Right Joy-Con Joystick Replacement
  1. Right Joy-Con Joystick Replacement, Right Joystick: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the four tri-point Y00 screws from the back panel of the Joy-Con.
    • These screws are each 6.2 mm long, but it's still a good idea to keep them organized and make sure they go back in their proper holes!
    I found it easier to remove the rubber cover over the joystick before changing it, and to remove it on the replacement before installing it. So that would be step 1 for me next time.
    kmcrawford111 - crwdns2934203:0crwdne2934203:0
    Si tienes cuidado no hay que desconectar nada. Sólo el cable del joystick, evidentemente, todos los demás se pueden dejar conectados, sobre todo el de la batería para que te ayude a probar si todo funciona antes de cerrar y atornillar todo de nuevo.
    Te ahorras 15 minutos y muchas posibilidades de romper cosas.
    Víctor SLB - crwdns2934203:0crwdne2934203:0
    This is probably very obvious advice, but it takes a decent bit of pressure to get these screws out. Hold the controller and support under where the screw is with one hand while applying a good bit of downward pressure with the screwdriver in the other hand. Don't go crazy, but you don't have to be delicate. This was my first repair and this tripped me up for way too long.
    Maxwell - crwdns2934203:0crwdne2934203:0
  2. Right Joy-Con Joystick Replacement, Open the case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Open the case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Open the case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the lower side of the back panel (opposite the R and ZR buttons).
    • Slide the flat edge of an opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel has shallow interference-fit tabs on the side opposite the charging rail. These loosen fairly easily, so not much pressure is needed.
  3. Right Joy-Con Joystick Replacement, Open the case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Open the case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the Joy-Con like a book, with the charging rail facing away from you.
    • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
    • During reassembly, make sure the SL/SR cable is lightly bent under the battery compartment before clipping the two halves of the joy‑con together. Otherwise, you might crease the cable and damage it.
    What’s i do, when the cables are disconnected from the Motherboard?
    Bad Mann - crwdns2934203:0crwdne2934203:0
  4. Right Joy-Con Joystick Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
    • Be extremely careful while you pry up the battery connector. If it does not come up easily, try gently pulling on the wires to disconnect it.
    Could've done with a narrower spudger for this and on the way back
    James - crwdns2934203:0crwdne2934203:0
    The plug is difficult to get a spudger under and leads to a lot of failed attempts where something could be damaged. I found it comes apart easier if you gently pull the wires with tweezers.
    Robert L - crwdns2934203:0crwdne2934203:0
    Agree. The spudger is too wide for this task. This guide needs to get update with his better approach.
    Nick Cope -
    I damaged this connector while trying to remove by pulling on the wires as suggested. The plastic over the wires broke out. I was able to “repair” it by carefully placing the pins in place without shorting, covering the top (only) of the connector with a little super glue. After curing I placed it over the receptacle as closely as possible with tweezers, and gently pressed in with a pencil eraser tip.
    I like the narrower spudger idea, but have never seen one.
    Hey, I was wondering if you damaged the part that attaches to the motherboard because I’ve done that and I’m not sure how to fix it?
    Milli3 -
    Hey so when I did this step it turns out I pulled the entire battery connector out not like the wires or the plug in but the entire connector that connects to the motherboard. I was wondering if anyone knew if it was possible for me to fix this or if I’d have to buy yet another set of joycons :(
    Milli3 - crwdns2934203:0crwdne2934203:0
    Milli, unfortunately repairing that connector is a tough fix unless you’ve got some microsoldering equipment. :( That said! You shouldn’t need to buy a whole other set of Joy-Cons. What you can do is find a replacement motherboard online, or even a cheap used Joy-Con from ebay and replace your motherboard with that one! I’m sorry about your bad luck, I hope this helps!
    Taylor Dixon -
    You’re not alone in this. I gave up and found a new genuine single controller for $60 AU
    John Matthews -
    I did the same. I broke battery plug, then whole connector separated from motherboard. I purchased new joycon...
    Piotr Wysocki -
    I have fcuked my entire connector and ruined it. Never pull the battery connector and just make your mods with the battery attached!! Mind the wires, finish your job quickly, and forget about powering off your joycon during teardown..
    Kelvin Susanto - crwdns2934203:0crwdne2934203:0
    Not at all clear from the photo what it is I am pulling off. Need a larger, zoomed-in image.
    danbalzer - crwdns2934203:0crwdne2934203:0
    Maybe add a third photo, showing what the socket looks like once the connector is removed.
    danbalzer -
    Click any photo in this guide to zoom in. Here’s the connector photo.
    Jeff Suovanen -
    Es ist ein Steckkontakt. Sprich: Wenn du es wieder zusammenbaust, musst du das Kabel von oben reindrücken.
    anonymous 5632 - crwdns2934203:0crwdne2934203:0
    Skip this step. It is far too easy to pull off the connector from the motherboard. Ruined the joy of fixing it. There is enough length on the wires to just skip steps 4 (this step), 5, and 6 and jump to 7. It is what it is. I’m mad at myself.
    Fernando Pruneda - crwdns2934203:0crwdne2934203:0
    I struggled with this step too and thanks to your tip, skipped out steps 4, 5, 6, 7 and rejoining at 8. It was tricky with the wires and being delicate not to damage any connections, but saved me so much stress in reconnections or permanent damage.
