Rear Cameras Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Rear Cameras Removal, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Rear Cameras Removal, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick next to the first one, near the bottom of the right edge.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Rear Cameras Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
  8. Rear Cameras Removal, Heat the left edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Rear Cameras Removal, Separate the left adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the left adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the left adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick next to the second one, near the left side of the bottom edge.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Rear Cameras Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
    • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
    • Leave the pick inserted near the power button to prevent the adhesive from resealing.
  11. Rear Cameras Removal, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Rear Cameras Removal, Separate the top adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the top adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the top adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top of the right edge.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  13. Rear Cameras Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the top edge to separate the adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
  14. Rear Cameras Removal, Separate the remaining adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the remaining adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the remaining adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the cameras.
  15. Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Four screws securing the wireless charging coil
    • Six screws securing the loudspeaker
  18. Rear Cameras Removal, Separate the coil adhesive: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the coil adhesive: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
  19. Rear Cameras Removal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to separate the tab from the frame.
  20. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
    • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
    • Pry up to unclip the loudspeaker from the frame.
  21. Rear Cameras Removal: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  22. Rear Cameras Removal, Disconnect the battery: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the battery: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery press connector.
  23. Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
  24. Rear Cameras Removal: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
  25. Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the interconnect cables from the phone.
  26. Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the earpiece speaker press connector.
  27. Rear Cameras Removal, Remove the earpiece speaker screws: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  28. Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger under the bottom edge of the earpiece speaker, under the engraved arrow.
    • Pry up with the spudger to unclip the speaker and remove it.
    • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
  29. Rear Cameras Removal, Remove the display cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the display cable: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
  30. Rear Cameras Removal: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the display cable press connector from the daughterboard.
    • Remove the display cable.
  31. Rear Cameras Removal, Disconnect the lower antenna: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the lower antenna: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the lower antenna press connector from the motherboard.
  32. Rear Cameras Removal, Disconnect the stylus port: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the stylus port: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the stylus port press connector from the motherboard.
  33. Rear Cameras Removal, Disconnect the upper antenna: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the upper antenna: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the upper antenna press connector from the motherboard.
  34. Rear Cameras Removal, Disconnect the fingerprint scanner: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the fingerprint scanner: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the fingerprint scanner press connector from the motherboard.
  35. Rear Cameras Removal, Disconnect the front camera: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the front camera: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the front camera press connector from the motherboard.
  36. Rear Cameras Removal, Remove the motherboard screws: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws securing the motherboard:
    • One 4.0 mm-long screw to the left of the top camera.
    • One 3.5 mm-long screw to the left of the bottom camera.
  37. Rear Cameras Removal, Remove the motherboard: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a spudger to lift the top of the motherboard.
    • Remove the motherboard.
    • Be careful not to catch on any loose cables.
    • During reassembly, be sure all press connectors are above the motherboard when reinserting it.
  38. Rear Cameras Removal, Disconnect the rear cameras: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the rear cameras: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the motherboard to expose the rear camera press connectors.
    • Use a spudger to pry up and disconnect the primary telephoto camera press connector.
  39. Rear Cameras Removal: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the secondary telephoto camera press connector.
  40. Rear Cameras Removal: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the main camera press connector.
  41. Rear Cameras Removal: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the ultrawide camera press connector.
Spencer Pennington
crwdns2935283:009/09/23crwdne2935283:0
19,228 crwdns2915208:0crwdne2915208:0
crwdns2935297:0114crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,712crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 30
