If your Ozeino OW810 Plug Jack isn't properly producing clear audio/video connections, telecommunications, and power supply use this guide to replace the Plug Jack. Before using this guide, inspect the plug jack to ensure there is no physical damage, loose connections, debris buildup, outdated drivers, or verify audio settings.
Before beginning this guide make sure you have gathered your tools.
You will need The Marlin Screw Driver Set
It will take approximately 3 min to get assembled
Once your tools are gathered you may begin the guide
Before beginning detach the ear muff
Use the Metal Spudger to help detach
Highlighted in the red circle is what needs to be detached in order to start the guide
Everything will be located on the left side of The Ozeino OW810
After detaching the ear muff gather your tools
You will need The Marlin Screw Driver set
Take The Phillips #0 screwdriver to begin
Highlighted in red is the first screw needed to remove
Use Phillips #0 to unscrew
Highlighted is the second screw needed to be removed
Use Phillips #0 screwdriver
Highlighted is the third screw needed to be removed
Use Phillips #0
Highlighted is the fourth screw needed to be removed
Highlighted is the fifth screw needed to be removed
Highlighted is the last screw needed to be removed
You should have unscrewed 6 screws from the ear muff
I would shorten this. Shortening this to, "There are six screws that need to be removed," can help the audience read through the guide faster.
After unscrewing the screws from the ear muff remove the piece
Locate circuit board highlighted
Highlighted is the screw needed to be removed from the circuit board
After following the guide and detaching the ear muffs begging locating the plug jack and begin replacement.
The replacement should take approximately 10 minutes
There is a lot of repetition regarding the tools. I recommend being clear in the beginning which tool to use and only repeating when another tool is used. The tools and screws are the main area I would recommend fixing. This is a good guide, and easy to understand.