    I also skipped out removing the ZR cable too. I guess the less I do, the less that could go wrong.
    Keen Hui -
    Same than Keen Hui here. The battery connector was jamed. I had difficulties to evaluate the risk of broke the connector vs the risk of letting the battery connected. Seems that i chose right by letting it there.
    Nicolas Boutin - crwdns2934203:0crwdne2934203:0
    Just pull up gently and it will come out, a spudger is too wide.
    anz - crwdns2934203:0crwdne2934203:0
    Have to agree that "just disconnect the battery, bro" is just a laughably bad oversimplification of how to remove this battery. A lot of tech gurus/youtubers gloss over this, and as you've seen here and likely across other places, the lack of clarification has caused TONS of people to break their joycon at this step. I ended up seeking help from the switch discord which game me some helpful tips.
    Use the pointed end of the spudger, the flat side is too big. Approach the connector from the corner side with the black cable. Pry directly up & towards you (do not let it slide), and again minimize contact with the wire. It won't always remove it it one "pop," but it may dislodge it enough to allow you to get under it better. You can even see this in the Ifixit video on youtube.
    Take your time with this.
    Yeldarb10 - crwdns2934203:0crwdne2934203:0
    Skip this step. Seriously. It’s unnecessary and risks damaging the connector entirely. You can just move the battery to the side (once you get to the next step) and it will still be out of your way enough.
    Deluxe Distrait - crwdns2934203:0crwdne2934203:0
    I wish I have skipped this part. I broke the battery plug, but hoped I will manage to reconnect. After replacement, trying to reconnect, I successfully removed the connector from motherboard.
    I purchased new pair of joycons, I will no longer fiddle with it, it is too fragile.
    All other steps were easy. Disconnecting battery was SUPER hard for me.
    Piotr Wysocki - crwdns2934203:0crwdne2934203:0
    I’d like more advice about how to reconnect the battery plug.
    JT19 - crwdns2934203:0crwdne2934203:0
    Echoing a lot of other comments, but yeah you don't need to remove the battery, even if you're new to this. These Joy-Cons were my first repair and you'll be fine just keeping the battery off to the side as long as you're careful.
    Like a lot of people have been saying SKIP THIS STEP! DO NOT DISCONNECT THE BATTERY!
    Especially not with the spudger since it is way too large.
    Just leave it plugged in and don´t break it like I did :(
    manon-gfx - crwdns2934203:0crwdne2934203:0
  5. Right Joy-Con Joystick Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The following two steps show the removal of the battery and the coaxial antenna cable from the midframe. These two steps make for a less cluttered repair, but are not essential. If you want, you can leave the battery and the grey coax cable in place here and proceed to step 7.
    • Insert an opening pick between the battery and the Joy-Con housing. Gently pry out the battery, which is lightly taped in place.
    • Be careful not to deform or puncture the battery—it can catch fire or explode if damaged.
    I don’t have a pick, just spudgers and blue plastic pry tools. There are gaps on the rail side of the battery where you can very easily get a spudger in and get the battery out.
    This step broke my rail cables and I am so mad that it wasn’t even necessary
    J S (J5) - crwdns2934203:0crwdne2934203:0
    I ended up doing steps 8 and 9 before pulling out the battery which bought it a fair bit away from the cables the other two are talking about. I’ve found the batteries are very hit-or-miss in how easy they are to get out, so just be cautious if you plan on doing things the way I did, since the rest of the joycon will be sitting loose as you get the battery out, and won’t have much leverage/stability. I’d still recommend getting the battery out (and NOT disconnecting the cables that are red and white) since it gives you a bit more room to work with
  6. Right Joy-Con Joystick Replacement, Remove the antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you perform this step, take note of how the antenna cable and its PCB are seated for proper reassembly later.
    • Carefully de-thread the upper half of the grey antenna cable out of the battery cavity.
    This step was basically necessary for me to get this plastic plate out, but you don't have to do the unplugging in the next step.
    What is this antenna for, anyway? It's not present on the left JoyCon. (2min edit: It's for NFC/amiibo)
    libewa - crwdns2934203:0crwdne2934203:0
  7. Right Joy-Con Joystick Replacement, Disconnect the antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up with the pointy end of a spudger to disconnect the antenna cable's coaxial connector from the motherboard.
    • Remove the grey antenna cable.
    • During reassembly, reconnect the antenna cable, then make sure it is routed through the battery cavity in the midframe as it was before you took it out.
    The antenna cable is very difficult to reconnect so if possible leave the coaxial connector connected
    Ethan Puente - crwdns2934203:0crwdne2934203:0
    You can also re-connect the coaxial cable before replacing the midframe
    Moose Juice -
    To add to Ethan's comment, reason #2 to leave the antenna connected is that it will greatly assist in reversing step #10.
    Eric Adams - crwdns2934203:0crwdne2934203:0
    Like the battery, don't unplug this if you can avoid it. It's easier to put back together if you keep things as attached as possible (though it can be a bit cluttered while you're doing the repair)
  8. Right Joy-Con Joystick Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.5 mm Phillips #00 screws on midframe.
    • Do not attempt to remove the midframe yet. There is a fragile cable that still connects the ZR button on the midframe to the motherboard underneath.
    These appear to be J00 (JIS #00) screws, not phillips
    matthew25 - crwdns2934203:0crwdne2934203:0
  9. Right Joy-Con Joystick Replacement, Remove the midframe: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the midframe: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip the midframe over and away from the motherboard.
