PDP Afterglow Wired Xbox 360 Controller Button Replacement
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber button covers from the A, B, X, and Y buttons.
    What about the rubber cover that's on all the buttons, similar to the rubber cover behind the D-Pad? What orientation is that meant to be in when reassembling the controller after replacing the buttons?
    Rohebat - crwdns2934203:0crwdne2934203:0
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PDP Afterglow Wired Xbox 360 Controller Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push up on the buttons from the front and pull them out from the back.
Joi Officer
crwdns2935283:009/17/15crwdne2935283:0
298 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-1, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G1
What about removing the Dpad? i really need help.
Elijah Douglas - crwdns2934203:0crwdne2934203:0
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - crwdns2934203:0crwdne2934203:0
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 5,602
