Saab 9-3 Ignition Switch Module (ISM) Replacement
Lars Erlandsen
crwdns2944109:0crwdnd2944109:0Lars Erlandsencrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Mud 17, 2018crwdne2944111:0
crwdns2931291:03crwdne2931291:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
I have a 2007 Saab 9-3 Aero petrol Automatic car. It has been a joy to own and ride, but recently it started to show warning messages:
"Steering lock Malfunction. Please come to a safe stop and call service" (or something like that)
On other occasions, the key would refuse to turn. Disconnecting the battery for a while would sometimes fix the issue, but this was clearly not a safe car to drive any longer.
Googling the issue revealed that there are two components involved in starting the car:
The ISM (Ignition Switch Module) is where the key is inserted.
The CIM (Column Integration Module) is located inside the steering wheel. It is the security centre and controls the central locking, ignition, immobilisation, steering lock etc.
Both of these could be the culprit. However, whereas the ISM _can_ be replaced by a layman (i.e. me!!), the CIM requires both special tools and the electronic equipment to be able to remove and replace, and pair up with a new set of keys.
So, equipped with a Haynes "Saab 9-3 Sept 2007 to 2011 Owners Workshop Manual", a set of star shaped screwdrivers, and a camera to record all the steps, as well as a pile of clear plastic bags to put the screws in and label them (they are all subtly different in size, thread and length), I set about to replace the ISM with a unit I bought on eBay. This involves removing the centre console to get to the ISM itself.
crwdns2944105:0crwdne2944105:0
  1. Saab 9-3 Ignition Switch Module (ISM) Replacement, The starting point: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Our starting point: The center console with the ignition switch in the middle
    If this is bad does the clocking ignition switch have to be replace with it as well. My 2003 SAAB is not starting and the lights and gauges stopped working and were flashing. It also would not shift..Is this really caused from the ISM?
    Shondel Begley - crwdns2934203:0crwdne2934203:0
  2. Saab 9-3 Ignition Switch Module (ISM) Replacement, The tool: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the screwdriver bit used to remove all the screws.
  3. Saab 9-3 Ignition Switch Module (ISM) Replacement, The ISM (Ignition Switch Module): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the item we need to replace
  4. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panels: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
  5. Saab 9-3 Ignition Switch Module (ISM) Replacement, Panel screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove this screw
  6. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panel comes off: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The panel can now come off.
  7. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rear cover is removed next.
  8. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove rear panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
  9. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear side panels: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear side panels in front of the rear cover are now easily accessible and can be removed.
  10. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rubber mat in front of gear lever: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, remove the rubber mat in front of the gear lever.
  11. Saab 9-3 Ignition Switch Module (ISM) Replacement, Gear lever surround trim: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
  12. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining frame holding screw: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
  13. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the retaining screw
  14. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the retaining frame
  15. Saab 9-3 Ignition Switch Module (ISM) Replacement, Hand brake cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out horizontally the protective plastic cover underneath the hand brake.
  16. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This exposes a single screw. Remove this.
    OMG, is that what this is? That is a pretty useless invention… Mine (2008, manual) doesn’t have the slit.
    Gábor Bánóczi - crwdns2934203:0crwdne2934203:0
  17. Saab 9-3 Ignition Switch Module (ISM) Replacement, CD holder: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the other side, remove the CD holder top cover,
  18. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • unscrew the two screws inside,
  19. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • and remove the CD holder itself. This exposes another single screw. Remove this.
  20. Saab 9-3 Ignition Switch Module (ISM) Replacement, Storage unit: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom rubber cover in the centre console storage unit.
  21. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This exposes two screws that need removing.
  22. Saab 9-3 Ignition Switch Module (ISM) Replacement, Drinks holder: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The drinks holder has another rubber mat.