    • Do your best not to stress the short ribbon cable attached to the ZR button during this step.
    At this stage, the R button pops off very easily. Almost inevitable. And when it does, you’ll probably lose the spring. Better to carefully take it off yourself and make sure the spring stays with it.
    Athul Acharya - crwdns2934203:0crwdne2934203:0
    Lift the midframe straight up, away from the motherboard, and keep a close eye on the ZR ribbon cable. Try—carefully—rotating the midframe so that the ribbon is not wrapped around the edge, then you can flip the midframe over and out of the way of the rest of the Joy-Con. This will give you a little more room to work without putting stress on the ribbon and without having to disconnect the ZR ribbon as described in the next step. You do not want to disconnect that ribbon unless you absolutely have to. It will suck to plug the connector back in later.
    synthmage - crwdns2934203:0crwdne2934203:0
    Agree. Reattaching the ZR ribbon was the hardest part of this repair. Wish I read your comment for the tip to avoid disconnecting it.
    Andrew Carlson -
    When putting this back in, watch out because it might have gotten flipped around, especially if you kept the ZR cable attached as I would recommend you do. Probably obvious, but it threw me off for a few minutes.
  10. Right Joy-Con Joystick Replacement, Disconnect the midframe: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the midframe: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the midframe: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ZR button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock.
    • Use tweezers to gently pull the ZR button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
    • The ZR button cable in this Joy-Con is short and can be tricky to reconnect. If you are worried about not being able to reconnect it, you can skip this step and leave it connected, which we recommend.
    • If you choose to leave the cable connected, be careful. Work slowly and do your best to keep the midframe from moving around as you perform the last few steps to avoid damaging the cable.
    Putting this back together was the hardest step
    Who knows an easy way to put this back in?
    Mr Krabs - crwdns2934203:0crwdne2934203:0
    My children learned to drive, went to college, got married and had children, by the time I got this to reconnect!
    I used the tweezers to carefully grab the end and slide it in. Make sure the lock is up because without the ribbon it falls down really easy.
    The left joy con is easy peasy compared to this one.
    Bethany Shillet - crwdns2934203:0crwdne2934203:0
    I think this step should warrant upgrading this from Moderate… I can’t understand why Nintendo decided to put SOO much slack on the left controller and then absolutely no slack on the right…
    errolsayre - crwdns2934203:0crwdne2934203:0
    I wasn’t remotely prepared for how much more difficult this was compared to the left Joy-Con. I ended up ruining the entire unit trying to reinsert the ZR cable into the zif connector.
    Andrew Ellis - crwdns2934203:0crwdne2934203:0
    I found this to be easier than the left joycon, maybe because I did the right joycon first. The cable is very rigid, so I just held the two parts of the joycon together so that the cable was already lined up with the connector. From there, you can make the final adjustment with tweezers, and the cable won’t fight you as much in the process.
    Charlie Lewis - crwdns2934203:0crwdne2934203:0
    Following your instructions, I finished it in less than a minute. I had been struggling with this step for a while. Thank you!
    Anup Upasani -
    Thank you so much for this description! I was finding it impossible until I did what you said… put the two parts of the joycon together and then get in between with the tweezer allowed me to get the connector in and then shut the ZIF
    Daniel C Henning -
    This is indeed a fantastic approach to handling this task. I'd like to also add that if you left the antenna connected from step #7, you can reseat its cable at this point which will stabilize the midframe from the end opposite the ZR button. You can then pivot the midframe upwards enough to give your tweezers room to get under there and manipulate the cable and ZIF lock.
    Eric Adams -
    maybe I’m being an idiot, but why does this have to be removed? I can get to the stick’s screws etc, and remove it and nothing seems to be in the way, thus making this step seem unnecessary. It was a little tricky to unscrew the joystick once the screws started to loosen, but I just propped the joycon up on my finger. There’s a risk to doing it this way, but then there’s a risk doing it either way, and judging from comments above about how awkward this is, maybe leaving it is best.
    N Carter - crwdns2934203:0crwdne2934203:0
    You’re definitely not being an idiot! It doesn’t technically need to be removed. :) That cable is so fragile though that the risk of leaving it connected with the midframe dangling awkwardly (as we leave it in step 9) seemed greater than the annoyance of disconnecting and reconnecting it. Definitely tricky and risky either way you slice it, though! Either way is a viable option. I’ll add a note to the step!
    Taylor Dixon -
    I think having a clamper that can hold the motherboard and the rest of the body really would help. I didn’t have anything that I could use but I propped it up with two jar lids so that the joystick would not make the whole thing wobble. I grabbed the midframe with one hand and used tweezers in the other hand to guide it in and close it.
    Here’s a picture: https://i.imgur.com/fSEIBqE.jpg
    My R button came off but I put it in before I screwed the midframe in place.
    I hope it helps.
    Kshitij Parajuli - crwdns2934203:0crwdne2934203:0
    This step should say in CAPITALS at the start that this is not strictly necessary, because the connector between the 2 boards is practically impossible to reconnect
    mcsmith1981 - crwdns2934203:0crwdne2934203:0
    Wouldn’t agree with people here - getting the ribbon back in is pretty finicky (much easier if you do it flipped over along the side, not like they have it in the photo), but I don’t see how you could get the joystick out and a new one in without moving it so much that you break it (then you’ve wasted the money on the kit and have to buy a whole new unit).
