PlayStation 5 Slim Front Trim Assembly Replacement
  1. PlayStation 5 Slim Front Trim Assembly Replacement, Prepare your PlayStation for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Prepare your PlayStation for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Prepare your PlayStation for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the console covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the console covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the console covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. PlayStation 5 Slim Front Trim Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the disc drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the disc drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the disc drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your PlayStation doesn't have a disc drive, skip this step.
    • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
    • Remove the disc drive.
    • During reassembly, place the hooks on the left edge of the drive into their cutouts and firmly press the drive into place so the connector on the bottom right corner goes into its socket.
  5. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the expansion slot cover screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the expansion slot cover screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  6. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the expansion slot cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the expansion slot cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the expansion slot cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  7. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan cables cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan cables cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan cables cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  8. PlayStation 5 Slim Front Trim Assembly Replacement, Free the fan cables: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Free the fan cables: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the fan cables out from under their plastic clip on the frame.
  9. PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  10. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
    • One 11.6 mm‑long screw
  11. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  12. PlayStation 5 Slim Front Trim Assembly Replacement, Flip your PlayStation over: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your PlayStation over.
  13. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the power supply screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the power supply screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the two 21.3 mm‑long screws securing the power supply.
  14. PlayStation 5 Slim Front Trim Assembly Replacement, Flip your PlayStation over: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the tamper evident sticker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the tamper evident sticker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the tamper evident sticker: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  16. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the right‑side inner shell screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the right‑side inner shell screws: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the nine screws securing the right‑side inner shell:
    • Four 18.9 mm‑long screws
    • One 21.3 mm‑long screw
    • Four 31.2 mm‑long screws
  17. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the right‑side inner shell: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the right‑side inner shell: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the right‑side inner shell straight up and remove it.
  18. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the interconnect cable cover screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the interconnect cable cover screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the four screws securing the interconnect cable cover:
    • One 28.7 mm‑long screw
    • Three 7.5 mm‑long screws
  19. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the interconnect cable cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the interconnect cable cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the interconnect cable cover.
  20. PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the interconnect cable: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the interconnect cable: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the interconnect cable: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push the interconnect cable's metal latch down and away from the connector to unlock it.
    • Keep the latch in its unlocked position and carefully pull the interconnect cable straight out of its socket.
    • During reassembly, push the latch into its unlocked position and insert the cable into its socket. Then, push the latch back in place to lock the cable.
  21. PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the antenna cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the antenna cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Disconnect the antenna cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  22. PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the antenna cable tape: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the antenna cable tape: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A piece of tape and a block of foam secure the antenna cables to the heatsink shield.
    • Gently lift both antenna cables to separate the tape from the heatsink shield.
  23. PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the antenna cable foam: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Peel up the antenna cable foam: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Light adhesive secures the foam block to the heatsink shield.
    • Use tweezers to gently peel up the foam block.
    • If you're having trouble, heat an iOpener and apply it to the foam for one minute to soften the adhesive. If you don't have an iOpener, you can use a hair dryer instead.
  24. PlayStation 5 Slim Front Trim Assembly Replacement, Reposition the antenna cables: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Reposition the antenna cables: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Reposition the antenna cables: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
    • During reassembly, use this photo as a reference to put the antenna cables back in their original position.
  25. PlayStation 5 Slim Front Trim Assembly Replacement, Lift the main board assembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Lift the main board assembly: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
    • Your PlayStation's plastic housing will likely flex while lifting the assembly.
  26. PlayStation 5 Slim Front Trim Assembly Replacement, Detach the power supply: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Detach the power supply: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Detach the power supply: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Keep the main board assembly raised with one hand.
    • With your free hand, insert your finger between the assembly and power supply.
    • Push down on the power supply and lift the assembly to separate them.
    • It'll take a significant amount of force to separate the two.
    • During reassembly, press down firmly on the bottom left corner of the main board assembly to fully connect it to the power supply.
  27. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the main board assembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the main board assembly: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the main board assembly: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not grab the main board assembly by the copper heat pipes or its fins, as they can easily be damaged.
    • Firmly secure the plastic housing with one hand.
    • With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
    • Make sure the interconnect cable doesn't get stuck under the main board assembly when lowering it into place.
    • Lower the assembly into its recess so its prongs go into their socket on the power supply and the three cutouts go over their alignment posts.
  28. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the power supply: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the power supply: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the power supply: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the left edge of the power supply and remove it.
    • Insert the power port into its cutout on the back of your PlayStation.
    • Lower the power supply into its recess, making sure the cutout on the bottom left corner goes over its plastic post.
  29. PlayStation 5 Slim Front Trim Assembly Replacement, Unclip the antenna cables: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Unclip the antenna cables: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Unclip the antenna cables: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull both antenna cables up and out of their clips along the rear edge of your PlayStation.
    • During reassembly, place the cables back into their clips on the rear edge of the frame.
  30. PlayStation 5 Slim Front Trim Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push both antenna cables down and out from under their clip on the top right corner of the plastic housing.
  31. PlayStation 5 Slim Front Trim Assembly Replacement, Unclip the front trim: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Unclip the front trim: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With one hand, secure the right edge of the plastic housing.
    • With your free hand, firmly lift the top edge of the front trim to release its three plastic clips.
    • During reassembly, push the front trim onto the frame so the clips snap into place.
  32. PlayStation 5 Slim Front Trim Assembly Replacement, Remove the front trim: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 5 Slim Front Trim Assembly Replacement, Remove the front trim: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front trim straight up and remove it.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119,310 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,855crwdne2935297:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 296
crwdns2942667:0crwdne2942667:0 3,655
