Opening Procedure
  1. Opening Procedure, Power down your watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening Procedure, Power down your watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Opening Procedure, Unfasten the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. Opening Procedure, Loosen the back cover adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  4. Opening Procedure, Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening Procedure, Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening Procedure, Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
  5. Opening Procedure, Disconnect the sensor assembly cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening Procedure, Disconnect the sensor assembly cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  6. Opening Procedure, Remove the back cover assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening Procedure, Remove the back cover assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening Procedure, Remove the back cover assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover assembly.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237,498 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,826crwdne2935297:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,701