    I however would agree that you don’t need to disconnect the battery or antenna. I pulled the antenna patch out of the midframe and let it dangle, but left the battery in and connected, and it was fine. Much better than removing them but leaving this fragile thing connected.
    Isaac Woods - crwdns2934203:0crwdne2934203:0
    The grey plastic zif lock came off and I lost it. I replaced pretty much the entire contents of an iPhone 6, but couldn’t do this step. Don’t detach it if you don’t need to!
    Anyone know if I can get another one?!
    Nathan Trevivian - crwdns2934203:0crwdne2934203:0
    Lmfao… why would you recommend not doing it after instructing to do it? That note needs to come before. Wow
    Justin Cash - crwdns2934203:0crwdne2934203:0
    It wasn’t apparent to me from the pictures, but when reassembling, the exposed metal teeth on the ZR ribbon need to be facing DOWN as you re-insert. Be warned that the ZIF socket will accept it wrong way up, without protest.
    Dave Horlick - crwdns2934203:0crwdne2934203:0
    its very hard to do this with my super small hands
    Kristian Cala - crwdns2934203:0crwdne2934203:0
    Definitely skip this step, you can replace the joystick while this connector is in place. Will save you time, energy, and in the end, maybe save your joy-con ;-)
    Damien Bernard - crwdns2934203:0crwdne2934203:0
    I removed this completely and managed to break the gray ZIF connector. I was able to re-insert it (incidentally, it's extremely tiny & very easy to lose) but after getting the cable reinserted and the ZIF connector in place it was all very loose & the cable could fall out if i put any pressure on the cable. Figuring there was nothing to lose at this point, I used a very small amount of hot glue and tiny tweezers to keep pressure on the ZIF and cable and then pulled it out right as the glue started to harden... I have it fully re-assembled now and both ZR and R appear to be working correctly! i.e., if you get in a similar scenario with a bit of luck you might be just fine, granted hot glue is horrible to work with but... yeah at least one success story over here.
    Wesley Heim - crwdns2934203:0crwdne2934203:0
    I tried editing this step in the guide to have the warning about disconnecting at the beginning of the step instead of at the end (as many have commented) but my change got denied. Let the suffering continue.
    Damian Esteves - crwdns2934203:0crwdne2934203:0
    Just another comment to echo what folks above are saying: You absolutely positively do not need to disconnect the ZR ribbon to complete a joystick replacement, and the warning about this should be given before the instructions on disconnecting it. There is very little slack in the cable, but it's just enough that you can rotate the midframe holding the ZR button out of the way without putting excessive strain on the anything. Just work slowly and carefully, and you'll be fine.
    If you honestly didn't have any problems reconnecting the ZR ribbon, that's great and we're all happy for you, but you're clearly the exception.
    I didn't have a hard time getting the connector back in, but it wouldn't stay connected after the case closed. I'd recommend putting a small piece of electrical tape to keep it in.
    Mark N - crwdns2934203:0crwdne2934203:0
    I just broke the grey latch on this zif connector. great.
    jhef - crwdns2934203:0crwdne2934203:0
    COME ON ifixit! dum these down, please! There are tons of us that are noobs with these things.. hence the reason we need a guide.. . None of these pictures shows lifting the flap!? why not? its supposed to be a step by step guide? Then please show the steps? maybe? :-) :-P Pics needs to be a LOT more zoomed in, and show before, and after, so that people can understand what it looks like, what is to be done, and the result of that.
    Johan Kåre Stokka - crwdns2934203:0crwdne2934203:0
    Found it very helpful during this step of reassembly to first separate the two halves (top and bottom) of the JoyCon case by disconnecting the two ribbon cables attached to the charging rail. This allowed much more space to work with when reconnecting the ZR button’s ribbon cable, working from the side for better sight lines and tweezer insertion. Just needed to reattach the two charging rail ribbon cables thereafter, rejoining the two sides of the case, which was very simple.
    Michael Nickley - crwdns2934203:0crwdne2934203:0
    Just adding to the swarm but you do NOT need to do this step. Just be careful and mindful as you keep it off to the side. If that's difficult for you it might be easier to go through the (apparent) hell of taking it out and putting it back in, but for me it made more sense to just keep it in and be careful.
    Why would you not put the warning before the step to disconnect it??? Honestly...
    Brian McLean - crwdns2934203:0crwdne2934203:0
  11. Right Joy-Con Joystick Replacement, Disconnect the joystick: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the joystick: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Disconnect the joystick: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The joystick cable is also locked into place by a ZIF connector. Use tweezers or a spudger to flip the ZIF lock upward and carefully disconnect the cable.
    Recommend putting a small amount of electrical tape or masking tape on the tweezers to protect the ribbon cable during reinstallation.
    smichaeldavis - crwdns2934203:0crwdne2934203:0
  12. Right Joy-Con Joystick Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.5 mm Phillips #00 screws from the joystick.
    Also do your best not to bump the “R” button as it my fall out and you might break off the solid state device it activates. My device broke off as I was unaware of my hand placement while holding the controller. I recommend others learn from my mistake and hold the controller by the long edge only.
