Samsung Galaxy Tab A9 Plus Charging Board Replacement
  1. Samsung Galaxy Tab A9 Plus Charging Board Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power the device off by holding the power button for 10-15 seconds.
    • Use the heat gun to evenly heat the edge of the device and loosen the adhesive securing the screen to the tablet.
    • The heat gun should be set on 5 when using it to heat the adhesive.
    • Be careful when using the heat gun; it can damage the device if you heat one area too much or for too long.
    • Use the suction tool to separate the screen from the case, and insert an opening pick to help keep the screen edge separated from the rest of the device.
    • Slide a second pick around the edge to cut through the remaining glue of the screen.
    • Continue placing plastic opening picks in the gaps about every inch or so intill the screen fully separates.
  2. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the screen towards the top of the device (the side with the front camera), being careful not to damage the orange flex cable.
    • Use a JIS #00 screwdriver to remove two 2.4 mm screws securing the metal bracket.
    • Remove the metal bracket covering the connector and place it to the side to use for reassembly.
  3. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide a spudger or opening pick under the glued-down cable to separate its adhesive and disconnect the cable.
    • Remove the display screen from the tablet.
  4. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to remove any excess adhesive remaining on the edges of the device's rear housing.
    • If you are having trouble removing the adhesive, try using adhesive remover.
  5. Samsung Galaxy Tab A9 Plus Charging Board Replacement, Charging Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #00 screwdriver to remove the four 2.3 mm screws from the USB port at the bottom edge of the device.
  6. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press a spudger into the edge between the USB cover and the device's exterior casing to remove it.
    • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it from the motherboard.
  7. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the end of a spudger into the gap underneath the flex cable to remove the USB port.
    • Use a spudger to create a gap between the USB port and the case to make it easier to remove.
  8. Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab A9 Plus Charging Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the USB port from the device.
    • Be careful when removing the USB port, as it is very close to the press connector and can be easily damaged.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Caleb Hataway
crwdns2935283:002/12/25crwdne2935283:0
580 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-6, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-6, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G6
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 122
crwdns2936753:030crwdne2936753:0 644
crwdns2942667:0crwdne2942667:0 2,010
