A guide to remove and replace the battery for the Razer Blade RZ09-0102. You may want to replace your battery if the battery cannot hold a charge or drains after an unreasonably short time. The battery needs to be removed if working on other components as well.
Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
Remove the back cover.
Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
Unlock the ZIF connectors securing the right ribbon cable.
Carefully pull the two ribbon cables out of their sockets.
Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
You know where I can buy that kind white ribbon, it hard find anywhere.
Carefully pull out the two connectors out of their sockets.
Pull the wide battery connector towards the battery to disconnect it from the motherboard.
Remove the battery from the laptop.
I lost some of the screws! What are the right replacement screws for the back cover and the battery?
For optimal performance, after completing this guide, calibrate your newly installed battery.
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
I need the screws is there any way I can get them?
Lupita Muro - crwdns2934203:0crwdne2934203:0