    Edmund Cooper - crwdns2934203:0crwdne2934203:0
  13. Right Joy-Con Joystick Replacement, Remove the joystick: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the joystick: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement, Remove the joystick: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the joystick from its housing.
    • There is a thin black gasket around the hole where the joystick pokes through the Joy-Con. Do your best not to disturb this gasket as you remove the joystick!
    • Once the Joy-Con is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick. Additionally, you may need to power cycle your Switch by holding down the power button for 10-15 seconds until it turns off, then turning it back on.
    The first time I tried to re-seat the new joystick, I had very slightly disturbed the black gasket (it ended up laying “on top” of the nearby wires, rather than underneath). This caused my joystick to register very slightly off-center after re-assembly. Once I took it apart again, gently slipped the gasket back into the right place, then the joystick registered perfectly centered. FYI!
    Geoffrey Potvin - crwdns2934203:0crwdne2934203:0
    I had the same experience as Geoffrey. My joystick was not able to be fully deflected downwards until I opened it back up and re-seated the gasket with the spudger. After reseating I’m also perfectly centered. Thanks for the tip!
    Truman DeYoung - crwdns2934203:0crwdne2934203:0
    Thanks! I had literally the same issue and reading your comments saved me doing this twice!!
    Luis Fernando Mata - crwdns2934203:0crwdne2934203:0
    This is literally my first ever repair and it went really well. Thanks guys. Although I would recommend not removing the zr cable, be gentle and save yourself the hassle of a tricky reconnect.
    Adsta Congrejo - crwdns2934203:0crwdne2934203:0
    This was the first repair my son (12yo) did. It would have been much too difficult to me (too small parts). I just helped him opening up the joystick in the end to clean it up internally. After assembly it worked again - no drift downwards any more…
    Mega Hertz - crwdns2934203:0crwdne2934203:0
    Use the pointy end of your spudger to hold the gasket in place while you pull the joystick out!
    Makes it much easier to perform the replacement without worrying about getting the gasket back in place if it pops out.
    Nicholas Fontaine - crwdns2934203:0crwdne2934203:0
    DO NOT disconnect the battery wires! They are almost impossible to get back in. My connector broke in the process. Now I need a new battery pack!
    Brett Saunier - crwdns2934203:0crwdne2934203:0
    I skipped the majority of the steps and it was much easier. Don't unplug the battery. Don't disconnect all of the ribbon connectors. Wear rubber gloves and use plastic tools. You can unscrew everything skipping all the disconnect steps. The only ribbon connector you'll need to disconnect is the joystick itself. Much less chance of breaking connectors. I did this for 2 pairs of joycons with no problems and no fuss.
    Brian Banister - crwdns2934203:0crwdne2934203:0
    The tiny spring for the Z button just pinged off and now it's lost forever 😔 can a replacement be ordered?
    Jo Cort - crwdns2934203:0crwdne2934203:0
    I did this many times. Now I have one joycon (right side) the stick won’t do anything. Several sticks testet. Neither connected to the switch, nor wireless. The buttons are working.
    The cable sits very tight in the connector. Can’t see anything.
    Any idea for this problem?
    Pättes - crwdns2934203:0crwdne2934203:0
    The rubber cap on the joystick is slightly larger than the opening in the black gasket in the controller housing, so it will deform momentarily as you're removing the joystick.
    Try to pull the joystick out at an angle, removing the side furthest away from the charging rail first. There is a small break in the black gasket that allows it to move out of the way on that side. The gasket is solid on the side closest to the charging rail, and there are very small wires routed over it that you will need to put back into place if the gasket slips over them while you're removing the joystick.
    So again, try to pull the joystick out through the opening at an angle, so that the part of the stick closest to the charging rail comes out last. This will give you the best chance of leaving the gasket placed correctly.
  14. Right Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you've replaced the joystick with a Gulikit module, follow the next two steps to install the included joystick ring sticker.
    • Use your fingers to pull the thumbstick off of the Gulikit joystick module.
  15. Right Joy-Con Joystick Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Joy-Con Joystick Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the ring sticker from its liner.
    • If the sticker center is still attached, separate and remove it from the ring.
    • Set the ring sticker in the joystick recess and press it with your fingers for a few seconds to attach it.
    How necessary is this step/the sticker? My kids took off with the sticker and lost it before I was able to install it so I went without. Haven't done any games since the repair but the calibration seemed to go just fine.
    Adam G - crwdns2934203:0crwdne2934203:0
crwdns2935229:0486crwdne2935229:0
Kyler Saunders
crwdns2935283:009/12/16crwdne2935283:0
4 556 crwdns2915208:0crwdne2915208:0
The.idoc.repair crwdns2935289:0The.idoc.repaircrwdne2935289:0
Business
crwdns2947412:066crwdne2947412:0
A good guide though for the antenna instead of disconnecting the cable it would be easier to simply slide out the plate and wire from the side of the battery tray
Tyler Karabin - crwdns2934203:0crwdne2934203:0
Agree with Tyler - no need to disconnect the antenna.
Thanks for the guide!
David K - crwdns2934203:0crwdne2934203:0
The antenna and battery don’t need to be disconnected, you can easily move them out of the way.
When reassembling, reconnecting the ribbon cable for the RL button is fiddly, easier if you can avoid disconnecting it as well. Just rotate the plastic battery plate a quarter turn counterclockwise to get it out of the way and access the analog stick.
