PlayStation Portal Speaker (Left) Replacement
  1. PlayStation Portal Speaker (Left) Replacement, Power off your PlayStation Portal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Power off your PlayStation Portal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your PlayStation Portal's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • If your battery is swollen, take appropriate precautions.
    • Power off your Portal and unplug any cables.
  2. PlayStation Portal Speaker (Left) Replacement, Pry up the L1 bumper: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Pry up the L1 bumper: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Pry up the L1 bumper: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Both bumpers are held in place with clips.
    • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
    • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
    • Pry up to unclip the bumper.
    • Slide the spudger along the seam to release any remaining clips.
  3. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the L1 bumper.
  4. PlayStation Portal Speaker (Left) Replacement, Pry up the R1 bumper: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Pry up the R1 bumper: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Pry up the R1 bumper: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the procedure to pry up and remove the R1 bumper.
  5. PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To install a bumper during reassembly:
    • Align the bumper into its slot.
    • Use a finger to press the bumper down firmly until it clicks into place.
  6. PlayStation Portal Speaker (Left) Replacement, Loosen the left joystick trim strip: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the left joystick trim strip: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
    • Twist the opening pick to release the bottom clip.
  7. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick underneath the outer edge of the trim strip.
    • Slide the opening pick along the edge to release the clips.
  8. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick under the inner edge of the strip.
  9. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
    • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
  10. PlayStation Portal Speaker (Left) Replacement, Remove the left joystick trim strip: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left joystick trim strip: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the left joystick trim strip.
  11. PlayStation Portal Speaker (Left) Replacement, Remove the right joystick trim strip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right joystick trim strip: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right joystick trim strip: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the procedure to unclip and remove the right joystick trim strip.
  12. PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To reattach a trim strip during reassembly:
    • Use your fingers to align and clip the top edge in place.
    • Firmly press along the remaining edges to clip the strip in place.
  13. PlayStation Portal Speaker (Left) Replacement, Remove the back shell screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the back shell screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
    • You may need to peel off some tamper-evident stickers to access the screws.
  14. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
  15. PlayStation Portal Speaker (Left) Replacement, Back shell information: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back shell is still secured with numerous clips. The next few steps will show how to unclip the shell while reducing the chance of damaging the clips.
  16. PlayStation Portal Speaker (Left) Replacement, Unclip the back shell: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Unclip the back shell: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the flat edge of a spudger into the back shell's left, inner seam.
    • This releases the clip in that area while flexing the shell slightly, creating a larger outer seam.
    • Keep the spudger inserted in the seam.
  17. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick into the shell's left, outer seam.
    • Slide the pick along the seam to release the clips securing the edge.
    • Keep a pick in the seam to prevent the shell from clipping back together.
  18. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spudger from the inner seam.
  19. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
  20. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip your Portal over.
    • Grasp the top edge of the back shell, near a corner.
    • Gently pull the top edge away until you feel the clips release in that corner.
  21. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull along the top edge to release all the top edge clips.
  22. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the bottom edge of the back shell, near the center.
    • Pull away with firm force to release the clips securing the bottom edge.
  23. PlayStation Portal Speaker (Left) Replacement, Remove the back shell: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the back shell: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back shell.
  24. PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To clip the back shell in place during reassembly:
    • Align the corners near the trigger buttons first.
    • Firmly press around the entire perimeter to clip the shell back in place.
  25. PlayStation Portal Speaker (Left) Replacement, Loosen the left grip shell: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the left grip shell: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
    • From the back, these screws are on the right side of the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver.
    • You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  26. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top edge of the grip shell and twist it slightly outwards (away from the screen) to release the inner clips.
  27. PlayStation Portal Speaker (Left) Replacement, Remove the left grip shell: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left grip shell: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left grip shell: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
    • Twist the spudger along the edge to unclip the bottom portion of the grip shell.
    • Remove the left grip shell.
  28. PlayStation Portal Speaker (Left) Replacement, Remove the left joystick cover: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left joystick cover.
  29. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the left joystick cover.
  30. PlayStation Portal Speaker (Left) Replacement, Remove the left joystick grip: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left joystick grip: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the left grip from the joystick.
  31. PlayStation Portal Speaker (Left) Replacement, Loosen the left joystick: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the left joystick: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to flip up the black lock tab on the left joystick's ZIF connector.
  32. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 2.9 mm‑long screws securing the joystick module to the Portal.
  33. PlayStation Portal Speaker (Left) Replacement, Remove the left joystick: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left joystick: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left joystick: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shift the joystick module so that the flex cable slides out of its socket.
    • Remove the left joystick.
    • During reassembly, slide the joystick cable into its socket before securing the joystick in place with screws.
  34. PlayStation Portal Speaker (Left) Replacement, Loosen the right grip shell: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the right grip shell: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right grip shell to the Portal.
    • From the back, these screws are on the left side of the Portal.
  35. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  36. PlayStation Portal Speaker (Left) Replacement, Remove the right grip shell: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right grip shell: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right grip shell: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right grip shell.
  37. PlayStation Portal Speaker (Left) Replacement, Remove the right joystick cover: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right joystick cover.
