This guide will walk you through the process of removing a battery from your Razer BlackWidow V3 Pro.
If your battery is swollen, take precautions.
Make sure to calibrate your new battery.
Dispose your e-waste responsibly.
Turn off your keyboard
Remove the keycaps using either a keycap puller or your hands
Repeat until all keycaps are off
Peel the lower-right rubber feet off just enough to reveal the 9mm Phillips screw.
Unscrew the 9 mm Phillips screw underneath.
Remove the 15 7 mm Phillips screws
Lift the top of the keyboard up and slightly to the front.
While pushing up, watch the LED on the front (circled red on the 2nd picture) and make sure it doesn't get damaged while removing the lid.
Flip up the black locking flap on the ZIF connector using a fingernail or a spudger, then carefully pull out the ribbon cable.
Carefully pull out the wires.
Remove the top housing entirely.
Peel off the black plastic covering the battery.
Remove the battery connector from the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your hands or tweezers to remove the wires from the mount.
The battery is held on with adhesive in the middle, as highlighted. direct your iOpener / heating device, and your tools in this general area to remove the battery.
Heat and place an iOpener or other heating device (Hair Dryer / Heat Gun) under the general location of the battery's adhesive.
For your reference, the red box is the general location of where the adhesive of the battery is.
For your reference, the black box is where the iOpener is.
Use a spudger to cut the adhesive, or if you have a suction cup, you can pull the battery directly up without risking puncturing the battery.
Use an iFixit opening tool (or flat end of your spudger) to lift the battery up.
Remove the battery carefully.
Recycle responsibly, it may be the law in your area.
Make sure to calibrate your battery.
I didn't attach a battery in the parts section for a reason. I found one site selling the exact same model number for the Razer BlackWidow V3 Pro battery, but it was from a site I've never seen before and zero reviews on trustpilot. I'll attach it here just in case, but buying it is at your own risk and you may not get what you ordered.
FT5936E2P Battery Replacement For Razer RZ03-0282 Wireless Keyboard (anvone.com)
I really don't know who is going to use this, but here's their battery supplier for who it becomes useful to (Although I don't take responsibility to if this source is reliable or not, it was just a quick Google search :))
op_ -
Any idea where to get a New battery from a trustable seller ? Thanks !
What are the dimensions of the original battery?
What do the 3 wires connect to?
Would a larger battery fit?