You can test the controller immediately after seating the joystick to make sure the ribbon cable is properly connected.
Peter Amstutz - crwdns2934203:0crwdne2934203:0
In agreement with the others, antenna definitely doesn’t need to be removed. Also noticed that the Y000 bit worked a lot better than the Y00 for the outside screws.
Steve Cazier - crwdns2934203:0crwdne2934203:0
Hello I have followed the guide succesfully for the most part, however the joy con doesn’t seem to power up after reconnecting the battery and the anthenna. I even tried swapping the batteries between joy- cons and battery from the right one does work in the left one. The right joy con doesn’t turn on even with the other battery inserted. Any ideas?
kajterman - crwdns2934203:0crwdne2934203:0
If you are able to isolate that the battery from being the source of the issue, it unfortunately may be that the battery connector socket has some damage or was shorted. I recommend inspecting that part closely to see if there is any issue and use compressed air in the relevant area.
Cooper -
I think the issue is elsewhere, since I can’t even connect the joy con physically. The other one does work even when I take out the battery and insert it into the console. This one doesn’t.
kajterman -
I agree, it sounds like it’s not a battery issue. If the right one doesn’t work even when attached to the console there’s probably a shorted or broken connection in the power circuitry of the motherboard.
Andrew Ellis -
sounds like you might have ripped the battery connector from the board if it isnt powering up. i would double check that first if you've already tried the battery in another joycon,
Christodian -
Caution: it appears the new joycon have a revised analog stick and the older replacement sticks will Not work. This is from an evening of research and taking apart 5 controllers. Nothing official.
New joycon have an analog stick with an “H" pattern pressed into the metal back of the stick. Older replacement sticks have an “X" imprinted and older joycon look like they have an “#".
It looks like the “#" and the “X" are interchangeable but the cable on the “H" are thinner. So the motherboard won't accept the older thicker style.
I've spent a few hours on this and have broken two replacement sticks finding this out. I haven't found anything official about Nintendo changing the sticks but I guess they eventually would to prevent the drift issue.
Scott Nieman - crwdns2934203:0crwdne2934203:0
sorry, but this doesn’t seem to be the case in my experience. I have just removed a stick from a UK switch that I got on launch day, and this had the H shape on the back. I replaced it with a stick bought the other day off amazon that claims to be ‘new’ design and has a # shape on the back. This is my 1st time doing this but the connectors seem to fit and everything seems to be working. So I don’t know how you can conclusively say H is new and H and # don’t interchange, because in my case that’s not true.
N Carter -
just replaced original joy-cons marked H with replacement joysticks with # and working as they should.
Jacob Croxford -
Just chiming in with a differing experience. I have three left Joy Cons I bought at the end of 2017, one is the original from the Switch, two were bought separately. All three had the H stamped in the back, and all three were compatible with the #-stamped replacement parts I bought from the store here. I should have whipped out my calipers, but the ribbons didn’t feel any thicker.
I’m sure Scott is right: there are probably some early controllers that have a different style of connector, but I don’t believe the stamp shape is a reliable way to determine compatibility.
Scott: I hope you were able to repair your controllers!
Ben Etherington -
a good guide but instead of guiding you through the process of rescrewing and reconnecting everything you just say “yea follow the guide back”. I mean it worked for me but its still better to atleast give some tipps on how for example reconnect the battery, because i personally had the most trouble with it.
Daniel Aldushyn - crwdns2934203:0crwdne2934203:0
Daniel, that is definitely one of the drawbacks of our guides! What specifically did you struggle with while reconnecting the battery? I can add a reminder bullet to that step to help people in the future.
Taylor Dixon -
I agree, pulling out the cables is a lot easier than trying to slide them back in.
N Carter -
Nicely done. Thank you for sharing.
Fixed my joycon thanks iFixit!!!
Devan Miller - crwdns2934203:0crwdne2934203:0
good guide overall, but I messed up the battery connector socket and now it appears it needs to be soldered back on the board. It would have been great to have a better close up of that since it was unclear to me. Any suggestions on this more in-depth repair?
Nathaniel Wilson - crwdns2934203:0crwdne2934203:0
No problems completing this what so ever. I did opt to not disconnect the battery and antenna. Mostly because I was having issues getting the spudger near the battery connection. Thanks so much for the fantastic guide!
Cameron Sorbie - crwdns2934203:0crwdne2934203:0
hi! i’ve replaced the analog stick on my right joy-con, however, now the stick wont recognize a “click”/R3 input. i don’t know if i screwed it up or how the click is registered electronically. now i cannot calibrate the new stick, or use any R3 function. any ideas? :/
Joseph Leib - crwdns2934203:0crwdne2934203:0
just as a suggestion is there any corrosion where the ribbon cable goes into the board?
Coker Lisonbee -
Thanks for the guide! my only issue which doesn’t pertain to the guide itself but my new stick won’t fully center but I’m also not getting any drift either. Anyway thanks again for the guide, it was really straight forward and easy to understand. (edit: I did also calibrate the stick a few times to center but it still won’t.)
Coker Lisonbee - crwdns2934203:0crwdne2934203:0
I’m glad everything went smoothly for you! If you bought the joystick from us you can contact our customer service team and they’ll send you a replacement.
