This guide outlines how to remove the lithium-ion battery in the Razer Blade Stealth 2017. Battery replacement may be necessary if the battery is not charging, not powering the computer, swollen, leaking, or not lasting as long as you would like. Some tools are required for this replacement.
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Remove the bottom cover of the laptop by sliding it away from the hinge.
Use your fingernail to pry up and disconnect the battery from the motherboard.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Do you have to remove the battery before swapping the wifi card? Is disconnecting the power not enough?
Hi Charles,
If you’re swapping the Wi-Fi card, you don’t need to remove the battery. Disconnecting it will suffice.
Are two of these screws shorter than the other four? And if so, where do the two shorter screws go?
Looks like the two shorter screws go where the trackpad is!
Use the plastic spudger to pry out the battery.
After removing the 6 screws securing the battery, mine does not come out easily. There is resistance, and I don't wanna forcefully pull it out. Is it supposed to be easy to pick up and take out or is there some sort of tape holding it down from the bottom?
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:016crwdne2935229:0
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
Where did you get the replacement battery? The replacement we purchased for two Razer units about a year ago worked fine, but a replacement battery purchased online about a month and a half ago from Amazon is showing the same issue. Essentially, it's not detected by the operating system at all, or only very rarely. Looks like a bad batch of batteries from wherever these sellers are getting their supply.
