Rear Cameras Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Rear Cameras Removal, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Separate the right adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Rear Cameras Removal, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second pick at the bottom right corner.
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Rear Cameras Removal, Heat the left edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Rear Cameras Removal, Separate the left adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the left adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Slide the pick toward the top left corner to separate the adhesive.
    • Leave the pick near the top left corner to prevent the adhesive from resealing.
  11. Rear Cameras Removal, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Rear Cameras Removal, Separate the top adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the top adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth opening pick at the top left corner.
    • Slide the pick toward the top right corner to separate the adhesive.
    • Leave the pick near the top right corner to prevent the adhesive from resealing.
  14. Rear Cameras Removal, Separate the rear mic adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Separate the rear mic adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There's a square of adhesive around the rear microphone, just above the flash.
    • Line up the tip of an opening pick with the flash.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
  15. Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the back cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the back cover.
    • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
    • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
  16. Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  18. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
    • Pry up to unclip the loudspeaker from the frame.
  19. Rear Cameras Removal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the loudspeaker away from the frame.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  20. Rear Cameras Removal, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery press connector.
  21. Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
  22. Rear Cameras Removal: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
  23. Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the interconnect cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the interconnect cables from the phone.
  24. Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the earpiece speaker: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the earpiece speaker press connector.
  25. Rear Cameras Removal, Remove the earpiece speaker screws: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker screws: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  26. Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the earpiece speaker: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the bottom edge of the earpiece speaker and the metal plate on the motherboard.
    • Twist the spudger to unclip the earpiece speaker from the frame and remove it.
    • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
  27. Rear Cameras Removal, Disconnect the upper antenna: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the upper antenna: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger under the top left corner of the upper antenna press connector.
    • Do not insert the spudger anywhere else to avoid damaging surface-mounted components.
    • Pry up and disconnect the upper antenna press connector from the motherboard
  28. Rear Cameras Removal, Disconnect the front camera: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Disconnect the front camera: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger under the bottom right corner of the front camera press connector.
    • Pry up and disconnect the front camera press connector from the motherboard.
  29. Rear Cameras Removal, Disconnect the display and lower antenna: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the display and lower antenna: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Disconnect the display and lower antenna: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the display and lower antenna cable press connectors from the motherboard.
  30. Rear Cameras Removal, Remove the motherboard screws: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the motherboard screws: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the motherboard.
  31. Rear Cameras Removal, Remove the motherboard: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the motherboard: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the top edge of the motherboard and the phone frame, in the earpiece speaker cutout.
    • Pry against the frame to lift the motherboard out of its slot and remove it.
    • During reassembly, make sure all of the cables are out of the way before placing the motherboard back into the frame.
  32. Rear Cameras Removal, Remove the ultrawide camera: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal, Remove the ultrawide camera: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The three rear cameras are slotted into each other and should be removed in the following order: ultrawide, main, telephoto.
    • Flip over the motherboard to expose the rear camera press connectors.
    • Use a spudger to pry up and disconnect the ultrawide camera press connector.
    • The ultrawide camera is the top camera when installed.
  33. Rear Cameras Removal: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rear Cameras Removal: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ultrawide camera is hooked into the motherboard with two metal pegs.
    • Slide the pegs on the ultrawide camera out of their holes in the motherboard to remove it.
  34. Rear Cameras Removal, Remove the main camera: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the main camera: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the main camera: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the main camera press connector.
    • The main camera is in the middle.
    • Lift the main camera off the motherboard and remove it.
  35. Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Cameras Removal, Remove the telephoto camera: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the telephoto camera press connector.
    • The telephoto camera is the bottom camera when installed.
    • Lift the telephoto camera off the motherboard and remove it.
    • During reassembly, install the rear cameras in the following order so they slot into each other properly:
    • Telephoto (small camera with metal back)
    • Main (large camera with metal back)
    • Ultrawide (plastic back)
Spencer Pennington
crwdns2935283:009/09/23crwdne2935283:0
19,139 crwdns2915208:0crwdne2915208:0
crwdns2935297:0114crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021,097crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 22
