Remove the iRobot Braava Jet 240 Motherboard Case
  1. Remove the iRobot Braava Jet 240 Motherboard Case, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device off.
  2. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently pop out the battery.
  3. Remove the iRobot Braava Jet 240 Motherboard Case, Mop Pad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Mop Pad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the handle to reveal the eject button.
  4. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to push the eject button forward.
  5. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the robot on its side and let the mop pad slide out.
  6. Remove the iRobot Braava Jet 240 Motherboard Case, Front Shell: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Front Shell: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
    These screws have a non-threaded top. So they’ll move after unscrewing but not come out.
    At this stage it’s best to lift them and continue to unscrew until they’re removed as this makes removing the cover easier.
    Same for the other two 15mm screws.
    The Virtual Traveller - crwdns2934203:0crwdne2934203:0
  7. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull back on the front shell to remove it from the robot.
  9. Remove the iRobot Braava Jet 240 Motherboard Case, Back Shell: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Back Shell: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
  12. Remove the iRobot Braava Jet 240 Motherboard Case, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First pull up, then pull down on the spring to detach it from the hooks.
  13. Remove the iRobot Braava Jet 240 Motherboard Case, Remove the motherboard case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Remove the motherboard case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the iRobot Braava Jet 240 Motherboard Case, Remove the motherboard case: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up on the motherboard case and pull it forward to remove it from the device. This will expose the free-floating platform, as well as motors, water tubing, and the magnetic sensor pads.
Elven Decker
crwdns2935283:004/18/22crwdne2935283:0
291 crwdns2915208:0crwdne2915208:0
Etape 12 .................................. Poubelle !
laristochatbob - crwdns2934203:0crwdne2934203:0
Can you add more detail? We have disconnected and reconnected the spring multiple times. What was the tricky part?
Elven Decker - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,034
