Ortizan X10 USB-C Charging Port Replacement
  1. Ortizan X10 USB-C Charging Port Replacement, Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement, Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to remove the rubber end caps.
  2. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws (two on each end).
    • Firmly grip the top of the speaker, stabilize the base, and twist the cap counterclockwise to loosen and remove. Repeat this step for the bottom cap.
  3. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool into the seam between the grille and body. Lift and crack it open just a little.
  4. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, pull the speaker out of the casing by holding the speaker in one hand and the shell in the other.
  5. Ortizan X10 USB-C Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Utilizing the iFixit Mahi 1/4" bit driver with the Philips #00 Bit, remove the screw securing the LED circuit board. Apply firm, even pressure while turning the screwdriver counterclockwise (to the left) to loosen and remove the screw.
  6. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel away the rubber button strip from the device housing. Use the iFixit opening tool to lift one end of the rubber strip, then use your hands to peel off the rest.
  7. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Utilizing the iFixit Mahi 1/4" bit driver with the Philips #00 Bit, remove the eight screws surrounding the button interface to detach the plastic button housing.
    • To remove the eight screws, align the tip of the screwdriver (with the bit already inserted) with the head of the screw, making sure it fits snugly into the grooves. Apply firm, even pressure while turning the screwdriver counterclockwise (to the left) to loosen and remove the screw.
  8. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Utilize the iFixit Opening Tool to lift and remove the rubber power button board.
  9. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully extract the motherboard from the device by gently shifting it left and right to disengage it from internal casing.
    • Be cautious when removing the motherboard, as JST Connectors are attached to it and can be damaged if pulled or disconnected improperly.
  10. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Utilizing the Precision Tweezer disconnect all three JST Connectors connected to the motherboard.
    • To disconnect the first three JST Connectors, use the precision tweezer and firmly grip the sides of the connectors and pull it up.
    • To disconnect the last JST Connector, use the precision tweezer, firmly grip the sides of the connectors and carefully move it side to side until it unplugs.
    • For helpful instructions on disconnecting various connector types, refer to this guide.
  11. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the LED connector from the motherboard, use a pair of tweezers or a clean fingernail to gently wiggle the black connector from side to side until it slides off.
    • Use caution when wiggling this connector side to side, as excessive force may cause it to break.
    • Once the connector is removed, the white ZIF tape will naturally detach from the motherboard. At this point, all components have been successfully disconnected, and the motherboard is ready for replacement. To reassemble your device, follow these instructions in reverse order.
  12. Ortizan X10 USB-C Charging Port Replacement, USB-C Charging Port: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the USB-C charging port on your motherboard.
  13. Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ortizan X10 USB-C Charging Port Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are four primary solder joints, two on each side of the USB-C charging port, that requires desoldering.
    • Additionally, two solder points located at the rear of the port must also be addressed.
    • To solder these connections, use a fine-tipped soldering iron to apply controlled, even heat to each joint.
    • Maintain a steady hand and avoid prolonged heat to prevent PCB damage.
    • Once the solder has melted, gently lift the USB-C using tweezers. If resistant is felt, apply additional heat to ensure all joints are fully liquefied before removal.
    • While the use of a soldering iron may take longer than other methods, it offers greater precision and reduces the risk of damaging surrounding components. Be patient and reapply heat as needed to ensure complete detachment of the USB-C port.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Yasmin Williams
crwdns2935283:003/18/25crwdne2935283:0
315 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-2, Konn Spring 2025 crwdns2935289:0UMass Dartmouth, Team 4-2, Konn Spring 2025crwdne2935289:0
UMASSD-KONN-S25S4G2
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 213