Taylor Dixon -
Worked great! Had a joystick that was drifting and the new part and guide fixed it perfectly. The one extra note I would make is to watch out for the top spring-loaded button popping out. It came out at step 9 and I was lucky I was able to find the spring. Just something to look out for. Thanks so much for the guide!
Kyle Hatlestad - crwdns2934203:0crwdne2934203:0
A good guide : changed the left and right joy-con with no problems. Just the left button’s spring that decided to pop out. But not a problem (I did not saw it at first).
Fabrice - crwdns2934203:0crwdne2934203:0
Missing from the recommended tools list — jeweler’s glasses! These components are TINY and it was nearly impossible to see what I was poking and pulling at.
Think I messed the battery part up when reconnecting. Works when attached but shows battery indicator as red and doesn’t work detached ?
M J - crwdns2934203:0crwdne2934203:0
Brilliant. This is literally the first thing I've repaired myself and it went really well. Thank you from a new right to repair fan.
Hallo ,
Ich hatte ein fixkit bestellt worin erst ein kaputtes Ersatzteil drinn war, habe aber direkt ein neues bekommen und konnte mein Nintendo jetzt erfolgreich reparieren
LG
Benny - crwdns2934203:0crwdne2934203:0
Hallo Benny,
super, dass alles geklappt hat! Viel Spaß mit deiner Switch.
Viele Grüße!
Fabian Neidhardt -
I bought 2 sticks from ifixit and both looked used and nether fixed the drift in the right joycon and ideas what it could be or do you thing i bought bad sticks
Kristopher Miller - crwdns2934203:0crwdne2934203:0
Took mine apart hoping to find a possible loose connection causing severe battery drain on my Joy-con. Nothing seemed out of place when I put it back together, but now the only button that works on it is the R3!!! Have no idea what I could have messed up, as I did not take the circuit board out at all. It lights up and pairs, but R3 only works, and when I check the calibration, the Joycon is pegged to the bottom right, will not move.
Joshua Bell - crwdns2934203:0crwdne2934203:0
-Update- took back apart, checked ribbon cables, and the arm on the Joystick ribbon cable was not locked, so that is fixed and the buttons work, but now they randomly activate without pressing them, and the SR and SL buttons do not work. I did not try taking out the main circuit board yet, but that is my next idea to reseat the buttons and check for possible broken ribbon cables. It will connect to the Switch, but only if I dock it to it.
Joshua Bell -
Great guide. I was able to get the joystick swapped and the controller buttoned back up. But upon testing it didn’t calibrate, and in a game it just spun in circles. Took it apart again to see I failed to plug the joystick into the board. Plugged it in, reassembled and all is good. Thanks for this service.
Alexander Hughes - crwdns2934203:0crwdne2934203:0
Thank you so much for this guide! My joy-con is working perfectly now. It was clear and concise but I agree with others and maybe state at the start which steps are optional. Still a novice when it comes to electronics, so any shortcuts would be most appreciated.
Keen Hui - crwdns2934203:0crwdne2934203:0
An absolute breeze with the iFixit Fix Kit! So happy to finally be rid of drift!!! :)
ishotjr - crwdns2934203:0crwdne2934203:0
Any tips for getting the new thumb stick ribbon in the ZIF slot? It refuses to go in. The catch is raised. I’ve even tried putting the old one back and that won’t slot in either! Please help!
Stuart Farquharson-Roberts - crwdns2934203:0crwdne2934203:0
Easiest way is to use some tweezers to hold the side tabs. This applies some pressure to the latch and you can wiggle the latch up and down. Should slot right in! But also the ribbon doesn't need to be 100% in. If you can get it 3/4 of the way in you should be fine.
Kyler Saunders -
Thank you Kyler, what are the side tabs? I’ve been jiggling the latch but the ribbon isn’t getting that far in for the latch to make any difference to the ribbon’s progress! Very frustrating!
Step 10 - the recommendation to not do this should probably come before instructing the user to do it. Lol
It’s definately worth indicating that disconnecting the antenna is an optional step, this can easily be skipped providing the person carrying out the repair is carefull with the cable.
MmmBe3r - crwdns2934203:0crwdne2934203:0
I agree 100% and was thinking the same thing.
Andrew Purkeypile -
Great guide, thank you! I want to mention that once you’re inside the Joy-Con the fasteners are JIS #000, not Phillips #00. A Phillips #00 will work in a pinch, but it does not fit well and can easily strip the head of the screw. Thanks again!
Andrew Purkeypile - crwdns2934203:0crwdne2934203:0
Do be careful of the R button not coming out of place, its not harmful if it does, but no one mentioned the module it interacts with being more flimsy than the ZR ribbon cable so now I’ve got an R button that doesn’t work. I hope this gets added to this guide soon.
Alejandro Gonzalez - crwdns2934203:0crwdne2934203:0
Thank you for the helpful guide! I’ve done this a couple times now — you’ve kept several joycons out of the trash!
Russ Williston - crwdns2934203:0crwdne2934203:0
I'm so glad I could help! That is great to hear it's really not that hard of a repair overall! :)
Kyler Saunders -
Great guide as usual folks! I've replaced my joystick but unfortunately the left-right and up-down movements are not registering. Pressing the joystick down, like a button, does work though. This makes me think I successfully connected the ribbon cables, so what did I do wrong?
