SONY WH-CH700N bluetooth headphones USB charging port Replacement
  1. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the foam pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the foam pad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the foam pad: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the foam pad by pulling up on the foam until it clears the groove.
    • Working around the foam, carefully slip it off to reveal the screws.
  2. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Open the headphones: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Open the headphones: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Open the headphones: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws holding the speaker enclosure to the main body.
    • Do not fully lift off as the speaker is still connected to the board.
  3. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the speaker (L) and desolder connections: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the speaker (L) and desolder connections: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the speaker (L) and desolder connections: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the speaker to fully remove it.
    • Desolder the mic and speaker conncetions
    • Desolder the battery connector.
  4. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the the board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the the board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Remove the the board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one Phillips screw, holding down the board
    • The board is also held in by clips, so use a prying tool or just fingers to pull upp on the board to release it.
  5. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Board view: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Board view: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Board view: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You successfully removed the main board.
    • You can see the damaged USB connector
  6. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Apply protective tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Apply protective tape: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply Kapton tape to ensure protect the plastic components like, switches and the jack conncetor.
  7. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Apply flux: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Apply flux: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply flux to the top pins and the mounting pins (underside) to help solder flow.
  8. SONY WH-CH700N bluetooth headphones USB charging port Replacement, Desolder the USB connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SONY WH-CH700N bluetooth headphones USB charging port Replacement, Desolder the USB connector: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the connector with tweezers and apply heat from the mounting pins' side (bottom).
    • Be careful with the hot air station and position the board in a way that you do not burn the jack connector while heating up the port.
    • 320 degrees (Celsius) with 20-30% airflow is more than enough to get the connector off.
    • Clean the pads with a solder wick.
crwdns2935229:05crwdne2935229:0
honakrisi
crwdns2935283:001/28/20crwdne2935283:0
3,730 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Very good tutorial, I'm looking for the WH-CH700N board, but cannot find any retailer for buying it. Do anyone knows any online shop or service that is selling it? Thanks
Juan A - crwdns2934203:0crwdne2934203:0
Do you still need a board?
Krooms -
thank you for an excellent guide. I am a volunteer at our local repair cafe where we try to repair things, free of charge, for residents and so avoid the item ending up in landfill. I have had a pair of the Sony WH -CH700N headphones in and need to replace the charging port. Sony will not supply. where can I get the right one? do you have a prat number? any help appreciated. many thanks Roger H
roger hutton - crwdns2934203:0crwdne2934203:0
Hi @rogerhutton
I found these to be a suitable replacement and fairly inexpensive:
https://www.ebay.co.uk/itm/132334638219
https://www.ebay.co.uk/itm/142512274587
Hope it helps!
Kris
honakrisi - crwdns2934203:0crwdne2934203:0
Thank you very much Kris. Ordered and fitted and a very happy resident to have them fixed at a cost of £2.50! Thank you again on his behalf and from the volunteers at the Dorking Repair cafe. all the best Roger H
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 3,202
