Use this guide to replace a worn-out or dead battery in your Xiaomi Redmi Note 9 Pro.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
In this model, the flexible ribbon cables are routed directly over the battery. If the battery is swollen, it exerts significant upward pressure, stretching the cables and putting stress on the connectors. This often leads to fractured connector pins—a common secondary fault in these devices. If you notice even slight swelling, replace the battery immediately to prevent permanent damage to the logic board and connecting cables."
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top left corner of your phone.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top right corner.
Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
Remove the rear glass.
Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
Insert the tip of an opening pick underneath the left edge of the motherboard cover.
Flip the opening pick sideways to pry up the motherboard cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers or your fingers to remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a spudger to disconnect the power and volume button cable by prying the connector straight up from its socket.
Use your spudger to carefully fold the power and volume button cable to the side to free the battery.
Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Fold the display and the interconnect flex cable towards the charging port in order to get free access to both battery pull tabs and the battery.
Use a pair of blunt nose tweezers or a clean fingernail to peel down both battery adhesive pull-tabs to un-stick them from the top edge of the battery.
Grab the first pull-tab with a pair of blunt nose tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
Don't press down on the battery. Hold the phone firmly by its sides.
Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
Pull at a low angle so the strip doesn't snag on the edge of the battery.
Repeat the previous pull-tab removal procedure on the second pull-tab.
Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a spudger to gently lift the battery.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
crwdns2935229:024crwdne2935229:0
crwdns2947412:08crwdne2947412:0
hello, i think the guide could be very helpful, how ever, i don't know where to find the battery. can somebody help me please.
it would be very helpful, thank you in advance.
Roy Morris - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello Roy, sorry for the late reply, but in case you are still looking: The Xiaomi Redmi Note 9 Pro Battery is available in the iFixit Store!
Manuel Haeussermann - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
https://www.aliexpress.com/item/10050054... (select the model BN53)
Dani Mourinho - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
After I replace the battery, the phone just shows a blinking white led light.I put it charging all night but nothing happened. I managed to show the xiaomi logo and then the battery indicator showing the thunder icon blinking, and it seems it is not charging. I thought it was a faulty battery but I bought another replacement and I still have the same issue. I had to put my old battery to be able to keep using my phone. Does anybody what is the issue? thanks!
it looks that i had very bad luck with the batteries i tried earlier. I bought this one and worked fantastic! No blinking problem.Highly recommended: https://www.aliexpress.com/item/10050054... (select the model BN53)
