Samsung Galaxy Book Pro 360 15" Screen Replacement
  1. Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
  4. Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    Hey, be carefull with the screw attachment between the lid and the chassie. They brake away easily if tightenend too much.
    Sora [___] - crwdns2934203:0crwdne2934203:0
  7. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up the locking flap on the right display cable's ZIF connector.
  10. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to grip the display cable's pull tab and gently pull the cable out of its socket on the motherboard.
  11. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull the right display cable out of its recess.
    • A small clip secures the cable.
    • During reassembly, make sure that the display cable is secured under its clip.
  12. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect and remove the left display cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the disconnection and removal procedure on the left display cable.
  13. Samsung Galaxy Book Pro 360 15" Screen Replacement, Open the laptop: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop until it's completely flat and lay it down with the display and keyboard facing down.
    • Before laying the laptop down, make sure you have a clean surface that is clear of items that could damage the display.
  14. Samsung Galaxy Book Pro 360 15" Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the right screen hinge.
    • During reassembly, install the screws from left to right.
  15. Samsung Galaxy Book Pro 360 15" Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the left screen hinge.
    • During reassembly, install the screws from right to left.
  16. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen up and away from the laptop and remove it.
  17. Samsung Galaxy Book Pro 360 15" Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is now detached from the laptop.
    I plan to do all steps removing and replacing laptop screen with the laptop open at 180 degrees on a protective mat. When I had an issue with the laptop not powering on previously, I removed the back cover with the laptop closed, disconnected then reconnected the battery, which solved the power issue. However, while removing/ replacing back cover, the back put pressure on the screen causing cracks in an already very flexible screen. If I had done everything with the laptop open, I think I would have not needed to replace the screen.
    DavidW - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow the instructions in reverse order.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
112.013 crwdns2915208:0crwdne2915208:0
crwdns2935297:0811crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.021crwdne2935297:0
This is the display assembly. How do you replace the screen?
Chris Wilson - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Rob -
Is this compatible with the Galaxy Book3 360 2-in-1 15.6" FHD AMOLED Touch Screen Laptop? Model NP750QFG-KA2US. I can't find a good site to confirm compatibility of parts. (FWIW, I don't care if I lose touchscreen capabilities.)
Bret - crwdns2934203:0crwdne2934203:0
I'm also echoing Chris Wilson on this one - this is not a screen replacement, rather this is a full display assembly replacement.
cubewano - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 350
crwdns2942667:0crwdne2942667:0 14,522
