Use this guide to remove or replace the battery in your Samsung Galaxy S21.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Although it’s not necessary to remove the interconnect cables to replace the battery, we advise doing so. It makes the battery removal and reassembly much easier.
You'll need replacement adhesive in order to complete this repair.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Are you pulling the suction cup on an angle or something? How can you pull up on cup with nothing tying down the phone?
The backing is a polycarbonate material - so yes it's plastic. Also, when pulling up with the suction cup your correct in that it is or should be done on an angle. Plus, the back is plastic so it will only flex upwards as you're applying the pressure. Lastly, because the backing is still tapped inside and your pulling upwards, if necessary with the hand that's pulling up you can gently rest the part of your palm/wrist against the phone which may also help in the separation process but remember you're goal is to only lift it enough so you can slide in the separator pick. I use guitar picks myself since I have them laying around all over the place. Good luck, and don't rush yourself :0)
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's left edge for two minutes.
If you have access to a heating pad you can use this instead and save some cash but make sure to turn it on and let it heat up so you check the temperature first as it needs to be hot enough to melt the glue but not damage the components. Typically, these work great because they're designed not to burn a person.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
Apply a heated iOpener to the back cover's right edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
Rotate the right-edge opening pick around the top-right corner of the phone.
Slide the top-most opening pick as close to the camera shell as possible.
Repeat for the left-edge pick.
Heat an iOpener and apply it to the camera shell for two minutes.
Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
Insert an opening pick in the gap.
Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
Slide an opening pick between the camera shell and the frame to cut the adhesive.
There's additional adhesive to the right of the camera that you need to cut through.
Angle the pick downward to avoid any damage.
Line up the opening pick's tip with your phone's flash
Insert the pick slowly, making sure to avoid the flash's plate.
Slice the adhesive to the right of the camera.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Why begin reassemble directions or reminders when the battery has not even been removed yet? This advice would be better suited just after the battery install and just after powering on to test. Might have to inject multiple "test" points before and after reassembly.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
Use your fingers to gently peel the wireless charging coil away from the phone.
Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
Remove the loudspeaker.
Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
Use the flat end of a spudger to pry up on the secondary interconnect cable's press connector.
Repeat for the primary interconnect cable's press connector.
Use tweezers, or your fingers, to remove the secondary and primary interconnect cables.
Use a spudger to pry up and disconnect the display cable's bottom press connector.
Use a spudger to pry up and disconnect the display cable's top press connector.
Use tweezers, or your fingers, to remove the display cable.
Don't forget to disconnect the power button cable between steps 32 and 33.
Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's perimeter.
Apply a suction cup to the battery, as close to the center of the right edge as possible.
Insert an opening pick into the edge with the widest gap between the frame and the battery.
Rotate the opening pick to insert its long edge into the gap.
Pull up on the suction cup with strong, steady force and pry up with the opening pick to separate the battery from the frame.
this does not wqork and I am afraid of breaking the battery or my hand
Not mentioned here is just how difficult these batteries can be to remove. More instruction would be useful. It took hours just to do this step following this instruction. Another thing: at least 3 people following this guide had a non working fingerprint sensor after putting everything back in place. At least 2 of these people struggled with this step but saw no visible damage to the sensor (which, for those reading, is directly under the battery!) In all, more or better instruction is needed.
Remove the battery, making sure to peel off any remaining adhesive.
If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
crwdns2935229:043crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Will it void my warranty
Yes, unfortunately the warranty will be voided if you "tamper" with any of the components.
Just a note to the last step regarding iso. Be careful not applying too much iso - it will run down to the display via the hole in the back.
The glue is a pain but I wasn't nearly as careful on the bottom part as the guide suggested and was able to get it off just fine. I also didn't bother to remove the old glue and it holds well enough
will my waterproofness go away
Instead of the tesa tape being listed in the products, the galaxy s21 back cover adhesive should be added. Did this fix and did not know it existed. Do we even need to replace the adhesive like the guide suggests?
All in all, many good things about this guide but ultimately I trusted it blindly and ended up with a non working fingerprint sensor. I would look at several sources, e.g. videos, before going forward with the fix.
I was fortunate in getting the back off as the battery had expanded enough to do the job for me except around the camera area which came off fine with a hairdryer. As pretty much all the glue was left around the case edge the application of the hairdryer soon sealed that up again. Great instructions, many thanks for presenting them!
Battery charge
My new battery is encased in a plastic film
Does that stay on?
Can I use this guide for a Samsung Galaxy A52s ?
The new battery is lower capacity than the original and smaller in size. I ordered a battery for a S21FE
How hot does the back cover have to be to come off? I tried with iOpener many times but have had no luck opening it. The surface temperature goes up to 105-110F (43C).
Imtiaz Chowdhury - crwdns2934203:0crwdne2934203:0
Hi Imtiaz!
We don't have a specific temperature that we recommend, but, if you're still having issues separating the adhesive with the iOpener, I would recommend you switch to a hair dryer or a heat pad. The back cover should be slightly too warm to the touch.
Alex Diaz-Kokaisl -
