Roku 4 Ethernet Port Replacement
  1. Roku 4 Ethernet Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Ethernet Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Ethernet Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Ethernet Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Ethernet Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Ethernet Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Ethernet Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Ethernet Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Ethernet Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roku 4 Ethernet Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
    So where do I get the new mother board?
    cfasche - crwdns2934203:0crwdne2934203:0
    Later versions of the Roku 4 have a connector for the fan so you do not need a soldering iron.
    Ian West - crwdns2934203:0crwdne2934203:0
  10. Roku 4 Ethernet Port Replacement, Ethernet Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the motherboard facedown on the table so you can see the large black ethernet port with several gold connections below it.
    • Use a soldering iron to desolder each of the ethernet port's connections to the motherboard.
    • Consult iFixit's Soldering Skills guide to learn how to safely use the soldering iron.
  11. Roku 4 Ethernet Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your thumb and pointer finger, carefully pinch the Ethernet port and pull it to the right, away from the motherboard, to remove it.
Hank Harrison
crwdns2935283:003/26/17crwdne2935283:0
467 crwdns2915208:0crwdne2915208:0
Baylor, Team S5-G4, Williams Spring 2017 crwdns2935289:0Baylor, Team S5-G4, Williams Spring 2017crwdne2935289:0
BU-WILLIAMS-S17S5G4
Is that the HDMI port on roku
cruzanbay45 - crwdns2934203:0crwdne2934203:0
where do you get the HDMI port for roku
mar plane - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,223
