PDP Afterglow Wired Xbox 360 Controller Button Replacement
crwdns2942287:0crwdne2942287:0This guide will provide step-by-step instructions for replacing the A, B, X, and Y buttons on the controller.
crwdns2944105:0crwdne2944105:0
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Using a plastic opening tool, pry the back cover from the front.
Remove the top cover from the bottom and place next to each other.
Remove the rubber button covers from the A, B, X, and Y buttons.
What about the rubber cover that's on all the buttons, similar to the rubber cover behind the D-Pad? What orientation is that meant to be in when reassembling the controller after replacing the buttons?
Push up on the buttons from the front and pull them out from the back.
What about removing the Dpad? i really need help.
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
