Use this guide to replace a worn-out or dead battery in your Samsung Galaxy S21 Ultra.
This guide was performed on the SM-G998B/DS (international) model. Other models have an additional antenna cable sitting in the edge of the midframe.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom right corner of your phone.
Slide the opening pick along the right edge of your phone to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top right corner of your phone.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top left corner.
Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers.
Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
Falls die Schrauben mit LOCTITE Kleber gesichert sind (bei mir der blaue), dann Vorsicht mit dem Kreuzschlitz der kleinen Schraubenköpfe. Unbedingt den richtigen Kreuzschlitz-Bit oder -Schraubendreher verwenden, der gut sitzt. Beherzte, aber dennoch vorsichtige auf- und zudrehversuche (!) bei gleichzeitigem drücken helfen, den LOCTITE zu brechen/lösen, bevor die Schrauben sich leicht herausdrehen lassen.
Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
No need to remove lower speaker to replace camera , just disconnect 3 flat flex cables from motherboard.
The corner screws were a little covered in glue on my phone (no previous repair or opening of the phone). This cause me to strip one of the screws, so I had to take it to a professional shop. Make sure you clean your screws and you get a good grip with the screwdriver!
Insert a spudger into the gap between the top edge of the loudspeaker assembly and the midframe.
Use your spudger to pry up the loudspeaker assembly by tilting it downwards.
Remove the loudspeaker assembly.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
Use your fingers or a pair of tweezers to carefully remove the main flex cable.
Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
Use your spudger to carefully bend the flex cable to the side to avoid damaging it during the battery removal.
Fold the display flex cable towards the charging port to get free access to the battery.
Wo ist dieses weise kable oder band habe jetzt alles gemacht zu diesem schritt shehe das band aber nicht
Band auf dem ersten bild das gedrehte
Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the left and right edge of the battery.
Let the isopropyl alcohol penetrate the battery adhesive for at least two to three minutes.
If you are replacing the LCD/frame then apply extra isopropyl so excessive prying does not turn the battery into a flame thrower and damage other imortant parts. The glue is beyond strong, for no apparent reason since the battery will not wiggle with much less glue.
Secure a suction handle to the battery, as close to the battery edge as possible.
Insert an opening pick into the gap between the edge of the battery and the frame.
Rotate the opening pick to insert its long edge into the gap.
crwdns2935267:0crwdne2935267:0Heavy-Duty Suction Cups (Pair)$14.95
Pull up on the suction handle with firm, steady pressure and tilt the opening pick downwards at the same time to pry up the battery.
If replacing LCD/frame I believe there isno need to remove the battery.
Remove the battery, making sure to peel off any remaining adhesive.
If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Hallo ifixit Team, gibt es Alternativen für das Battery adhesive in Deutschland, da man es über die website nicht kaufen kann? Gibt es dieses kleine Fläschchen zum Aufträgen des isopropyl Alkohols bei euch?
Danke
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
crwdns2935229:030crwdne2935229:0
is it possible to destroy the screen by heating it up to much?
Danny National (NerdNational) - crwdns2934203:0crwdne2934203:0
Hi Danny,
yes it is possible to damage the display if you expose it to too much heat. At the latest when the display discolors under heat, it has become too hot and is damaged. A guideline is about 80 to 90 degrees maximum temperature. If you don't have the possibility to check the temperature exactly, it is recommended to heat the display several times with a lower temperature and to test again and again whether the adhesive can be loosened yet. The device should get just warm enough that you can still touch it.
Centigrade for Fahrenheit?
Sorry for the ambiguity. 80 to 90 degrees centigrade.
Is step 17 really neccesary?
Excellent battery replacement guide. At first I had concerns about removing the back panel. I was afraid of sharing the back panel, with some patience it was removed in about 30 minutes. Oh boy, the battery... the battery toke me 2 hours. Make shure you have patience and the right type of alcohol for the battery adhesive. The reassembling and testing toke me 30 minutes. Overall the key is patience.
