Use this guide to replace the screen on your Samsung Galaxy S6 Edge+.
This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. Note: some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. This procedure is very different, so make sure you have the correct part before starting this guide.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
Removing the rear glass destroys the adhesive holding it in place. The adhesive will need to be replaced before the rear glass is replaced or reinstalled.
Insert a paper clip or SIM card eject tool into the hole in the SIM card slot on the volume button side of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Heat an iOpener and apply it to the volume button side of the phone for about two minutes.
Once the back panel is hot to the touch, apply a suction cup near the center of the phone, and as close as possible to the edge of the panel.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the side of the phone to cut the adhesive securing the rear panel.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive.
Remove the rear glass.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. The sheet is asymmetrical, so make sure the screw holes in the adhesive sheet line up with the screws on the frame before applying the adhesive.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Remove eighteen 3.2 mm screws from the midframe.
Press down on the back of the battery while you lift up on the edges of the midframe to separate the midframe from the rest of the phone.
Use the flat end of a spudger to disconnect the battery ribbon cable from the motherboard.
Use the flat end of a spudger to pry the display cable connecter straight up out of its socket.
After testing the replacement display, unplug the battery and replacement display and continue with the guide.
Use the flat end of a spudger to disconnect the front-facing camera ribbon cable.
Use the flat end of a spudger to disconnect the front-facing sensor array ribbon cable by prying it straight up from its socket.
Use the point of a spudger to disconnect the two antenna cables.
Grip the edges of the motherboard and lift up slightly.
Use the point of a spudger to move the battery and sensor assembly ribbon cables away from the edges of the motherboard.
With the battery and sensor assembly cables out of the way, hinge the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
Use the flat end of a spudger to disconnect the daughterboard ribbon cable from the underside of the motherboard.
Remove the motherboard.
If your display glass is badly cracked, tape over the glass to contain stray glass and make prying easier.
Heat an iOpener and apply it to the left edge of the display for at least two minutes.
Cut very gently near the "recent" and "back" capacitive buttons near the bottom of the display. These are adhered to the display and are very easy to tear.
Insert an opening pick into the small gap between the display and the display frame, near the middle of the battery-side edge of the display.
When you insert the pick make sure it is on top of the pink shield layer of the display to properly cut the adhesive.
Slide the pick along the entire edge of the display, separating the adhesive.
Insert the pick as far as you can while maintaining a firm grip.
Slide the pick back up the edge of the display to separate the last of the adhesive.
After cutting the adhesive, leave the pick in the side of the display to prevent the display from re-adhering to the frame.
Insert an opening pick no more than 0.25 inches (~6 mm) into the bottom battery-side corner of the display, near the top of the daughterboard.
Slide the pick around the corner of the display, stopping before you reach the "recent" button ribbon cable.
Heat and apply an iOpener to the bottom of the display.
Insert an opening pick no more than 0.25 inches (~6 mm) in the bottom edge of the display, near the headphone port. Inserting it farther may damage the home button.
Slide the pick along the bottom edge of the display, separating the adhesive. Stop before you reach the "back" button ribbon cable.
Heat an iOpener and apply it to the display cable side of the display.
Insert an opening pick into the gap along the display cable edge of the display, just below the display cable.
Slide the pick down the edge of the display, stopping before you reach the daughterboard.
Slide the pick back up the edge of the display, cutting the remaining adhesive.
Insert an opening pick no more than 0.25 inches (~6 mm) into the bottom, display cable side corner of the display, near the top of the daughterboard.
Slide the pick around the corner of the display, stopping before you reach the "back" button ribbon cable.
Insert an opening pick no more than 0.25 inches (~6 mm) into the gap at the top edge of the display.
Slide the opening pick along the top edge of the display, cutting the adhesive.
Leave the pick in the top edge to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the display for about one minute.
Gently insert an opening pick between the display and the "recent" button, no more than 0.5 (~12 mm) inches deep to avoid damaging the display.
Leave the pick under the display to prevent the button from re-adhering to the display.
Insert an opening pick between the "back" capacitive button and the display.
Insert an opening pick in between the display and the display frame on the battery side.
Twist the pick to pry apart the display and the frame.
Slowly lift the display frame away from the display.
Use a spudger to push the display cable connector away from the edges of the hole in the display frame and gently thread the cable through the hole.
With the display cable connector safely through the display frame, completely separate the display from the frame.
After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
crwdns2935229:014crwdne2935229:0
I find the best thing to do with any smartphone with a cracked rear and front screen is smashed the screen not to answer basic components and then it's easy to get off
Hello sir, I am DESIRE ANDREW.
Can I get a screen of this Samsung Galaxy s6 edge plus
