Razer Naga Epic Chroma Side Button Connection Strip Replacement
  1. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Mouse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
    Thank you for this guide! I was able to get my mouse from 2014 open and clean it out
    Spam Account - crwdns2934203:0crwdne2934203:0
  5. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
    Also, you’ll want to carefully remove the foam from the battery for reuse.
    Dan Mergens - crwdns2934203:0crwdne2934203:0
  6. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord from the circuit board in the mouse.
    Did you find a replacement? Couldn't find a dealer for this battery
    Doc Brown - crwdns2934203:0crwdne2934203:0
    Reposting from below: https://www.amazon.com/gp/product/B0767K... - for this battery you’ll need to switch the battery leads to match the polarity.
    Dan Mergens -
    Also, you should remove the tape, or provide your own for the replacement battery.
  7. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
  8. Razer Naga Epic Chroma Side Button Connection Strip Replacement, Side Button Connection Strip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the battery, remove the two screws holding the battery mount in place.
    • Remove the battery mount.
  9. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip open the black locking flap on either end of the white connection strip holding the side buttons onto the circuit board.
  10. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the white connection strip out of both connection ports.
  11. Razer Naga Epic Chroma Side Button Connection Strip Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the blue tab of the new white connection strip into both white connection points.
To reassemble your device, follow these instructions in reverse order. Test your mouse to ensure the connection strip is set up correctly; if not, go back and make sure that all of the wires were re-connected successfully.
Jordan Morgan
crwdns2935283:001/19/17crwdne2935283:0
895 crwdns2915208:0crwdne2915208:0
Arkansas State University, Team 1-4, Chamberlain Spring 2017 crwdns2935289:0Arkansas State University, Team 1-4, Chamberlain Spring 2017crwdne2935289:0
ARSU-CHAMBERLAIN-S17S1G4
Where can i buy a new Strip?
Rathura - crwdns2934203:0crwdne2934203:0
Did you find the strip? Im looking or it as well.
Tsuki Yomi -
crwdns2942667:0crwdne2942667:0 2,778