  23. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
  24. Saab 9-3 Ignition Switch Module (ISM) Replacement, Air duct: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
  25. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
  26. Saab 9-3 Ignition Switch Module (ISM) Replacement, Cable bundles: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
  27. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
    Would you happen to know which of those wires sends the voltage when cranked? I know the violet/yellow one provides voltage when key is turned to ‘on’. I’m trying to install a push button starts. Thanks!
    Tito Sanchez - crwdns2934203:0crwdne2934203:0
  28. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The other is an earth connector near the rear of the console. This can easily be pulled away.
  29. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining screws in front of the gear lever: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two screws located in front of the gear lever.
  30. Saab 9-3 Ignition Switch Module (ISM) Replacement, Horizontal retainer screws -- a fiddle to get out!!: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
  31. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
  32. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The center console is now loose, and can be puller backwards and upwards, and removed from the car.
  33. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
  34. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
  35. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
    Did you go for a genuine ISM? How is it holding up today?
    Machachi - crwdns2934203:0crwdne2934203:0
    • The rest of the procedure is doing the dismantling in reverse. However, this is the best order that I found (choosing the wrong order once or twice):
  36. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
  37. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
    This is a good time to test out your new switch if you haven’t already.
    Andy Hudson - crwdns2934203:0crwdne2934203:0
    • Next, fit the retaining frame underneath the gear lever, all screws around it, then the shiny gear lever surround trim, and finally the rubber mat in front of it. Fit the side rear panels, then the front panels (fasten them with the single screw), then the rear cover.
  38. Saab 9-3 Ignition Switch Module (ISM) Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?). You are done!
    • Touch Wood, my car is now purring, with none of the issues I had before. Having heard quotes from around £1,000 upwards for a complete ISM / CIM refit, I am well pleased with the result.
    I have not as yet got the replacement part but, I'm not saying that it'll be the easiest set of instructions to follow. It looks like it's not going to be the hardest either, thank you.
    waynesthe1 - crwdns2934203:0crwdne2934203:0
    Just completed fitting ism … driving the car for a couple of days to make sure issues resolved before putting the rest of Humpty Dumpty back together again
    thanks very much for posting this, was quite satisfying to do, saved a fortune
    Cheers
    David
    david ward - crwdns2934203:0crwdne2934203:0
    Did you have any issues with Key not Recognized message ?? I’m having it but both keys previously worked
    Brian E Gorrell - crwdns2934203:0crwdne2934203:0
crwdns2935229:015crwdne2935229:0
Lars Erlandsen
crwdns2935283:004/17/18crwdne2935283:0
1,313 crwdns2915208:0crwdne2915208:0
crwdns2947412:026crwdne2947412:0
And the key worked once plugged in and the battery is reconnected?
Michael Sullivan - crwdns2934203:0crwdne2934203:0
These are great instructions. I had the dreaded ‘steering lock malfunction’ warning message on my 9-3. Bought an ISM off eBay for £35 and had it fitted and working fine in 2 hours. Thanks so much for posting.
Mike - crwdns2934203:0crwdne2934203:0
Instructuctions spot on. In 1.5hrs I had the ISM out, cleaned and back in. And no more steering lock errors. !!!
gtsmail951 - crwdns2934203:0crwdne2934203:0
Does anyone have advice on how to replace the ignition switch on a 1998 9.3 automatic transmission Saab
davina gammon - crwdns2934203:0crwdne2934203:0
Most of these steps are not necessary at all, you can pull the ISM out from the side when you have removed the side panel, its tight but more than possible. This is very easy, 3h is a joke it takes 30 minutes at most!
Filip Andersson - crwdns2934203:0crwdne2934203:0
My starting point was a Haynes manual. Not all the steps worked as described. The steps above will work. Three hours it took, and it didn’t feel like a joke. By the way, the Saab is still chugging along nicely (touch wood). Not missed a beat since the repair.
Glad you’ve found an easier way. For the rest of the mere mortals, me included, the above steps will work.
Lars Erlandsen -
Any clue as to why after install of new switch the key won't turn?