  38. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the right joystick cover.
  39. PlayStation Portal Speaker (Left) Replacement, Remove the right joystick grip: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right joystick grip: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the right grip from the joystick.
  40. PlayStation Portal Speaker (Left) Replacement, Loosen the right joystick: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the right joystick: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to flip up the black lock tab on the right joystick's ZIF connector.
  41. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  42. PlayStation Portal Speaker (Left) Replacement, Remove the right joystick: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right joystick: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the right joystick: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right joystick.
  43. PlayStation Portal Speaker (Left) Replacement, Loosen the joystick brackets: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Loosen the joystick brackets: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 6.5 mm‑long screws (two on each side) securing the two joystick brackets to the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver. You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  44. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each joystick bracket is still attached to the Portal by a delicate flex cable. Be careful not to strain the cable as you move the bracket.
    • Carefully flip the right bracket over so that it no longer blocks the edge of the screen.
    • Repeat the process for the left bracket.
  45. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tape to secure the two brackets to the frame so they don't block the screen.
    • Make sure the delicate flex cables aren't strained when the brackets are taped down.
  46. PlayStation Portal Speaker (Left) Replacement, Loosen the screen: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes to soften the adhesive.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  47. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your fingers underneath the bottom edge of the Portal to keep it steady.
    • Apply a suction handle to the center of the bottom edge, as close to the edge as possible.
  48. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step shows how to create an initial gap using an opening tool. If you don't have an opening tool, skip to the next step.
    • Pull up on the suction handle with strong, steady force.
    • Press the edge of an opening tool downwards into the seam to create an initial gap.
    • If you're having trouble, reheat the edge and try again.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the pick more than 2 mm, or you may damage the screen.
  49. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step shows how to create an initial gap using an opening pick.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • If you can't insert the pick, heat the edge and try again. You may need to repeat the process multiple times before the adhesive loosens enough to insert the pick.
  50. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the opening pick downwards to a 45° angle.
    • This helps the opening pick slide underneath the display panel.
    • Insert the opening pick deeper into the seam until the pick can stay in place by itself.
    • You can insert the pick more than 2 mm once you've angled the pick.
  51. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the screen for a minute to reheat the edge.
  52. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the bottom edge to slice through the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  53. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the heating and slicing procedure around the left and top edges of the screen. Leave an opening pick in each corner to prevent the adhesive from resealing.
    • There are no cables along these edges, so you can insert the pick deeper than 2 mm.
  54. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  55. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the left edge of the screen near the corners and lift it slightly to separate any remaining adhesive.
  56. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to strain the short display cable as you move the screen.
    • Swing the left edge of the screen over the right and rest the flipped screen on top of the Portal.
  57. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rest a finger on top of the display cable bracket to prevent it from flying off when you pry.
    • Insert the point of a spudger underneath a corner of the bracket and pry it up.
    • Remove the bracket.
  58. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  59. PlayStation Portal Speaker (Left) Replacement, Remove the screen: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen.
  60. PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Reassembly information: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • You'll need to replace the adhesive to reattach the screen:
    • To ensure a good adhesive bond, thoroughly clean all adhesion surfaces.
    • Remove large chunks of adhesives with the flat edge of a spudger or tweezers.
    • Use high concentration isopropyl alcohol (>90%) to remove any remaining residue. Wipe in one direction with a lint-free cloth or coffee filter until all the adhesive residue is gone.
    • Allow any leftover isopropyl alcohol to completely evaporate before reassembly.
    • Apply strips of double-sided tape such as Tesa tape to the screen perimeter to reattach the screen.
  61. PlayStation Portal Speaker (Left) Replacement, Loosen the motherboard cover: crwdns2935265:061crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eight 6.5 mm‑long screws securing the motherboard cover to the Portal.
  62. PlayStation Portal Speaker (Left) Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat edge of a spudger under the top-right corner of the motherboard cover.
    • Pry up to release the clips securing the corner.
  63. PlayStation Portal Speaker (Left) Replacement, Remove the motherboard cover: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the motherboard cover: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the motherboard cover.
    • During reassembly, lay the cover in place and press along the edges to clip it in place.
  64. PlayStation Portal Speaker (Left) Replacement, Disconnect the battery: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Disconnect the battery: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the battery connector.
  65. PlayStation Portal Speaker (Left) Replacement, Power off your PlayStation Portal: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Power off your PlayStation Portal: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  66. PlayStation Portal Speaker (Left) Replacement, Loosen the left speaker: crwdns2935265:066crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three screws securing the left speaker to the Portal:
    • Two 2.9 mm‑long screws
    • One 6.5 mm‑long screw
    • This screw can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver. You can also try using a JIS #00 screwdriver to get a better grip on the screw.
  67. PlayStation Portal Speaker (Left) Replacement, Remove the left speaker: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left speaker: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Portal Speaker (Left) Replacement, Remove the left speaker: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger underneath the bottom left corner of the left speaker.
    • Pry up and remove the left speaker.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297.935 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.724crwdne2935297:0
crwdns2942667:0crwdne2942667:0 208
