Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Heat the right edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain to below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Adhesive information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Adhesive information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the right adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the right adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the right adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  7. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the bottom adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the bottom adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Heat the left edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  10. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the left adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the left adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the left adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  13. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the top adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the top adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  14. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Separate the corner adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  15. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the remaining adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the remaining adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  16. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the back cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the back cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the back cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  17. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  18. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Unfasten the NFC antenna and charging coil: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  20. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Unfasten the loudspeaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  21. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Unclip the loudspeaker: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Unclip the loudspeaker: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  22. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  23. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the battery: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the battery: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  24. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the laser AF module: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Disconnect the laser AF module: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the laser autofocus module press connector.
  25. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Unfasten the motherboard cover: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the motherboard cover.
  26. Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover and laser AF module.
    • During reassembly, press down on the cover to secure its clips to the frame.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86,430 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,503crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 65