Ryan Nordbrock -
Does it need coding into car or is it just plug and go
Jason platten - crwdns2934203:0crwdne2934203:0
The steering wheel unit will need re-programming. However, the ignition switch that I replaced, listed above, needs no re-programming at all!
Lars Erlandsen -
Great instructions. I also had the ‘steering lock malfunction’ warning message on my 2011 soft top 9-3. Fixed by replacing the ISM with a used item from eBay for £38. If only Haynes instructions were this good!
David Saker - crwdns2934203:0crwdne2934203:0
Très bon tutoriel changement en 1H30 .
Merci beaucoup Lars
didier.vanelslande - crwdns2934203:0crwdne2934203:0
vous êtes les bienvenus (Google translation from “you are welcome”) :-)
Lars Erlandsen -
Thanks for this advice - it’s really well produced. However I can also vouch for the alternative method which just involves removing the side panels and carefully lowering the ISM out of the left hand side. In total the job took about 20-30 mins and the car is good as new now. I also removed the gear lever surround to give it a good clean. But still thank you as I did follow a few of your steps.
Jeff Hilton - crwdns2934203:0crwdne2934203:0
Thanks great photos and information is ism plug and play or needs re programming thanks Clive
Clive Briggs - crwdns2934203:0crwdne2934203:0
Hi, Clive.
The ignition switch in the center console is plug and play. The unit that is wrapped around the steering wheel, however, needs re-programming. I was warned this would involve a 4 figure sum of money, so I was happy my £120 key switch gamble replacement did the trick. And the Saab is still running. With the key switch working flawlessly…
Lars Erlandsen -
Thanks for the tips. I solved the same problem at the service station. But I installed the timing light for MSD ignition myself using your instructions.
William Clark - crwdns2934203:0crwdne2934203:0
Do i need to code/program it after replacement? What about keys, do they need to be coded again?
Robert Rupa - crwdns2934203:0crwdne2934203:0
Just read your instructions and followed them to the letter , many thanks
Julian Barnes - crwdns2934203:0crwdne2934203:0
Hello, do you know if a Tech2 reprogrammation is needed once ISM has been changed? Is it part of security components of the car?
Famille Ponal - crwdns2934203:0crwdne2934203:0
and is OBD fault “B3057 ox48” linked to ISM module issue?
Hi.
As I said in my tutorial, replacing the key module does not require any re-programming. If you replace the full security module around the steering wheel, it will need all re-programming…
Thanks,
Lars Erlandsen.
Lars Erlandsen - crwdns2934203:0crwdne2934203:0
The NIST frameworks were designed as flexible, voluntary frameworks. The fact that they are flexible makes it relatively easy to implement them in conjunction with ISO 27001.
This is largely due to both standards having a number of common principles, including; requiring senior management support, a continual improvement process, and a risk-based approach.
6 Clicks
Dillon Mitchell - crwdns2934203:0crwdne2934203:0
6 Clicks
I have a question. What issues were you having that made you replace it. I’m getting the steering wheel lock message and sometimes the car won’t start. I have to take the key out and put it back in and try again to start it. Also I don’t hear the steering wheel unit unlocking everytime like it used too. It says steering wheel locked but it’s not actually physically locked. I’m hoping it just needs a new ism.
Twinturbobmw 535xi - crwdns2934203:0crwdne2934203:0
For reference, this is exactly the scenario that I faced, and that made me replace the unit in the first place (and write the tutorial).
Lars Erlandsen -
I cant turn the key in my ignotion [2006 9-3 auto wagon runs sweet as a bell] . when I put the key in the ignotion the needles on the instrument panel dance/vibrate? ! Its liek the key has forgotten it belongs to the car Again. [this happened a few weeks ago, but it was with my mechanic and he simply re-programmed the key]. Do I need to go throiugh the busdiness of changing the ISM?
firefly - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 145
crwdns2942667:0crwdne2942667:0 34,905
