Use this guide to replace the motherboard in your Samsung Galaxy S20 FE 5G.
You’ll need replacement back cover adhesive to reassemble your device.
Power off your phone and unplug any cables.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of your phone until the tray ejects.
Remove the SIM card tray.
Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
Apply a suction cup to the center of the back cover's bottom edge, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and frame.
Insert an opening pick in the gap.
Slide the opening pick along the bottom edge to slice the adhesive securing the back cover.
Leave the opening pick inserted in the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Slide the opening pick around the bottom right corner and all the way up the right edge to slice the adhesive.
Leave the opening pick inserted in the top right corner.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Slide the opening pick around the top right corner and along the top edge to slice the adhesive.
Leave the pick inserted in the top left corner.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Slide the opening pick around the top left corner and all the way down the left edge to slice the remaining adhesive.
Remove the back cover.
Use tweezers or your fingers to peel off the old adhesive from the back cover and frame.
Use highly-concentrated isopropyl alcohol (over 90%) and a microfiber cloth to remove any remaining adhesive residue.
Follow this guide to apply new custom-cut adhesive.
Use a Phillips screwdriver to remove the 16 screws securing the wireless charging assembly:
Nine 4 mm-long screws securing the motherboard cover
Seven 4.5 mm-long screws securing the loudspeaker
Insert a pick under the bottom right edge of the motherboard cover.
Twist the pick to release the clips securing the cover.
Insert and twist the opening pick on the bottom left edge of the cover to release the remaining clips.
Reposition the motherboard cover so you can access the battery and wireless charging press connectors on the bottom edge of the motherboard.
Use the flat end of a spudger to pry up and disconnect the battery and wireless charging press connectors from the motherboard.
Insert the point of a spudger between the bottom left corner of the loudspeaker and the frame.
Pry up to release the clips securing the left edge of the loudspeaker.
Pry up the bottom right corner of the loudspeaker to release the remaining clips.
Remove the wireless charging assembly.
Use the flat end of a spudger to pry up and disconnect the interconnect cable press connector from the motherboard.
Use the flat end of a spudger to disconnect the three camera press connectors.
Slide one arm of your angled tweezers under the head of the red antenna cable.
Gently lift straight up to disconnect the cable.
Use the same process to disconnect the white antenna cable.
Repeat the previous step to disconnect the blue antenna cable from the bottom left corner of the motherboard.
During reassembly, make sure the antenna cables are in their channels on the edges of the phone.
To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
Use a Phillips screwdriver to remove the 4 mm-long screw securing the motherboard.
Use the flat end of a spudger to lift the top edge of the motherboard up until you can grip it with your fingers.
Remove the motherboard.
Make sure the eight cables that connect to the motherboard are out of the way so they don't get stuck under the board.
Lay the motherboard in its recess and press down to secure it.
Flip the motherboard over and lay it on a clean, soft cloth to prevent damaging it.
Use the flat end of a spudger to disconnect the ultra wide camera.
Remove the camera.
You're left with the motherboard.
Compare your new replacement part to the original part—you may need to transfer remaining components from the new part before you install it.
Thanks for this guide! My S20 FE got water damage and this helped me remove the motherboard. Much appreciated
