Use this guide to replace a dead or worn-out battery in your Polaroid I-2.
Lithium-ion batteries have a limited lifespan. If your camera doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
The clips securing the plastic covers are strong and require significant prying. Don't use metal tools to avoid marring the plastic.
This guide requires discharging the flash capacitor to avoid being accidentally shocked during disassembly. Be sure to follow the directions carefully to ensure the capacitor is discharged properly.
            If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
            Before you begin:
            Power down and unplug your camera.
            Put on the lens cap to avoid scratching your lens during disassembly.
            Use the latch on the left side of the camera to open the film door.
            Fold a piece of cloth or napkin (or the included bag) into a small square.
            Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
            Flip the camera over, making sure the cloth stays lodged in the film compartment.
            Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
            Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
            Tilt the pick up and push to position the pick between the bottom and front covers.
            Slide the opening pick toward the rear of the camera to release the clips along the left edge.
            Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
            Insert the tip of a second opening pick under the top right corner of the bottom cover.
            Slide the opening pick toward the rear of the camera to release the clips along the right edge.
            Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
            Remove the back cover.
            Insert the flat end of a spudger between the film door's left hinge and the frame.
            Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
            Pull the film door towards the front of the camera to completely disconnect its left hinge.
            Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
            Remove the film door.
            Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
            Insert a spudger between the frame and the alignment hole on the back cover.
            Twist the spudger to lift the back cover off of the alignment peg.
            Repeat for the second alignment peg.
            There are eight large clips that secure the back cover. The next four steps show how to release them.
            Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
            Push the pick up to get it above the overhanging lip in the back cover.
            While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
            While pushing the pick downward, slide it all the way up the right edge to release the clips.
            Leave the pick at the top corner before continuing to prevent the clips from resecuring.
            Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
            While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
            While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
            Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
            Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
            Use tweezers to pull the interconnect cable out of its slot in the control board.
            Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the top cover.
            Angle an opening pick upward and insert in the gap at the top right corner of the top cover and front cover, next to the flash.
            Leave the pick in the gap before continuing to prevent the clips from re‑engaging.
            Angle a second opening pick upward and insert in the gap at the top left corner of the top cover and front cover.
            Leave the pick in the gap before continuing to prevent the clips from re-engaging.
            Insert the flat end of a spudger between the frame and the top cover's left external clip, above the viewfinder.
            Twist the spudger to release the clip.
            Insert the tip of an opening pick between the frame and the top cover's right external clip.
            Pry up to release the clip.
            Pull the lens cap off and remove it.
            Lift the top cover off the camera and remove it.
            Use a Phillips screwdriver to remove the four screws securing the front cover:
            Two 5.9 mm-long screws along the back edge of the front cover
            Flip your camera over.
            Two 3.9 mm-long screws under the front of the camera
            Pull the front cover away from the lens to release the clips along the front edge and slide the viewfinder out of its cutout.
            Use tweezers, or your fingers, to push the lidar sensor bracket toward the lidar sensor and off its alignment pegs.
            Remove the lidar sensor bracket.
            Lift the rear of the front cover while pulling the entire cover toward the front of the camera to separate it from its lip under the lens.
            Lift the front of the cover over the lens.
            Slide the front cover toward the rear of the camera until the back edge clears the viewfinder.
            Remove the front cover.
            If you're disassembling further, put the lens cover back on to prevent scratching the lens.
            To minimize the risk, make sure to either discharge the capacitor properly before continuing, or wear rubber gloves for added protection.
            Remove the tape covering the battery connector at the top of the main board.
            The battery connector is located on the inside of the main board.
            Insert the tip of a spudger under the head of the battery connector, where the cables meet the head itself.
            Pry up to disconnect the battery.
            Pull the lidar sensor up and out of its slot in the frame.
            Rotate the sensor so its exposed board is facing upward and let it hang over its slot.
            Use the point of a spudger to "walk" the lidar sensor cable connector out of its socket until it's disconnected.
            Remove the lidar sensor.
            Use a Phillips screwdriver to remove the two 5.9 mm-long screws securing the viewfinder, one near the front of the viewfinder and the other along the side.
            Push the lidar sensor cable down through its slot in the frame.
            Reposition the lidar sensor cable so the viewfinder can move sideways without snagging it.
            Grip both ends of the viewfinder, making sure to secure the cable connector with your fingers.
            Pull the front of the viewfinder away from the camera and out of its recess.
            Flip the viewfinder over to access its ZIF connector on the bottom of it.
            Use the tip of a spudger to lift up the locking flap on the viewfinder ZIF connector.
            Use tweezers to pull the viewfinder cable out of its slot.
            Remove the viewfinder.
            Use the flat end of a spudger to lift up the locking flap on the lens assembly ZIF connector.
            Use tweezers to pull the lens assembly cable out of its slot in the main board.
            Use a Phillips screwdriver to remove the four 5.9 mm-long screws securing the lens assembly:
            Two screws along the top of the lens
            One screw under the lens
            One screw along the left edge of the camera, under the capacitor.
            Pull the lens assembly toward the front of the camera until it slides out of its alignment peg.
            Rotate the left side of the lens assembly up to separate the capacitor from its slot in the frame.
            Pull the lens assembly out of its slot in the frame and remove it.
            Use the point of a spudger to push the cables down and out of the clips.
            Use tweezers to pull the cables one-by-one out of their recess and let them rest on the motor.
            Peel up the black tape covering the battery and let it stick to the frame before continuing.
            Insert the flat end of a spudger under the left edge of the battery.
            Twist the spudger to separate the adhesive enough to grip the battery with your fingers.
            Grip the end of the battery and lift up to separate the remaining adhesive.
            Remove the battery.
            Use your fingers or blunt-nose tweezers to peel off the adhesive pad from the bottom of the battery.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
