This guide will show you how to replace a broken or malfunctioning connection strip. Before attempting the process in this guide, be sure to check that your mouse's drivers are up to date, the mouse's buttons are already connected properly and there are no other issues.
There will also be instructions on how to remove and replace a "swollen" or otherwise damaged battery, as the battery will be removed in order to reach the connection strip.
Exercise caution while following the procedure to avoid damaging other components. Additionally, be sure to handle the battery carefully, as a swollen battery is subject to combustion if punctured or subjected to extreme temperatures or other conditions.
Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Use a Phillips #00 screwdriver to remove the four screws.
Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
Gently pull up on the right plate on the mouse; separating it.
Carefully repeat this step for the left side.
Thank you for this guide! I was able to get my mouse from 2014 open and clean it out
Take your nylon spudger to gently pry the battery pack from the device.
Remove the foam on the battery shell for your new battery.
Also, you’ll want to carefully remove the foam from the battery for reuse.
Unplug the power cord from the circuit board in the mouse.
Did you find a replacement? Couldn't find a dealer for this battery
Reposting from below: https://www.amazon.com/gp/product/B0767K... - for this battery you’ll need to switch the battery leads to match the polarity.
Also, you should remove the tape, or provide your own for the replacement battery.
Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
Insert the new battery into the battery socket.
Place the foam on the surface of the new battery (reference Step 5).
Under the battery, remove the two screws holding the battery mount in place.
Remove the battery mount.
Flip open the black locking flap on either end of the white connection strip holding the side buttons onto the circuit board.
Gently pull the white connection strip out of both connection ports.
Insert the blue tab of the new white connection strip into both white connection points.
To reassemble your device, follow these instructions in reverse order. Test your mouse to ensure the connection strip is set up correctly; if not, go back and make sure that all of the wires were re-connected successfully.
Where can i buy a new Strip?
Did you find the strip? Im looking or it as well.
