This guide shows how to remove and replace the fingerprint sensor for the Samsung Galaxy S10e.
This is a very involved procedure that requires you to remove the screen, which will destroy it. Do not attempt this procedure unless you have a replacement screen.
Turn your phone off completely before you begin this repair.
Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
Insert an opening pick into the edge next to the opening tool. Leave the pick here to prevent the separated glue from re-adhering.
Apply a heated iOpener to the top edge of the phone for two minutes.
Insert an opening pick near the top right corner of the phone and slide it around the corner and across the top edge of the phone.
Leave the opening pick in place to prevent the adhesive from re-adhering.
Apply a heated iOpener to the left edge of the phone for two minutes.
Insert a new opening pick near the top left corner and slide it along the left edge of the phone.
Again, leave the opening pick in place in the left edge of the phone to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the phone for two minutes.
Insert an opening pick near a bottom corner of the phone, and slide it along the bottom edge of the phone to separate the adhesive there.
Use the opening picks to very carefully pry up the back cover.
If you encounter any resistance, stop prying and use an opening pick to cut any remaining adhesive.
Remove the back cover.
Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
Slide an opening pick under the bottom right corner of the upper midframe to separate the adhesive holding it to the lower midframe.
Insert the point of a spudger in the small cutout on the right edge of the plastic part of the upper midframe, near the Bixby button.
Use the point of the spudger to pry the midframe up from the phone chassis.
Lift the midframe by the plastic section and remove it from the phone.
Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
Use a Phillips driver to remove the seven 3.9 mm screws securing the loudspeaker.
Insert the point of a spudger into the notch on the right edge of the loudspeaker.
Pry up with the spudger to loosen the loudspeaker.
Lift the loudspeaker up and remove it.
Use the flat end of a spudger to pry up and disconnect the screen connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the fingerprint sensor connector from its motherboard socket.
Use a Phillips driver to remove the two 4 mm screws securing the fingerprint sensor bracket.
Apply a heated iOpener to the fingerprint sensor bracket for one minute to loosen the adhesive.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the points of your tweezers to slowly pry up the fingerprint sensor bracket.
Remove the fingerprint sensor bracket.
Use a pair of tweezers to loosen the fingerprint sensor cable from the adhesive gasket.
Flip the phone over so that the display is facing up.
Apply a heated iOpener to the right edge of the screen for two minutes.
Display seam—this seam sits above the thin plastic bezel. You need to pry along this seam to separate the display.
Frame seam—this seam sits below the thin plastic bezel. Do not pry along this seam or you will damage the plastic bezel.
Apply a suction cup to the heated edge of the display.
Pull up on the suction up with strong, steady force to create a gap.
Insert the point of an opening pick into the display seam gap.
Slide the opening pick along the right edge to slice through the adhesive.
Leave the opening pick in the corner to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the display for one minute.
Slide an opening pick along the bottom edge to slice through the adhesive.
Repeat the heating and slicing procedure for the remaining display sides.
Lift up and remove the display glass.
Apply a heated iOpener to the OLED panel for a minute to soften up the panel adhesive.
Lift the display panel from the right edge and peel it away from the frame.
Thread the display panel connector through the frame.
Use the flat end of a spudger to pry up the fingerprint cable cover from the frame.
Remove the fingerprint cable cover.
Use the point of a spudger to gently pull the fingerprint sensor cable through its frame cutout.
Use a pair of tweezers to lift and remove the power button support bracket from its recess.
Remove the fingerprint sensor from its recess.
After you've completed the repair, follow this guide to test your repair.