Andrew Krelle - crwdns2934203:0crwdne2934203:0
Having accidentally disconnected the ZR button cable, I found it substantially easier to reassemble by removing the ZR button from the assembly. This involves pulling out the ZR button itself (being careful to keep the springs) and unscrewing a tiny daughterboard containing the electrical button (which has a very short silver screw - do not mix it up with the others). Once this board is free you can easily connect the cable, install the midframe, and then reinstall the ZR button.
David Griffin - crwdns2934203:0crwdne2934203:0
Hey, would I just follow the other tutorial in the repair manual?
Carlos T -
Do any of yall have tips on reinserting the ZR midframe connecter? I disconnected it, and didn't read the full manual about you can do the repair without disconnecting the midframe.
Carlos T - crwdns2934203:0crwdne2934203:0
Mine still has some minor drift. Is it my connectin or would it be the joystick?
Hudson Liao - crwdns2934203:0crwdne2934203:0
I wish I had seen the comments earlier about not needing to disconnect the antenna and the battery. The repair was flawless, but it would save me a lot of time 🤣
Kayke - crwdns2934203:0crwdne2934203:0
Hey Y'all, I recognize this is bad repair process on my part for not reading everything through beforehand, but in Step 10, maybe it would make sense to edit the guide so that other dummies like me don't remove the ZR cable connector before reading the footnote that says, "we don't recommend you do this". I'm having a heck of a time getting it back together. Either way, thank you very much for the guide! I've found it helpful, and I'm confident I'll get it all working eventually!
Chris Romeo - crwdns2934203:0crwdne2934203:0
I agree! Otherwise a great guide that helped me fix the joycons that had already been fixed once before by manufacturer and still were not working. Seems great now.
Alexander Moriarty -
I followed the steps and put the right joy con back together with a gulikit hall sensing joystick. When I calibrate the new stick, it reads the direction correctly for pressing up, left, and down. However, when I press the stick to the far right, the reading jumps between the far left and the far right in the calibration circle, even though I am only holding right. Is this a known issue with any solutions? I've calibrated it several times and have turned the switch on and off again.
Rhys Layman - crwdns2934203:0crwdne2934203:0
I'm having the exact same issue. After reassembling and calibrating the Joy-Con, when I have the joystick anywhere between about 30 degrees and 45 degrees clockwise from right, it starts jumping back and forth to the same position on the left side. Additionally, when I go to Calibrate Control Sticks, the stick sometimes starts slightly above center. I realize this comment is almost a year and a half old, but did you find a solution to this?
Zachary Burgoon -
Hello, many thanks. i just replace both left and right stick. i suggest the BT cable can be in place. there was no need to remove it.
Marceau - crwdns2934203:0crwdne2934203:0
When they say that battery connector is fragile, they mean it. I broke the connector and separated power socket from motherboard trying to disconnect battery. This very step requires a lot of skill I lacked. My old joycon is now useless, it was easier to purchase new one than soldier power to mobo.
I wish the advice to leave the ZR button connected was offered BEFORE the advice to disconnect it… I followed the steps in real time and now pretty much have a useless joycon because I wrecked the ZIF connector and have no way of putting it back. Any advice on if anything can be done about that by someone more professional than me?
Rico - crwdns2934203:0crwdne2934203:0
After following this guide the joycon works, but for some reason the leds don't.
Namba-Uan - crwdns2934203:0crwdne2934203:0
Just finished replacing the right joy con stick following this guide and everything (so far) has worked out perfectly. I didn't remove the mid frame since I didn't want to mess with any more ribbons than I had to. I did remove the battery as I didn't want to risk possibly shorting components but both disconnecting and reconnecting it was tricky. I had to "wiggle and push" the connector out from the base as the spudger was too wide and using flat head precision screwdrivers and the pointed end of the spudger, I still wasn't able to pry it up. Putting it back was tricky as I had to align, keep pressure to keep it flat and then push in from the back. The other tricky part, for me anyway, was connecting the ribbon cable joystick ribbon cable. I wasn't sure how far to push it into the ZIF connection and it never felt far enough in. But I got it as far as I could, set the lock and everything worked so I guess I did it right. Overall though, great guide and I've got a working controller without buying a new one!
Chris Gossett - crwdns2934203:0crwdne2934203:0
Much thanks to everyone who's written and contributed to this guide! It's my first time using ifixit and I think I'm hooked now! :)
Chris Gossett -
I let the battery run completely down and then didn’t need to disconnect it. That sucker is not easy. Just leave it connected.
Also, pay particular attention to the ribbon cable connect orientation as you remove them. This helps know how to reconnect later.
When reconnecting ribbon cables I had to get clever. It pays to be patient and delicate. Tweezers were required to insert some of the ribbon cables. The new joystick’s cable is quite cantankerous. I ended up using a spudger that has a curled tip and lightly tugged on the thicker part of the cable to pull it in the slot. Did this on left and right Joycons.
I am pretty good at this type of stuff and it took me about an hour for the right and half hour for the left.
Mark - crwdns2934203:0crwdne2934203:0
Hi I've installed the replacement joycon onto my switch and I am unable to calibrate the new joystick. I've updated the controller, my console is up to date and I've power cycled my switch so I have no idea what the problem is. Any advice is really appreciated!
Taylor Vail - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 159
crwdns2936753:07crwdne2936753:0 1,301
crwdns2936753:030crwdne2936753:0 5,840
crwdns2942667:0crwdne2942667:0 382,739
