Rear Cameras Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Rear Cameras Removal, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Rear Cameras Removal, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second pick at the bottom right corner.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Rear Cameras Removal, Heat the left edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Rear Cameras Removal, Separate the left adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the left adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Slide your pick toward the top left corner to separate the adhesive.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  11. Rear Cameras Removal, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth opening pick at the top left corner.
    • Rotate it around the top left corner to separate the adhesive.
  13. Rear Cameras Removal, Separate the top adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the top adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick to the top right corner to separate the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Rear Cameras Removal, Separate the flash adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the flash adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the flash adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There's a remaining patch of adhesive directly under the flash.
    • Line up the tip of an opening pick with the flash cutout.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • You should see the opening pick through the flash cutout.
    • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
    • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
  15. Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  17. Rear Cameras Removal, Disconnect the NFC antenna: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the NFC antenna: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the NFC antenna press connector.
  18. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  19. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
    • Pry up to unclip the loudspeaker from the frame.
  20. Rear Cameras Removal: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  21. Rear Cameras Removal, Disconnect the battery: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the battery: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the battery press connector.
  22. Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the earpiece speaker press connector.
  23. Rear Cameras Removal, Remove the earpiece speaker screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  24. Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of your spudger between the bottom edge of the earpiece speaker and the sliver shield on the motherboard.
    • Don't insert your spudger anywhere else or you risk dislodging fragile surface‑mounted components.
    • Twist the spudger to unclip the earpiece speaker from the frame and remove it.
    • During reassembly, insert the top end of the earpiece speaker into the frame first before pressing down and clipping it back in.
  25. Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the primary and secondary interconnect cable press connectors from the daughterboard.
  26. Rear Cameras Removal: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the primary and secondary interconnect cable connectors on the motherboard.
  27. Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the interconnect cables.
  28. Rear Cameras Removal, Disconnect the antenna: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the antenna: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of your spudger between the left edge of the antenna press connector and the sliver plate on the motherboard.
    • Fragile surface mounted-components surround this connector. Prying on other edges of this connector risks dislodging them from the board.
    • Pry up and disconnect the antenna press connector.
  29. Rear Cameras Removal, Disconnect the display and antenna cables: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the display and antenna cables: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the display and antenna cables: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the display and 5G mmWave cable press connectors from the motherboard.
  30. Rear Cameras Removal, Disconnect the front camera: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the front camera: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to pry up and disconnect the front camera press connector.
  31. Rear Cameras Removal, Remove the motherboard screws: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the motherboard screws: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the motherboard.
  32. Rear Cameras Removal, Remove the motherboard: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of your spudger between the top edge of the motherboard and the frame, near the earpiece speaker cutout.
    • Twist the spudger to lift the motherboard up and out of the frame until you can grip it with your fingers.
    • Remove the motherboard.
    • During reassembly, make sure all of the cables are out of the way before placing the motherboard back into the frame.
  33. Rear Cameras Removal, Remove the ultrawide camera: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the ultrawide camera: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The three rear cameras are slotted into each other and should be removed from top to bottom.
    • Flip over the motherboard to expose the rear camera press connectors.
    • Use the point of a spudger to pry up and disconnect the ultrawide camera press connector.
  34. Rear Cameras Removal: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ultrawide camera is hooked into the motherboard and the main camera by metal pegs.
    • While holding the motherboard, lift the ultrawide camera out of its peg holes and remove it.
  35. Rear Cameras Removal, Remove the main camera: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the main camera: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the main camera: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the main camera press connector.
    • Lift the main camera off the motherboard and remove it.
  36. Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the telephoto camera press connector.
    • Lift the telephoto camera off the motherboard and remove it.
    • During reassembly, reinstall the rear cameras in the opposite order so they slot into each other properly (Telephoto → Main → Ultrawide)
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174,544 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,998crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 12
