Repair a Cracked or Buckled Polyurethane Surfboard
  1. Repair a Cracked or Buckled Polyurethane  Surfboard, Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard, Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set up your work area.
    • This repair process will get very messy. Do this outside, away from anything valuable.
    • It is nice to have a stable, firm platform to work on. I happened to have a homemade surfboard-shaping stand to work on.
    • Some of the materials you will be working with are hazardous if inhaled or touched. It is highly recommended to wear a mask and a respirator (a basic health one will do), gloves are optional.
  2. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove old foam and fiberglass with a sharp knife, utility knife, or really anything. I found that needle nose pliers work very well for grabbing and twisting.
    • You really have to just go at it. Don't be afraid to really dig in and use some force. At the end of this there will be a huge gaping section of your board missing.
  3. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you don't have your respirator and eye protection on, now is the time to put it on. Sanding the foam will create a cloud of tiny foam bits flying around.
    • Sand the inside foam that you just revealed with rough sand paper until it is vertical and flush.
    • Place the sandpaper through the crack and pull back and away from the crack. This will smooth down the edges of the thin fiberglass on the top and bottom.
  4. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will fill the crack with a series of small foam wedges.
    • Polyurethane Foam isn't easy to find. If you know a shaper or a local shop that works on boards you might be able to snag a few scrap pieces. Check online if that doesn't work out.
    • Use the surform to grind down the sides of the piece so that they are flat and parallel.
    • You want the wedge to barely fit into its position. You will really have to jam it in with some force. Be careful not to snap it though, as the foam is very brittle.
    • The wedge should be tall enough so that it extends out both the top and bottom of your repair area. The portion hanging out will be sanded down in a later step.
  5. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step until the wedges extend out past the rail.
    • Notice how each piece extends beyond the top and bottom of the board.
  6. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Trim down the overly excess pieces. Don't trim below the deck. This step will just make sanding a little bit easier.
  7. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put your eye and lung protection back on.
    • Sand the overhanging foam down with rough sand paper. Don't be afraid to hit the fiberglass, it will be fine.
    • Sand the foam so that there is a slight concave relative to the deck (or bottom of the board). This will be where the resin will sit.
    • Be careful around the rail. Use the fiberglass of the non-damaged rail to guide the shape of the foam here.
  8. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In your mixing cup, pour enough resin to cover the entire area thoroughly.
    • Mix in an even amount of Q-Cell filler and stir until well-mixed.
    • Once well mixed, add catalyst (hardener) as normal : i.e., 5-6 drops per 20ml of resin (a drop or two more if the weather is cold; a drop or two less if the weather is warm).
    • If doing a large mix (this repair is a large mix), you do not need to add as much hardener. 75% of the total will be fine as it is plenty to catalyze the reaction.
  9. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply mixture over the foam. Do not worry about overflowing slightly onto the board as this will be sanded off. However, do try to avoid runs.
    • Allow mixture to cure for 1.5 hours.
    • Repeat on the other side of the board.
    • You may want to place a piece of tape towards the rail to stop the resin from flowing over the rail. We will glass the rail in the next step.
  10. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To glass the rail, make a 'dam' out of tape. This will catch the resin and create a pool to cover all areas of the rail.
    • Using the same mixture ratio as in the previous step, fill the dam. When pouring in the mixture, make sure the top of the liquid is flush with the rest of the rail.
    • Wait and hour and a half for the resin to cure.
    This is not reglassing the rail, since you did not mention, nor illustrate, applying any fiberglass cloth to the area. This is simply filling the voids in the rail.
    Bruce Fleming - crwdns2934203:0crwdne2934203:0
  11. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all tape and begin sanding with rough grit sand paper.
    • Put some elbow grease into it. Small scratches around the repair will be buffed out later.
  12. Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Cracked or Buckled Polyurethane  Surfboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using finer grit sand paper, buff the repair and the area around it until smooth.
    • You're all done!
Ryan Kirkpatrick
crwdns2935283:009/29/15crwdne2935283:0
128 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-5, Green Fall 2015 crwdns2935289:0Cal Poly, Team 14-5, Green Fall 2015crwdne2935289:0
CPSU-GREEN-F15S14G5
This guide showed how to fill the gash, but stopped before showing/explaining how to re-glass over that area. If this repair is “done” without reglassing over the gash, that board will break soon, since the skin provides most of the structural strength and the gash interrupts that structure.
crwdns2942667:0crwdne2942667:0 13,153
