de sellador o silicón?porque pues usualmente este tipo de tapas vienen sellados de fabrica para evitar cualquier posibilidad de que le pudiera entrar agua
    Jesus Frias - crwdns2934203:0crwdne2934203:0
crwdns2935229:013crwdne2935229:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
124,713 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,132crwdne2935297:0
What kind of glue would you use if the plastic of the back cover fell off?
Dave Hains - crwdns2934203:0crwdne2934203:0
This happened to me as well. I opted to replace the entire adhesive-attached back cover. You can find kits that include a new back with a new adhesive gasket already attached. You just need to take off the old one and make sure it's clean before putting on the new one. I bought this one on ebay: https://www.ebay.com/itm/164638316825
John S. -
Hello. Where can i get the back cover with adhesive as a replacement or just the adhesvie? I noticed it is a weird rubbery glue and i cannot source this anywhere.
Arbuzov Paul - crwdns2934203:0crwdne2934203:0
Why would you use glue? The back is fixed with screws.
If there is a loose part on the back cover you might want to try a glue like the E6000, B7000 or T9000 (there are different combinations out there)
Tobias Isakeit -
My Samsung Galaxy active to watch not only did the rear piece fall off but I had bought a new one to put on the back but I noticed that the charging ring has that metal magnet has come off and little shards of metal have attached everywhere else so it won't charge is there any way you can take that charging ring out of your watch and not use it or where can you buy them at. Everyone talks about how to put the back on a watch but they do not talk about this part I have looked for it for months also there always doing a watch that has screws in the back of it, my Galaxy watch does not have screws on the back of it.
Loria Lee Scott - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 336
crwdns2942667:0crwdne2942667:0 39,835
